Hello. When I do inference of license plate detection in the tao_deploy.ipynb notebook, I got an error message as follow: ValueError: axes don’t match array.
How should I do to deal with the problem ?
My TensorRT version is 8.5.1.7 and python version is 3.8.10
The contents below are the error message of license plate detection inference
Running inference for LicensePlateDetection on /root/nvidia-tao/tao_deploy/trt_out_folderLicensePlateDetection/LicensePlateDetection.trt.fp32
Loading uff directly from the package source code
[03/26/2023-18:15:08] [TRT] [W] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars
[03/26/2023-18:15:08] [TRT] [W] The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
Producing predictions: 0%| | 0/1 [00:00<?, ?it/s][03/26/2023-18:15:08] [TRT] [W] The enqueue() method has been deprecated when used with engines built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. Please use enqueueV2() instead.
[03/26/2023-18:15:08] [TRT] [W] Also, the batchSize argument passed into this function has no effect on changing the input shapes. Please use setBindingDimensions() function to change input shapes instead.
File "</usr/local/lib/python3.8/dist-packages/nvidia_tao_deploy/cv/detectnet_v2/scripts/inference.py>", line 3, in <module>
File "<frozen cv.detectnet_v2.scripts.inference>", line 169, in <module>
File "<frozen cv.detectnet_v2.scripts.inference>", line 85, in main
File "<frozen cv.detectnet_v2.inferencer>", line 136, in infer
File "<frozen cv.detectnet_v2.inferencer>", line 37, in trt_output_process_fn
ValueError: axes don't match array
2023-03-26 18:15:09,328 [INFO] nvidia_tao_deploy.cv.common.entrypoint.entrypoint_proto: Sending telemetry data.
2023-03-26 18:15:09,359 [WARNING] nvidia_tao_deploy.cv.common.entrypoint.entrypoint_proto: Telemetry data couldn't be sent, but the command ran successfully.
2023-03-26 18:15:09,359 [WARNING] nvidia_tao_deploy.cv.common.entrypoint.entrypoint_proto: [Error]: <urlopen error [Errno -2] Name or service not known>
2023-03-26 18:15:09,359 [WARNING] nvidia_tao_deploy.cv.common.entrypoint.entrypoint_proto: Execution status: FAIL
if ptm_model_name in ("VehicleMakeNet", "VehicleTypeNet"):
The contents below are the infer spec file
inferencer_config{
# defining target class names for the experiment.
# Note: This must be mentioned in order of the networks classes.
target_classes: "lpd"
# Inference dimensions.
image_width: 640
image_height: 480
# Must match what the model was trained for.
image_channels: 3
batch_size: 16
gpu_index: 0
stride: 16
# model handler config
tensorrt_config{
parser: ETLT
etlt_model: "lpd.etlt"
backend_data_type: INT8
save_engine: true
trt_engine: "lpd.trt"
calibrator_config: {
calibration_cache: "lpd.cache"
bbox_handler_config{
kitti_dump: true
disable_overlay: false
overlay_linewidth: 2
classwise_bbox_handler_config{
key:"lpd"
value: {
confidence_model: "aggregate_cov"
output_map: "lpd"
bbox_color{
R: 255
G: 0
B: 0
clustering_config{
coverage_threshold: 0.00
clustering_algorithm: DBSCAN
dbscan_confidence_threshold: 0.9
dbscan_eps: 0.3
dbscan_min_samples: 0.05
minimum_bounding_box_height: 4
key:"default"
value: {
bbox_color{
R: 0
G: 255
B: 0
clustering_config{
coverage_threshold: 0.005
dbscan_eps: 0.3
The content below is command of run inference
if ptm_model_name in ("PeopleNet","LicensePlateDetection","DashCamNet","TrafficCamNet","FaceDetect","FaceDetectIR"):
action = "_infer"
os.environ["inference_experiment_spec"] = f"{os.environ.get('COLAB_NOTEBOOKS_PATH')}/tao_deploy/specs/{ptm_model_name}/{ptm_model_name}{action}.txt"
# FIXME 10 - inference_out_folder: Folder path to write the inference results to
os.environ["inference_out_folder"] = "/root/nvidia-tao/tao_deploy/tao_ptm_inference/"
!rm -rf $inference_out_folder
# FIXME 11 - inference_input_images_folder: Folder path containing images to run the inference on
os.environ["inference_input_images_folder"] = f"/root/nvidia-tao/tao_deploy/tao_deploy_input_images/{ptm_model_name}"
print(f"Running inference for {ptm_model_name} on {os.environ['trt_out_file_name']}")
!detectnet_v2 inference -e $inference_experiment_spec \
-m $trt_out_file_name \
-r $inference_out_folder \
-i $inference_input_images_folder
