• Hardware Platform (Jetson / GPU) GPU Tesla T4
• DeepStream Version 5.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 450.119.03
• Issue Type( questions, new requirements, bugs) questions, (bugs?)
deepstream-ssd-parser sample app. Trying to add secondary inference (a multi-label classifier using nvinferserver) on primary detection objects. The pipeline works i.e. no issues with model loading and running the pipeline. But not able to get any classifier objects on using a probe function at either sgie source or nvvidconv sink (next element). The obj_meta.obj_user_meta_list is always None. My probe function -
def sgie1_src_pad_buffer_probe(pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
l_obj = frame_meta.obj_meta_list
count = frame_meta.num_obj_meta
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
l_class = obj_meta.obj_user_meta_list
print(l_class)
while l_class is not None:
l_user = pyds.NvDsUserMeta.cast(l_class.data)
if (
l_user.base_meta.meta_type
!= pyds.NvDsMetaType.NVDSINFER_TENSOR_OUTPUT_META
continue
tensor_meta = pyds.NvDsInferTensorMeta.cast(l_user.user_meta_data)
layers_info = []
for i in range(tensor_meta.num_output_layers):
layer = pyds.get_nvds_LayerInfo(tensor_meta, i)
layers_info.append(layer)
frame_object_list = nvds_infer_parse_custom_tf(layers_info, count)
for frame_object in frame_object_list:
add_classifier_obj_meta_to_frame(frame_object, batch_meta, obj_meta)
try:
l_class = l_class.next
break
try:
l_obj = l_obj.next
break
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
My pipeline-
streammux.link(queue1)
queue1.link(pgie)
pgie.link(sgie1)
sgie1.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(queue5)
queue5.link(nvvidconv2)
nvvidconv2.link(capsfilter)
capsfilter.link(encoder)
encoder.link(codeparser)
codeparser.link(container)
container.link(sink)
Same probe function I have tried while keeping peoplenet TLT model as the primary inference using nvinfer and it works great, I get the output tensors of the classifier model.
Is this some issue when we add object meta to frame as it is there in the deepstream-ssd-parser example and this object does not go as input to the secondary classifier?
I am confused here, whether secondary inference is happening at all as I am not getting any errors anywhere but also can’t read the output.
