GPU
• DeepStream Version
DeepStream 6.0
Driver Version: 470.103.01
Hi.
I am running the following pipeline for license plate recognition:
uridecodebin -> nvstreammux -> primary nvinfer (car detection) -> nvtracker -> secondary nvinfer (license plate detection) -> nvdspreprocess -> primary nvinfer (OCR on tensor input) -> nvmultistreamtiler -> nvvideoconvert -> nvdsosd -> nveglglessink
I added nvdspreprocess element as I would like to do some pre-processing on license plates in the future (perspective correction), as suggested here. I added some changes to gstnvdspreprocess.cpp to change the ROI in runtime to be the detected object from previous model (license plate) instead of full frame. I can see the ROIs fine on the display.
The thing is, the pipeline works fine (exactly as in the deepstream LPR example) until I add the pre-process element. In other words, I get meaningful output on the display, but when I add the preprocess element and change the OCR model to primary model, I get no output from it (no character labels). Even though the custom parser interface for OCR, NvDsInferParseCustomNVPlate
, is being invoked and returning meaningful values (I was able to print license plate characters during runtime but not display them).
primary infer element config (car detector)
car_detect_config.txt (809 Bytes) -
secondary infer element config (license plate detector)
lp_detect_config.txt (894 Bytes) -
pre-process element config
[property]
enable=1
gpu-id=0
unique-id=3
# should be same as model gie id (don't know why)
target-unique-ids=4
# 0=NCHW, 1=NHWC, 2=CUSTOM
network-input-order=0
processing-width=96
processing-height=48
scaling-buf-pool-size=6
tensor-buf-pool-size=6
# tensor shape based on network-input-order
network-input-shape= 2;3;48;96
# 0=RGB, 1=BGR, 2=GRAY
network-color-format=0
# 0=FP32, 1=UINT8, 2=INT8, 3=UINT32, 4=INT32, 5=FP16
tensor-data-type=0
tensor-name=image_input
# 0=NVBUF_MEM_DEFAULT 1=NVBUF_MEM_CUDA_PINNED 2=NVBUF_MEM_CUDA_DEVICE 3=NVBUF_MEM_CUDA_UNIFIED
scaling-pool-memory-type=0
# 0=NvBufSurfTransformCompute_Default 1=NvBufSurfTransformCompute_GPU 2=NvBufSurfTransformCompute_VIC
scaling-pool-compute-hw=1
# Scaling Interpolation method
# 0=NvBufSurfTransformInter_Nearest 1=NvBufSurfTransformInter_Bilinear 2=NvBufSurfTransformInter_Algo1
# 3=NvBufSurfTransformInter_Algo2 4=NvBufSurfTransformInter_Algo3 5=NvBufSurfTransformInter_Algo4
# 6=NvBufSurfTransformInter_Default
scaling-filter=0
custom-lib-path=../../gst-nvdspreprocess/nvdspreprocess_lib/libcustom2d_preprocess.so
custom-tensor-preparation-function=CustomTensorPreparation
[user-configs]
pixel-normalization-factor=0.00392156862745098
[group-0]
src-ids=0
custom-input-transformation-function=CustomAsyncTransformation
process-on-roi=0
roi-params-src-0=0;0;200;200
[group-1]
src-ids=1
process-on-roi=0
roi-params-src-1=350;200;300;100
- primary nvinfer config (OCR) (I already set the input-tensor-meta boolean to true)
[property]
gie-unique-id=4
#operate-on-gie-id=3
#operate-on-class-ids=0
output-tensor-meta=1
process-mode=1
#force-implicit-batch-dim=1
gpu-id=0
model-engine-file=models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b2_gpu0_fp32.engine
labelfile-path=models/LP/LPR/labels_us.txt
tlt-encoded-model=models/LP/LPR/us_lprnet_baseline18_deployable.etlt
tlt-model-key=nvidia_tlt
#output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
batch-size=2
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=3
#0=Detection 1=Classifier 2=Segmentation
network-type=1
parse-classifier-func-name=NvDsInferParseCustomNVPlate
custom-lib-path=nvinfer_custom_lpr_parser/libnvdsinfer_custom_impl_lpr.so
net-scale-factor=0.00392156862745098
#0=RGB 1=BGR 2=GRAY
model-color-format=0
[class-attrs-all]
threshold=0.5
What could I possibly be missing here? Thanks.
