DJI Manifold 2 Jetpack 3.3, CUDA not found, cannot installl Pytorch+cu
Hi i am running a dji manifold2, which contains a NVIDIA Jetson TX2, however it tells me CUDA device not found, even though there is CUDA 9 installed !
Source code: GitHub - mikel-brostrom/Yolov5_DeepSort_Pytorch: Real-time multi-object tracker using YOLO v5 and deep sort
Command: python3 track.py --source 0 --show-vid
Loading weights from deep_sort_pytorch/deep_sort/deep/checkpoint/ckpt.t7... Done!
  File "track.py", line 243, in <module>
    detect(opt)
  File "track.py", line 51, in detect
    device = select_device(opt.device)
  File "/media/dji/80GBstore/targetTrack/mikelbrostromNov2021/Yolov5_DeepSort_Pytorch/yolov5/utils/torch_utils.py", line 65, in select_device
    assert torch.cuda.is_available(), f'CUDA unavailable, invalid device {device} requested'  # check availability
AssertionError: CUDA unavailable, invalid device 0 requested
Python version and pip list
Python 3.8.9 (default, Apr  3 2021, 01:02:10)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
torch                         1.8.0
torchaudio                    0.10.1
torchvision                   0.11.1
Drivers query
/usr/local/cuda/samples/1_Utilities/deviceQuery$ ./deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA Tegra X2"
  CUDA Driver Version / Runtime Version          9.0 / 9.0
  CUDA Capability Major/Minor version number:    6.2
  Total amount of global memory:                 7839 MBytes (8219348992 bytes)
  ( 2) Multiprocessors, (128) CUDA Cores/MP:     256 CUDA Cores
  GPU Max Clock rate:                            1301 MHz (1.30 GHz)
  Memory Clock rate:                             1600 Mhz
  Memory Bus Width:                              128-bit
  L2 Cache Size:                                 524288 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 32768
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 1 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            Yes
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 1
Result = PASS
nvcc --version
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Sun_Nov_19_03:16:56_CST_2017
Cuda compilation tools, release 9.0, V9.0.252
nvcc --version
My system
DJI Manifold 2
NVIDIA Jetson TX2
ARMv8 Processor rev 3 (v8l) × 4 ARMv8 Processor rev 0 (v8l) × 2
NVIDIA Tegra X2 (nvgpu)/integrated
64-bit
Extra debugging:
>>> import torch
>>> print(torch.version.cuda)
None
>>> torch.cuda.current_device()
  File "<stdin>", line 1, in <module>
  File "/media/dji/80GBstore/pyenvs/newpy38/lib/python3.8/site-packages/torch/cuda/__init__.py", line 388, in current_device
    _lazy_init()
  File "/media/dji/80GBstore/pyenvs/newpy38/lib/python3.8/site-packages/torch/cuda/__init__.py", line 164, in _lazy_init
    raise AssertionError("Torch not compiled with CUDA enabled")
AssertionError: Torch not compiled with CUDA enabled
>>> torch.cuda.device(0)
<torch.cuda.device object at 0x7fa871ad00>
The odd thing is, i have also attempted to install CUDA-enabled versions of torch from torch’s website, and this is what i got, after trying on virtual environments for python3.7 and python3.8
pip install torch-1.1.0-cp37-cp37m-linux_x86_64.whl
ERROR: torch-1.1.0-cp37-cp37m-linux_x86_64.whl is not a supported wheel on this platform.
pip install torch-1.0.1.post2-cp37-cp37m-linux_x86_64.whl
ERROR: torch-1.0.1.post2-cp37-cp37m-linux_x86_64.whl is not a supported wheel on this platform.
pip install torch-1.7.0+cu92-cp38-cp38-linux_x86_64.whl
ERROR: torch-1.7.0+cu92-cp38-cp38-linux_x86_64.whl is not a supported wheel on this platform.
pip install torch-1.7.1+cu92-cp39-cp39-linux_x86_64.whl
ERROR: torch-1.7.1+cu92-cp39-cp39-linux_x86_64.whl is not a supported wheel on this platform.
pip install torch-1.7.1+cpu-cp39-cp39-linux_x86_64.whl
ERROR: torch-1.7.1+cpu-cp39-cp39-linux_x86_64.whl is not a supported wheel on this platform.
Here are the python run virtual environments
Python 3.7.10 (default, Feb 20 2021, 21:21:24)
Output from uname -a
uname -a
Linux manifold2 4.4.38+ #2 SMP PREEMPT Mon Jun 3 20:19:02 CST 2019 aarch64 aarch64 aarch64 GNU/Linux
Output from “head -n 1 /etc/nv_tegra_release”
# R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64, DATE: Thu May 17 07:29:06 UTC 2018
Could anyone advise what could be the problem ?
  1. Why cant CUDA-compatible version of torch be installed ?
  2. Are there any updates I have to do before this can be done ?
We’re not familiar with dji manifold2, but you may check below link to see if can help: Dji Manifold2-G Jetson TX2 install Pytorch
@kayccc thanks for the link ! Hmm there’s some progress, but it tells me
CMake Error at cmake/public/cuda.cmake:49 (message):
  PyTorch requires CUDA 10.2 or above.
Call Stack (most recent call first):
  cmake/Dependencies.cmake:43 (include)
  CMakeLists.txt:669 (include)
Understandbly this means my CUDA is too old. I have tried using the nvidia provided jetpack firware for Jetpack 4, but after updating the USB hardware interfaces on my DJI Manifold 2 stopped working (my mouse and keyboard cannot work), as such i was forced to downgrade back using DJI’s firmware for Jetpack 3.3…
Would you know how I can go about updating the CUDA version ? Thank you !
EDIT:
I realised when i git cloned it gave me the latest version of pytorch. I will go try the minimum version i need which is pytorch1.7.0 to see if it is ok.
I am back with the error log…
This is from installing pytorch 1.7 release from the source itself (the github repo). I am installing it with a python 3.8 virtual environment, non-conda
python setup.py install
Building wheel torch-1.7.0a0
-- Building version 1.7.0a0
cmake -DBUILD_PYTHON=True -DBUILD_TEST=True -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/media/dji/80GBstore/pyenvs/newpy38/pytorch/torch -DCMAKE_PREFIX_PATH=/opt/ros/kinetic -DCUDNN_INCLUDE_DIR=/usr/include -DCUDNN_LIBRARY=/usr/lib/aarch64-linux-gnu -DNUMPY_INCLUDE_DIR=/media/dji/80GBstore/pyenvs/newpy38/lib/python3.8/site-packages/numpy/core/include -DONNX_ML=1 -DPYTHON_EXECUTABLE=/media/dji/80GBstore/pyenvs/newpy38/bin/python -DPYTHON_INCLUDE_DIR=/usr/include/python3.8 -DPYTHON_LIBRARY=/usr/lib/libpython3.8.so.1.0 -DTORCH_BUILD_VERSION=1.7.0a0 -DUSE_CUDA=1 -DUSE_CUDNN=1 -DUSE_DISTRIBUTED=1 -DUSE_NCCL=0 -DUSE_NUMPY=True -DUSE_OPENCV=ON /media/dji/80GBstore/pyenvs/newpy38/pytorch
-- The CXX compiler identification is GNU 5.5.0
-- The C compiler identification is GNU 5.5.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Not forcing any particular BLAS to be found
-- Performing Test COMPILER_WORKS
-- Performing Test COMPILER_WORKS - Success
-- Performing Test SUPPORT_GLIBCXX_USE_C99
-- Performing Test SUPPORT_GLIBCXX_USE_C99 - Success
-- Performing Test CAFFE2_EXCEPTION_PTR_SUPPORTED
-- Performing Test CAFFE2_EXCEPTION_PTR_SUPPORTED - Success
-- std::exception_ptr is supported.
-- Performing Test CAFFE2_NEED_TO_TURN_OFF_DEPRECATION_WARNING
-- Performing Test CAFFE2_NEED_TO_TURN_OFF_DEPRECATION_WARNING - Success
-- Performing Test CAFFE2_COMPILER_SUPPORTS_AVX2_EXTENSIONS
-- Performing Test CAFFE2_COMPILER_SUPPORTS_AVX2_EXTENSIONS - Failed
-- Performing Test CAFFE2_COMPILER_SUPPORTS_AVX512_EXTENSIONS
-- Performing Test CAFFE2_COMPILER_SUPPORTS_AVX512_EXTENSIONS - Failed
-- Performing Test COMPILER_SUPPORTS_HIDDEN_VISIBILITY
-- Performing Test COMPILER_SUPPORTS_HIDDEN_VISIBILITY - Success
-- Performing Test COMPILER_SUPPORTS_HIDDEN_INLINE_VISIBILITY
-- Performing Test COMPILER_SUPPORTS_HIDDEN_INLINE_VISIBILITY - Success
-- Performing Test COMPILER_SUPPORTS_RDYNAMIC
-- Performing Test COMPILER_SUPPORTS_RDYNAMIC - Success
-- Building using own protobuf under third_party per request.
-- Use custom protobuf build.
-- 3.11.4.0
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Check if compiler accepts -pthread
-- Check if compiler accepts -pthread - yes
-- Found Threads: TRUE
-- Performing Test protobuf_HAVE_BUILTIN_ATOMICS
-- Performing Test protobuf_HAVE_BUILTIN_ATOMICS - Success
-- Caffe2 protobuf include directory: $<BUILD_INTERFACE:/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/protobuf/src>$<INSTALL_INTERFACE:include>
-- Trying to find preferred BLAS backend of choice: MKL
-- MKL_THREADING = OMP
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of void*
-- Check size of void* - done
CMake Warning at cmake/Dependencies.cmake:148 (message):
  MKL could not be found.  Defaulting to Eigen
  CMakeLists.txt:513 (include)
CMake Warning at cmake/Dependencies.cmake:172 (message):
  Preferred BLAS (MKL) cannot be found, now searching for a general BLAS
  library
-- Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_intel_lp64: not found
-- Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_intel: not found
-- Checking for [mkl_intel - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_gf_lp64: not found
-- Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_gf: not found
-- Checking for [mkl_gf - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_intel - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_gf - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf - mkl_core - pthread - m - dl]
-- Checking for [mkl - guide - pthread - m]
--   Library mkl: not found
-- MKL library not found
-- Checking for [Accelerate]
--   Library Accelerate: BLAS_Accelerate_LIBRARY-NOTFOUND
-- Checking for [vecLib]
--   Library vecLib: BLAS_vecLib_LIBRARY-NOTFOUND
-- Checking for [openblas]
--   Library openblas: /usr/lib/libopenblas.so
-- Looking for sgemm_
-- Looking for sgemm_ - found
-- Performing Test BLAS_F2C_DOUBLE_WORKS
-- Performing Test BLAS_F2C_DOUBLE_WORKS - Failed
-- Performing Test BLAS_F2C_FLOAT_WORKS
-- Performing Test BLAS_F2C_FLOAT_WORKS - Success
-- Performing Test BLAS_USE_CBLAS_DOT
-- Performing Test BLAS_USE_CBLAS_DOT - Success
-- Found a library with BLAS API (open).
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/cc
-- Brace yourself, we are building NNPACK
-- NNPACK backend is neon
CMake Deprecation Warning at third_party/googletest/CMakeLists.txt:1 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
CMake Deprecation Warning at third_party/googletest/googlemock/CMakeLists.txt:42 (cmake_minimum_required):
  CMake.
CMake Deprecation Warning at third_party/googletest/googletest/CMakeLists.txt:49 (cmake_minimum_required):
  CMake.
-- Found PythonInterp: /media/dji/80GBstore/pyenvs/newpy38/bin/python (found version "3.8.9")
-- Found Git: /usr/bin/git (found version "2.7.4")
-- git Version: v1.4.0-505be96a
-- Version: 1.4.0
-- Performing Test HAVE_CXX_FLAG_STD_CXX11
-- Performing Test HAVE_CXX_FLAG_STD_CXX11 - Success
-- Performing Test HAVE_CXX_FLAG_WALL
-- Performing Test HAVE_CXX_FLAG_WALL - Success
-- Performing Test HAVE_CXX_FLAG_WEXTRA
-- Performing Test HAVE_CXX_FLAG_WEXTRA - Success
-- Performing Test HAVE_CXX_FLAG_WSHADOW
-- Performing Test HAVE_CXX_FLAG_WSHADOW - Success
-- Performing Test HAVE_CXX_FLAG_WERROR
-- Performing Test HAVE_CXX_FLAG_WERROR - Success
-- Performing Test HAVE_CXX_FLAG_PEDANTIC
-- Performing Test HAVE_CXX_FLAG_PEDANTIC - Success
-- Performing Test HAVE_CXX_FLAG_PEDANTIC_ERRORS
-- Performing Test HAVE_CXX_FLAG_PEDANTIC_ERRORS - Success
-- Performing Test HAVE_CXX_FLAG_WSHORTEN_64_TO_32
-- Performing Test HAVE_CXX_FLAG_WSHORTEN_64_TO_32 - Failed
-- Performing Test HAVE_CXX_FLAG_WFLOAT_EQUAL
-- Performing Test HAVE_CXX_FLAG_WFLOAT_EQUAL - Success
-- Performing Test HAVE_CXX_FLAG_FSTRICT_ALIASING
-- Performing Test HAVE_CXX_FLAG_FSTRICT_ALIASING - Success
-- Performing Test HAVE_CXX_FLAG_WNO_DEPRECATED_DECLARATIONS
-- Performing Test HAVE_CXX_FLAG_WNO_DEPRECATED_DECLARATIONS - Success
-- Performing Test HAVE_CXX_FLAG_WSTRICT_ALIASING
-- Performing Test HAVE_CXX_FLAG_WSTRICT_ALIASING - Success
-- Performing Test HAVE_CXX_FLAG_WD654
-- Performing Test HAVE_CXX_FLAG_WD654 - Failed
-- Performing Test HAVE_CXX_FLAG_WTHREAD_SAFETY
-- Performing Test HAVE_CXX_FLAG_WTHREAD_SAFETY - Failed
-- Performing Test HAVE_CXX_FLAG_COVERAGE
-- Performing Test HAVE_CXX_FLAG_COVERAGE - Success
-- Performing Test HAVE_STD_REGEX
-- Performing Test HAVE_STD_REGEX -- success
-- Performing Test HAVE_GNU_POSIX_REGEX
-- Performing Test HAVE_GNU_POSIX_REGEX -- failed to compile
-- Performing Test HAVE_POSIX_REGEX
-- Performing Test HAVE_POSIX_REGEX -- success
-- Performing Test HAVE_STEADY_CLOCK
-- Performing Test HAVE_STEADY_CLOCK -- success
CMake Warning at cmake/Dependencies.cmake:659 (message):
  A compiler with AVX512 support is required for FBGEMM.  Not compiling with
  FBGEMM.  Turn this warning off by USE_FBGEMM=OFF.
CMake Warning at cmake/Dependencies.cmake:698 (message):
  Turning USE_FAKELOWP off as it depends on USE_FBGEMM.
-- Found Numa: /usr/include
-- Found Numa  (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libnuma.so)
-- OpenCV found (/usr/local/lib/cmake/opencv4)
-- Using third party subdirectory Eigen.
-- Found PythonInterp: /media/dji/80GBstore/pyenvs/newpy38/bin/python (found suitable version "3.8.9", minimum required is "3.0")
-- Found PythonLibs: /usr/lib/libpython3.8.so.1.0 (found suitable version "3.8.9", minimum required is "3.0")
-- Could NOT find pybind11 (missing: pybind11_DIR)
-- Could NOT find pybind11 (missing: pybind11_INCLUDE_DIR)
-- Using third_party/pybind11.
-- pybind11 include dirs: /media/dji/80GBstore/pyenvs/newpy38/pytorch/cmake/../third_party/pybind11/include
-- Found MPI_C: /usr/lib/openmpi/lib/libmpi.so (found version "3.0")
-- Found MPI_CXX: /usr/lib/openmpi/lib/libmpi_cxx.so (found version "3.0")
-- Found MPI: TRUE (found version "3.0")
-- MPI support found
-- MPI compile flags: -pthread
-- MPI include path: /usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include/usr/lib/openmpi/include/usr/lib/openmpi/include/openmpi
-- MPI LINK flags path: -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,--enable-new-dtags -pthread
-- MPI libraries: /usr/lib/openmpi/lib/libmpi_cxx.so/usr/lib/openmpi/lib/libmpi.so
CMake Warning at cmake/Dependencies.cmake:1005 (message):
  OpenMPI found, but it is not built with CUDA support.
CMake Warning (dev) at /usr/local/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:438 (message):
  The package name passed to `find_package_handle_standard_args` (OpenMP_C)
  does not match the name of the calling package (OpenMP).  This can lead to
  problems in calling code that expects `find_package` result variables
  (e.g., `_FOUND`) to follow a certain pattern.
  cmake/Modules/FindOpenMP.cmake:565 (find_package_handle_standard_args)
  cmake/Dependencies.cmake:1065 (find_package)
This warning is for project developers.  Use -Wno-dev to suppress it.
  The package name passed to `find_package_handle_standard_args` (OpenMP_CXX)
-- Adding OpenMP CXX_FLAGS: -fopenmp
-- Will link against OpenMP libraries: /usr/lib/gcc/aarch64-linux-gnu/5/libgomp.so;/usr/lib/aarch64-linux-gnu/libpthread.so
-- Found CUDA: /usr/local/cuda-9.0 (found version "9.0")
-- Caffe2: CUDA detected: 9.0
-- Caffe2: CUDA nvcc is: /usr/local/cuda-9.0/bin/nvcc
-- Caffe2: CUDA toolkit directory: /usr/local/cuda-9.0
-- Caffe2: Header version is: 9.0
-- Found CUDNN: /usr/local/cuda-9.0/lib64/libcudnn.so
-- Found cuDNN: v7.4.2  (include: /usr/local/cuda-9.0/include, library: /usr/local/cuda-9.0/lib64/libcudnn.so)
-- Autodetected CUDA architecture(s):  6.2
-- Added CUDA NVCC flags for: -gencode;arch=compute_62,code=sm_62
-- Could NOT find CUB (missing: CUB_INCLUDE_DIR)
CMake Warning (dev) at third_party/gloo/CMakeLists.txt:21 (option):
  Policy CMP0077 is not set: option() honors normal variables.  Run "cmake
  --help-policy CMP0077" for policy details.  Use the cmake_policy command to
  set the policy and suppress this warning.
  For compatibility with older versions of CMake, option is clearing the
  normal variable 'BUILD_BENCHMARK'.
-- Gloo build as SHARED library
-- Found CUDA: /usr/local/cuda-9.0 (found suitable version "9.0", minimum required is "7.0")
-- CUDA detected: 9.0
-- Performing Test UV_LINT_W4
-- Performing Test UV_LINT_W4 - Failed
-- Performing Test UV_LINT_WALL
-- Performing Test UV_LINT_WALL - Success
-- Performing Test UV_LINT_NO_UNUSED_PARAMETER
-- Performing Test UV_LINT_NO_UNUSED_PARAMETER - Success
-- Performing Test UV_LINT_STRICT_PROTOTYPES
-- Performing Test UV_LINT_STRICT_PROTOTYPES - Success
-- Performing Test UV_LINT_EXTRA
-- Performing Test UV_LINT_EXTRA - Success
-- Found uv: 1.38.1 (found version "1.38.1")
CMake Warning at cmake/Dependencies.cmake:1347 (message):
  Metal is only used in ios builds.
Generated: /media/dji/80GBstore/pyenvs/newpy38/pytorch/build/third_party/onnx/onnx/onnx_onnx_torch-ml.proto
Generated: /media/dji/80GBstore/pyenvs/newpy38/pytorch/build/third_party/onnx/onnx/onnx-operators_onnx_torch-ml.proto
-- ******** Summary ********
--   CMake version         : 3.22.0
--   CMake command         : /usr/local/bin/cmake
--   System                : Linux
--   C++ compiler          : /usr/bin/c++
--   C++ compiler version  : 5.5.0
--   CXX flags             :  -fvisibility-inlines-hidden -DUSE_PTHREADPOOL -fopenmp -Wnon-virtual-dtor
--   Build type            : Release
--   Compile definitions   : ONNX_ML=1;ONNXIFI_ENABLE_EXT=1
--   CMAKE_PREFIX_PATH     : /opt/ros/kinetic;/usr/local/cuda-9.0
--   CMAKE_INSTALL_PREFIX  : /media/dji/80GBstore/pyenvs/newpy38/pytorch/torch
--   CMAKE_MODULE_PATH     : /media/dji/80GBstore/pyenvs/newpy38/pytorch/cmake/Modules;/media/dji/80GBstore/pyenvs/newpy38/pytorch/cmake/public/../Modules_CUDA_fix
--   ONNX version          : 1.7.0
--   ONNX NAMESPACE        : onnx_torch
--   ONNX_BUILD_TESTS      : OFF
--   ONNX_BUILD_BENCHMARKS : OFF
--   ONNX_USE_LITE_PROTO   : OFF
--   ONNXIFI_DUMMY_BACKEND : OFF
--   ONNXIFI_ENABLE_EXT    : OFF
--   Protobuf compiler     :
--   Protobuf includes     :
--   Protobuf libraries    :
--   BUILD_ONNX_PYTHON     : OFF
--   System                : Linux
--   ONNX version          : 1.4.1
-- Found CUDA with FP16 support, compiling with torch.cuda.HalfTensor
-- Adding -DNDEBUG to compile flags
-- MAGMA not found. Compiling without MAGMA support
-- Could not find hardware support for NEON on this machine.
-- No OMAP3 processor on this machine.
-- No OMAP4 processor on this machine.
-- asimd/Neon found with compiler flag : -D__NEON__
-- Looking for cpuid.h
-- Looking for cpuid.h - not found
-- Performing Test NO_GCC_EBX_FPIC_BUG
-- Performing Test NO_GCC_EBX_FPIC_BUG - Failed
-- Performing Test C_HAS_AVX_1
-- Performing Test C_HAS_AVX_1 - Failed
-- Performing Test C_HAS_AVX_2
-- Performing Test C_HAS_AVX_2 - Failed
-- Performing Test C_HAS_AVX_3
-- Performing Test C_HAS_AVX_3 - Failed
-- Performing Test C_HAS_AVX2_1
-- Performing Test C_HAS_AVX2_1 - Failed
-- Performing Test C_HAS_AVX2_2
-- Performing Test C_HAS_AVX2_2 - Failed
-- Performing Test C_HAS_AVX2_3
-- Performing Test C_HAS_AVX2_3 - Failed
-- Performing Test CXX_HAS_AVX_1
-- Performing Test CXX_HAS_AVX_1 - Failed
-- Performing Test CXX_HAS_AVX_2
-- Performing Test CXX_HAS_AVX_2 - Failed
-- Performing Test CXX_HAS_AVX_3
-- Performing Test CXX_HAS_AVX_3 - Failed
-- Performing Test CXX_HAS_AVX2_1
-- Performing Test CXX_HAS_AVX2_1 - Failed
-- Performing Test CXX_HAS_AVX2_2
-- Performing Test CXX_HAS_AVX2_2 - Failed
-- Performing Test CXX_HAS_AVX2_3
-- Performing Test CXX_HAS_AVX2_3 - Failed
-- Looking for cheev_
-- Looking for cheev_ - found
-- Looking for cgesdd_
-- Looking for cgesdd_ - found
-- Found a library with LAPACK API (open).
disabling ROCM because NOT USE_ROCM is set
-- MIOpen not found. Compiling without MIOpen support
disabling MKLDNN because USE_MKLDNN is not set
-- Looking for clock_gettime in rt
-- Looking for clock_gettime in rt - found
-- Looking for mmap
-- Looking for mmap - found
-- Looking for shm_open
-- Looking for shm_open - found
-- Looking for shm_unlink
-- Looking for shm_unlink - found
-- Looking for malloc_usable_size
-- Looking for malloc_usable_size - found
-- Performing Test C_HAS_THREAD
-- Performing Test C_HAS_THREAD - Success
-- Version: 7.0.3
-- Build type: Release
-- CXX_STANDARD: 14
-- Performing Test has_std_14_flag
-- Performing Test has_std_14_flag - Success
-- Performing Test has_std_1y_flag
-- Performing Test has_std_1y_flag - Success
-- Performing Test SUPPORTS_USER_DEFINED_LITERALS
-- Performing Test SUPPORTS_USER_DEFINED_LITERALS - Success
-- Performing Test FMT_HAS_VARIANT
-- Performing Test FMT_HAS_VARIANT - Failed
-- Required features: cxx_variadic_templates
-- Looking for strtod_l
-- Looking for strtod_l - not found
-- GCC 5.5.0: Adding gcc and gcc_s libs to link line
-- Performing Test HAS_WERROR_FORMAT
-- Performing Test HAS_WERROR_FORMAT - Success
-- Performing Test HAS_VST1
-- Performing Test HAS_VST1 - Failed
-- Performing Test HAS_VLD1
-- Performing Test HAS_VLD1 - Failed
-- Looking for backtrace
-- Looking for backtrace - found
-- backtrace facility detected in default set of libraries
-- Found Backtrace: /usr/include
-- NUMA paths:
-- /usr/include
-- /usr/lib/aarch64-linux-gnu/libnuma.so
-- Using ATen parallel backend: OMP
CMake Deprecation Warning at third_party/sleef/CMakeLists.txt:20 (cmake_policy):
  The OLD behavior for policy CMP0066 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
-- Found OpenSSL: /usr/lib/aarch64-linux-gnu/libcrypto.so (found version "1.0.2g")
-- Check size of long double
-- Check size of long double - done
-- Performing Test COMPILER_SUPPORTS_LONG_DOUBLE
-- Performing Test COMPILER_SUPPORTS_LONG_DOUBLE - Success
-- Performing Test COMPILER_SUPPORTS_FLOAT128
-- Performing Test COMPILER_SUPPORTS_FLOAT128 - Failed
-- Performing Test COMPILER_SUPPORTS_SVE
-- Performing Test COMPILER_SUPPORTS_SVE - Failed
-- Found OpenMP_C: -fopenmp (found version "4.0")
-- Found OpenMP_CXX: -fopenmp (found version "4.0")
-- Found OpenMP: TRUE (found version "4.0")
-- Performing Test COMPILER_SUPPORTS_OPENMP
-- Performing Test COMPILER_SUPPORTS_OPENMP - Success
-- Performing Test COMPILER_SUPPORTS_WEAK_ALIASES
-- Performing Test COMPILER_SUPPORTS_WEAK_ALIASES - Success
-- Performing Test COMPILER_SUPPORTS_BUILTIN_MATH
-- Performing Test COMPILER_SUPPORTS_BUILTIN_MATH - Success
-- Performing Test COMPILER_SUPPORTS_SYS_GETRANDOM
-- Performing Test COMPILER_SUPPORTS_SYS_GETRANDOM - Success
-- Configuring build for SLEEF-v3.4.0
   Target system: Linux-4.4.38+
   Target processor: aarch64
   Host system: Linux-4.4.38+
   Host processor: aarch64
   Detected C compiler: GNU @ /usr/bin/cc
-- Using option `-Wall -Wno-unused -Wno-attributes -Wno-unused-result -Wno-psabi -ffp-contract=off -fno-math-errno -fno-trapping-math` to compile libsleef
-- Building shared libs : OFF
-- MPFR : LIB_MPFR-NOTFOUND
-- GMP : /usr/lib/aarch64-linux-gnu/libgmp.so
-- RT : /usr/lib/aarch64-linux-gnu/librt.so
-- FFTW3 : LIBFFTW3-NOTFOUND
-- OPENSSL : 1.0.2g
-- SDE : SDE_COMMAND-NOTFOUND
-- RUNNING_ON_TRAVIS : 0
-- COMPILER_SUPPORTS_OPENMP : 1
AT_INSTALL_INCLUDE_DIR include/ATen/core
core header install: /media/dji/80GBstore/pyenvs/newpy38/pytorch/build/aten/src/ATen/core/TensorBody.h
-- NCCL operators skipped due to no CUDA support
-- Excluding FakeLowP operators
-- Excluding ideep operators as we are not using ideep
-- Including image processing operators
-- Excluding video processing operators due to no opencv
-- Include Observer library
-- /usr/bin/c++ /media/dji/80GBstore/pyenvs/newpy38/pytorch/torch/abi-check.cpp -o /media/dji/80GBstore/pyenvs/newpy38/pytorch/build/abi-check
-- Determined _GLIBCXX_USE_CXX11_ABI=1
-- MPI_INCLUDE_PATH: /usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent;/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include;/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi
-- MPI_LIBRARIES: /usr/lib/openmpi/lib/libmpi_cxx.so;/usr/lib/openmpi/lib/libmpi.so
-- MPIEXEC: /usr/bin/mpiexec
CMake Deprecation Warning at torch/lib/libshm/CMakeLists.txt:2 (cmake_minimum_required):
  CMake.
CMake Deprecation Warning at torch/lib/libshm/CMakeLists.txt:3 (cmake_policy):
  CMake.
  caffe2/CMakeLists.txt:925 (find_package)
-- pytorch is compiling with OpenMP.
OpenMP CXX_FLAGS: -fopenmp.
OpenMP libraries: /usr/lib/gcc/aarch64-linux-gnu/5/libgomp.so;/usr/lib/aarch64-linux-gnu/libpthread.so.
-- Caffe2 is compiling with OpenMP.
-- Using lib/python3.8/site-packages as python relative installation path
CMake Warning at CMakeLists.txt:788 (message):
  Generated cmake files are only fully tested if one builds with system glog,
  gflags, and protobuf.  Other settings may generate files that are not well
  tested.
-- General:
--   System                : Linux
--   C++ compiler id       : GNU
--   BLAS                  : MKL
--   CXX flags             :  -fvisibility-inlines-hidden -DUSE_PTHREADPOOL -fopenmp -DNDEBUG -DUSE_QNNPACK -DUSE_PYTORCH_QNNPACK -DUSE_XNNPACK -DUSE_VULKAN_WRAPPER -O2 -fPIC -Wno-narrowing -Wall -Wextra -Werror=return-type -Wno-missing-field-initializers -Wno-type-limits -Wno-array-bounds -Wno-unknown-pragmas -Wno-sign-compare -Wno-unused-parameter -Wno-unused-variable -Wno-unused-function -Wno-unused-result -Wno-unused-local-typedefs -Wno-strict-overflow -Wno-strict-aliasing -Wno-error=deprecated-declarations -Wno-psabi -Wno-error=pedantic -Wno-error=redundant-decls -Wno-error=old-style-cast -fdiagnostics-color=always -Wno-unused-but-set-variable -Wno-maybe-uninitialized -fno-math-errno -fno-trapping-math -Werror=format -DMISSING_ARM_VST1 -DMISSING_ARM_VLD1
--   Compile definitions   : ONNX_ML=1;ONNXIFI_ENABLE_EXT=1;ONNX_NAMESPACE=onnx_torch;HAVE_MMAP=1;_FILE_OFFSET_BITS=64;HAVE_SHM_OPEN=1;HAVE_SHM_UNLINK=1;HAVE_MALLOC_USABLE_SIZE=1;USE_EXTERNAL_MZCRC;MINIZ_DISABLE_ZIP_READER_CRC32_CHECKS
--   TORCH_VERSION         : 1.7.0
--   CAFFE2_VERSION        : 1.7.0
--   BUILD_CAFFE2          : ON
--   BUILD_CAFFE2_OPS      : ON
--   BUILD_CAFFE2_MOBILE   : OFF
--   BUILD_STATIC_RUNTIME_BENCHMARK: OFF
--   BUILD_BINARY          : OFF
--   BUILD_CUSTOM_PROTOBUF : ON
--     Link local protobuf : ON
--   BUILD_DOCS            : OFF
--   BUILD_PYTHON          : True
--     Python version      : 3.8.9
--     Python executable   : /media/dji/80GBstore/pyenvs/newpy38/bin/python
--     Pythonlibs version  : 3.8.9
--     Python library      : /usr/lib/libpython3.8.so.1.0
--     Python includes     : /usr/include/python3.8
--     Python site-packages: lib/python3.8/site-packages
--   BUILD_SHARED_LIBS     : ON
--   BUILD_TEST            : True
--   BUILD_JNI             : OFF
--   BUILD_MOBILE_AUTOGRAD : OFF
--   INTERN_BUILD_MOBILE   :
--   USE_ASAN              : OFF
--   USE_CPP_CODE_COVERAGE : OFF
--   USE_CUDA              : 1
--     CUDA static link    : OFF
--     USE_CUDNN           : 1
--     CUDA version        : 9.0
--     cuDNN version       : 7.4.2
--     CUDA root directory : /usr/local/cuda-9.0
--     CUDA library        : /usr/local/cuda-9.0/lib64/stubs/libcuda.so
--     cudart library      : /usr/local/cuda-9.0/lib64/libcudart.so
--     cublas library      : /usr/local/cuda-9.0/lib64/libcublas.so;/usr/local/cuda-9.0/lib64/libcublas_device.a
--     cufft library       : /usr/local/cuda-9.0/lib64/libcufft.so
--     curand library      : /usr/local/cuda-9.0/lib64/libcurand.so
--     cuDNN library       : /usr/local/cuda-9.0/lib64/libcudnn.so
--     nvrtc               : /usr/local/cuda-9.0/lib64/libnvrtc.so
--     CUDA include path   : /usr/local/cuda-9.0/include
--     NVCC executable     : /usr/local/cuda-9.0/bin/nvcc
--     NVCC flags          : -Xfatbin;-compress-all;-DONNX_NAMESPACE=onnx_torch;-gencode;arch=compute_62,code=sm_62;-Xcudafe;--diag_suppress=cc_clobber_ignored;-Xcudafe;--diag_suppress=integer_sign_change;-Xcudafe;--diag_suppress=useless_using_declaration;-Xcudafe;--diag_suppress=set_but_not_used;-Xcudafe;--diag_suppress=field_without_dll_interface;-Xcudafe;--diag_suppress=base_class_has_different_dll_interface;-Xcudafe;--diag_suppress=dll_interface_conflict_none_assumed;-Xcudafe;--diag_suppress=dll_interface_conflict_dllexport_assumed;-Xcudafe;--diag_suppress=implicit_return_from_non_void_function;-Xcudafe;--diag_suppress=unsigned_compare_with_zero;-Xcudafe;--diag_suppress=declared_but_not_referenced;-Xcudafe;--diag_suppress=bad_friend_decl;-std=c++14;-Xcompiler;-fPIC;--expt-relaxed-constexpr;--expt-extended-lambda;-Wno-deprecated-gpu-targets;--expt-extended-lambda;-Xcompiler;-fPIC;-DCUDA_HAS_FP16=1;-D__CUDA_NO_HALF_OPERATORS__;-D__CUDA_NO_HALF_CONVERSIONS__;-D__CUDA_NO_HALF2_OPERATORS__
--     CUDA host compiler  : /usr/bin/cc
--     NVCC --device-c     : OFF
--     USE_TENSORRT        : OFF
--   USE_ROCM              : OFF
--   USE_EIGEN_FOR_BLAS    : ON
--   USE_FBGEMM            : OFF
--     USE_FAKELOWP          : OFF
--   USE_FFMPEG            : OFF
--   USE_GFLAGS            : OFF
--   USE_GLOG              : OFF
--   USE_LEVELDB           : OFF
--   USE_LITE_PROTO        : OFF
--   USE_LMDB              : OFF
--   USE_METAL             : OFF
--   USE_MKL               : OFF
--   USE_MKLDNN            : OFF
--   USE_NCCL              : 0
--   USE_NNPACK            : ON
--   USE_NUMPY             : ON
--   USE_OBSERVERS         : ON
--   USE_OPENCL            : OFF
--   USE_OPENCV            : ON
--     OpenCV version      : 4.5.4
--   USE_OPENMP            : ON
--   USE_TBB               : OFF
--   USE_VULKAN            : OFF
--   USE_PROF              : OFF
--   USE_QNNPACK           : ON
--   USE_PYTORCH_QNNPACK   : ON
--   USE_REDIS             : OFF
--   USE_ROCKSDB           : OFF
--   USE_ZMQ               : OFF
--   USE_DISTRIBUTED       : 1
--     USE_MPI             : ON
--     USE_GLOO            : ON
--     USE_TENSORPIPE      : ON
--   Public Dependencies  : Threads::Threads
--   Private Dependencies : pthreadpool;cpuinfo;qnnpack;pytorch_qnnpack;nnpack;XNNPACK;/usr/lib/aarch64-linux-gnu/libnuma.so;opencv_core;opencv_highgui;opencv_imgproc;opencv_imgcodecs;opencv_optflow;opencv_videoio;opencv_video;fp16;/usr/lib/openmpi/lib/libmpi_cxx.so;/usr/lib/openmpi/lib/libmpi.so;gloo;tensorpipe;aten_op_header_gen;foxi_loader;rt;fmt::fmt-header-only;gcc_s;gcc;dl
-- Configuring done
-- Generating done
-- Build files have been written to: /media/dji/80GBstore/pyenvs/newpy38/pytorch/build
cmake --build . --target install --config Release -- -j 6
[  0%] Building C object confu-deps/pthreadpool/CMakeFiles/pthreadpool.dir/src/legacy-api.c.o
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/any_lite.cc.o
[  0%] Building CXX object third_party/googletest/googlemock/gtest/CMakeFiles/gtest.dir/src/gtest-all.cc.o
[  0%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/benchmark.cc.o
[  0%] Building C object confu-deps/cpuinfo/deps/clog/CMakeFiles/clog.dir/src/clog.c.o
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/any_lite.cc.o
In file included from /media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:8:0:
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/include/pthreadpool.h:997:2: warning: ‘pthreadpool_function_1d_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_1d_t function,
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/include/pthreadpool.h:1003:2: warning: ‘pthreadpool_function_1d_tiled_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_1d_tiled_t function,
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/include/pthreadpool.h:1010:2: warning: ‘pthreadpool_function_2d_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_2d_t function,
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/include/pthreadpool.h:1017:2: warning: ‘pthreadpool_function_2d_tiled_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_2d_tiled_t function,
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/include/pthreadpool.h:1026:2: warning: ‘pthreadpool_function_3d_tiled_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_3d_tiled_t function,
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/include/pthreadpool.h:1037:2: warning: ‘pthreadpool_function_4d_tiled_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_4d_tiled_t function,
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:16:2: warning: ‘pthreadpool_function_1d_t’ is deprecated [-Wdeprecated-declarations]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:27:2: warning: ‘pthreadpool_function_1d_tiled_t’ is deprecated [-Wdeprecated-declarations]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:39:2: warning: ‘pthreadpool_function_2d_t’ is deprecated [-Wdeprecated-declarations]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:51:2: warning: ‘pthreadpool_function_2d_tiled_t’ is deprecated [-Wdeprecated-declarations]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:64:2: warning: ‘pthreadpool_function_3d_tiled_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_3d_tiled_t function;
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:95:2: warning: ‘pthreadpool_function_3d_tiled_t’ is deprecated [-Wdeprecated-declarations]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:138:2: warning: ‘pthreadpool_function_4d_tiled_t’ is deprecated [-Wdeprecated-declarations]
  pthreadpool_function_4d_tiled_t function;
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/legacy-api.c:177:2: warning: ‘pthreadpool_function_4d_tiled_t’ is deprecated [-Wdeprecated-declarations]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c: In function ‘clog_vlog_fatal’:
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c:112:4: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
    write(STDERR_FILENO, out_buffer, prefix_chars + format_chars + CLOG_SUFFIX_LENGTH);
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c: In function ‘clog_vlog_error’:
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c:188:4: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c: In function ‘clog_vlog_warning’:
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c:264:4: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c: In function ‘clog_vlog_info’:
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c:340:4: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
    write(STDOUT_FILENO, out_buffer, prefix_chars + format_chars + CLOG_SUFFIX_LENGTH);
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c: In function ‘clog_vlog_debug’:
/media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/cpuinfo/deps/clog/src/clog.c:416:4: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
[  0%] Linking C static library ../../../../lib/libclog.a
[  0%] Building C object confu-deps/pthreadpool/CMakeFiles/pthreadpool.dir/src/portable-api.c.o
[  0%] Built target clog
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/arena.cc.o
In file included from /media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/portable-api.c:16:0:
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/arena.cc.o
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/extension_set.cc.o
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/extension_set.cc.o
[  0%] Building C object confu-deps/pthreadpool/CMakeFiles/pthreadpool.dir/src/memory.c.o
In file included from /media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/threadpool-object.h:30:0,
                 from /media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/memory.c:19:
[  0%] Building C object confu-deps/pthreadpool/CMakeFiles/pthreadpool.dir/src/pthreads.c.o
In file included from /media/dji/80GBstore/pyenvs/newpy38/pytorch/third_party/pthreadpool/src/pthreads.c:50:0:
[  0%] Linking C static library ../../lib/libpthreadpool.a
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/generated_enum_util.cc.o
[  0%] Built target pthreadpool
[  0%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/generated_message_table_driven_lite.cc.o
[  0%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/benchmark_register.cc.o
[  0%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/algorithm.cc.o
[  0%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/allgather.cc.o
[  0%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/allgatherv.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/colorprint.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/generated_enum_util.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/generated_message_table_driven_lite.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/generated_message_util.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/generated_message_util.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/allreduce.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/commandlineflags.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/allreduce_local.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/implicit_weak_message.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/complexity.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/console_reporter.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/alltoall.cc.o
[  1%] Linking CXX static library ../../../../lib/libgtest.a
[  1%] Built target gtest
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/counter.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/io/coded_stream.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/csv_reporter.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/alltoallv.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/barrier.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/broadcast.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/implicit_weak_message.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/coded_stream.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/io/io_win32.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/json_reporter.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/io/strtod.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/io/zero_copy_stream.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/io/zero_copy_stream_impl.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/reporter.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/fs-poll.c.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/context.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/idna.c.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/io_win32.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/strtod.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/inet.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/random.c.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/sleep.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/statistics.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/io/zero_copy_stream_impl_lite.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/strscpy.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/threadpool.c.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/zero_copy_stream.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/timer.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/uv-common.c.o
[  1%] Building CXX object third_party/fmt/CMakeFiles/fmt.dir/src/format.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/gather.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/zero_copy_stream_impl.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/message_lite.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/uv-data-getter-setters.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/version.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/async.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/core.c.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/gatherv.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/zero_copy_stream_impl_lite.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/string_util.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/dl.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/fs.c.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/message_lite.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/parse_context.cc.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/sysinfo.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/getaddrinfo.c.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/reduce.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/getnameinfo.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/loop-watcher.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/loop.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/pipe.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/poll.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/process.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/random-devurandom.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/signal.c.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/parse_context.cc.o
[  1%] Building CXX object third_party/fmt/CMakeFiles/fmt.dir/src/os.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/scatter.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/stream.c.o
[  1%] Building CXX object third_party/benchmark/src/CMakeFiles/benchmark.dir/timers.cc.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/repeated_field.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/tcp.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/thread.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/tty.c.o
[  1%] Linking CXX shared library ../../lib/libfmt.so
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/udp.c.o
[  1%] Built target fmt
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/proctitle.c.o
[  1%] Linking CXX static library ../../../lib/libbenchmark.a
[  1%] Built target benchmark
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/linux-core.c.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/types.cc.o
[  1%] Building CXX object c10/CMakeFiles/c10.dir/core/Allocator.cpp.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/linux-inotify.c.o
[  1%] Building CXX object c10/CMakeFiles/c10.dir/core/CPUAllocator.cpp.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/common/logging.cc.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/linux-syscalls.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/procfs-exepath.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/random-getrandom.c.o
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/random-sysctl-linux.c.o
[  1%] Building C object third_party/foxi/CMakeFiles/foxi_loader.dir/foxi/onnxifi_loader.c.o
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/repeated_field.cc.o
[  1%] Linking C static library ../../lib/libfoxi_loader.a
[  1%] Building C object third_party/tensorpipe/tensorpipe/CMakeFiles/tensorpipe_uv.dir/__/third_party/libuv/src/unix/sysinfo-loadavg.c.o
[  1%] Built target foxi_loader
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/bytestream.cc.o
[  1%] Linking C static library ../../../lib/libtensorpipe_uv.a
[  1%] Built target tensorpipe_uv
[  1%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/common.cc.o
[  1%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/common/linux.cc.o
[  2%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/mpi/context.cc.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/bytestream.cc.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/int128.cc.o
[  2%] Building CXX object c10/CMakeFiles/c10.dir/core/CopyBytes.cpp.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/common.cc.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/int128.cc.o
[  2%] Building CXX object c10/CMakeFiles/c10.dir/core/DefaultDtype.cpp.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/status.cc.o
[  2%] Building CXX object c10/CMakeFiles/c10.dir/core/Device.cpp.o
[  2%] Building CXX object c10/CMakeFiles/c10.dir/core/DeviceType.cpp.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/status.cc.o
[  2%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/rendezvous/context.cc.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/statusor.cc.o
[  2%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/rendezvous/file_store.cc.o
[  2%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/rendezvous/hash_store.cc.o
[  2%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/stringpiece.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/statusor.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/stringpiece.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/stringprintf.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/stringprintf.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/structurally_valid.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/rendezvous/prefix_store.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/rendezvous/store.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/address.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/structurally_valid.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/DispatchKey.cpp.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/DispatchKeySet.cpp.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/strutil.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/strutil.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/buffer.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/context.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/device.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/pair.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/stubs/time.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/GeneratorImpl.cpp.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/unbound_buffer.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/tcp/address.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/tcp/buffer.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/tcp/context.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/Scalar.cpp.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf-lite.dir/__/src/google/protobuf/wire_format_lite.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/time.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/wire_format_lite.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/Storage.cpp.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/StorageImpl.cpp.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/Stream.cpp.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/tcp/device.cc.o
[  3%] Linking CXX static library ../../../lib/libprotobuf-lite.a
[  3%] Built target libprotobuf-lite
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/tcp/loop.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/tcp/pair.cc.o
[  3%] Building CXX object third_party/gloo/gloo/CMakeFiles/gloo.dir/transport/tcp/unbound_buffer.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/TensorImpl.cpp.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/any.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/TensorOptions.cpp.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/any.pb.cc.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/api.pb.cc.o
[  3%] Generating ../aten/src/ATen/BackendSelectRegister.cpp, ../aten/src/ATen/CPUType.cpp, ../aten/src/ATen/CPUType.h, ../aten/src/ATen/Declarations.yaml, ../aten/src/ATen/Functions.cpp, ../aten/src/ATen/Functions.h, ../aten/src/ATen/MkldnnCPUType.cpp, ../aten/src/ATen/MkldnnCPUType.h, ../aten/src/ATen/NativeFunctions.h, ../aten/src/ATen/QuantizedCPUType.cpp, ../aten/src/ATen/QuantizedCPUType.h, ../aten/src/ATen/RegistrationDeclarations.h, ../aten/src/ATen/SparseCPUType.cpp, ../aten/src/ATen/SparseCPUType.h, ../aten/src/ATen/TypeDefault.cpp, ../aten/src/ATen/TypeDefault.h, ../aten/src/ATen/CUDAType.cpp, ../aten/src/ATen/CUDAType.h, ../aten/src/ATen/QuantizedCUDAType.cpp, ../aten/src/ATen/QuantizedCUDAType.h, ../aten/src/ATen/SparseCUDAType.cpp, ../aten/src/ATen/SparseCUDAType.h, ../aten/src/ATen/core/ATenOpList.cpp, ../aten/src/ATen/core/TensorBody.h, ../aten/src/ATen/core/TensorMethods.cpp
[  3%] Building C object sleef/src/common/CMakeFiles/common.dir/common.c.o
[  3%] Building C object sleef/src/libm/CMakeFiles/mkalias.dir/mkalias.c.o
[  3%] Built target common
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/UndefinedTensorImpl.cpp.o
[  3%] Linking C executable ../../bin/mkalias
[  3%] Built target mkalias
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/compiler/importer.cc.o
[  3%] Linking CXX static library ../../../lib/libgloo.a
[  3%] Built target gloo
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/compiler/parser.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/impl/DeviceGuardImplInterface.cpp.o
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/descriptor.cc.o
[  3%] Building C object sleef/src/libm/CMakeFiles/mkrename.dir/mkrename.c.o
[  3%] Linking C executable ../../bin/mkrename
[  3%] Built target mkrename
[  3%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/descriptor.pb.cc.o
[  3%] Building CXX object c10/CMakeFiles/c10.dir/core/impl/LocalDispatchKeySet.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/core/thread_pool.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/mobile/CPUCachingAllocator.cpp.o
[  4%] Building CXX object caffe2/CMakeFiles/caffe2_nvrtc.dir/__/aten/src/ATen/cuda/nvrtc_stub/ATenNVRTC.cpp.o
[  4%] Linking CXX shared library ../lib/libcaffe2_nvrtc.so
[  4%] Built target caffe2_nvrtc
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/descriptor_database.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Array.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Backtrace.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/C++17.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Exception.cpp.o
[  4%] Building C object caffe2/CMakeFiles/torch_global_deps.dir/__/torch/csrc/empty.c.o
[  4%] Linking C shared library ../lib/libtorch_global_deps.so
/usr/local/cuda-9.0/lib64/libcudnn.so: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
caffe2/CMakeFiles/torch_global_deps.dir/build.make:105: recipe for target 'lib/libtorch_global_deps.so' failed
make[2]: *** [lib/libtorch_global_deps.so] Error 1
CMakeFiles/Makefile2:5307: recipe for target 'caffe2/CMakeFiles/torch_global_deps.dir/all' failed
make[1]: *** [caffe2/CMakeFiles/torch_global_deps.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/duration.pb.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Half.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/LeftRight.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Logging.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Metaprogramming.cpp.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/dynamic_message.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/empty.pb.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Optional.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/SmallVector.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/StringUtil.cpp.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/extension_set_heavy.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/ThreadLocalDebugInfo.cpp.o
[  4%] Built target ATEN_CPU_FILES_GEN_TARGET
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/field_mask.pb.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/generated_message_reflection.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/Type.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/TypeList.cpp.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/generated_message_table_driven.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/TypeTraits.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/UniqueVoidPtr.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/flags_use_gflags.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/flags_use_no_gflags.cpp.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/gzip_stream.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/intrusive_ptr.cpp.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/printer.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/io/tokenizer.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/numa.cpp.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/thread_name.cpp.o
[  4%] Built target ATEN_CUDA_FILES_GEN_TARGET
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/map_field.cc.o
[  4%] Building CXX object c10/CMakeFiles/c10.dir/util/typeid.cpp.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/message.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/reflection_ops.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/service.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/source_context.pb.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/struct.pb.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/stubs/substitute.cc.o
[  4%] Linking CXX shared library ../lib/libc10.so
[  4%] Built target c10
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/text_format.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/timestamp.pb.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/type.pb.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/unknown_field_set.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/delimited_message_util.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/field_comparator.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/field_mask_util.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/datapiece.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/default_value_objectwriter.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/error_listener.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/field_mask_utility.cc.o
[  4%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/json_escaping.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/json_objectwriter.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/json_stream_parser.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/object_writer.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/proto_writer.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/protostream_objectsource.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/protostream_objectwriter.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/type_info.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/type_info_test_helper.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/internal/utility.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/json_util.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/message_differencer.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/time_util.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/util/type_resolver_util.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/wire_format.cc.o
[  5%] Building CXX object third_party/protobuf/cmake/CMakeFiles/libprotobuf.dir/__/src/google/protobuf/wrappers.pb.cc.o
[  5%] Linking CXX static library ../../../lib/libprotobuf.a
[  5%] Built target libprotobuf
Makefile:145: recipe for target 'all' failed
make: *** [all] Error 2
  File "setup.py", line 760, in <module>
    build_deps()
  File "setup.py", line 310, in build_deps
    build_caffe2(version=version,
  File "/media/dji/80GBstore/pyenvs/newpy38/pytorch/tools/build_pytorch_libs.py", line 62, in build_caffe2
    cmake.build(my_env)
  File "/media/dji/80GBstore/pyenvs/newpy38/pytorch/tools/setup_helpers/cmake.py", line 345, in build
    self.run(build_args, my_env)
  File "/media/dji/80GBstore/pyenvs/newpy38/pytorch/tools/setup_helpers/cmake.py", line 141, in run
    check_call(command, cwd=self.build_dir, env=env)
  File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['cmake', '--build', '.', '--target', 'install', '--config', 'Release', '--', '-j', '6']' returned non-zero exit status 2.
Apologies it is vey long
