How to use metadata from the secondary classifier in Python
I am developing a system that uses an object detection model as the primary detector and an image classifier as the secondary classifier. I am taking “deepstream_test_2.py” as reference . The system displays the inference information from both models on the screen. Using the nvanalytics.get_static_pad(“src”) I can read the information from the primary detector. However, I cannot read the information from the secondary classifier. I am trying to read using “obj_meta.parent.class_id” but it is empty.
I linked the pipeline elements as follows:
streammux.link(queue1)
queue1.link(pgie)
pgie.link(queue2)
queue2.link(tracker)
tracker.link(queue3)
queue3.link(sgie1)
sgie1.link(queue4)
queue4.link(nvanalytics)
nvanalytics.link(queue5)
queue5.link(tiler)
tiler.link(queue6)
queue6.link(nvvidconv)
nvvidconv.link(queue7)
queue7.link(nvosd)
I appreciate your help.
• DeepStream Version
• TensorRT Version
Jetson AGX Xavier
Deepstream 6
Jetpack 4.6
• TensorRT Version
Tensor 8
Question
deepstream-nvdsanalytics
and
deepstream-test2
To reproduce the issue, please use the sample “deepstream-nvdsanalytics” from deepstream_python_apps , replace the following source code into the deepstream-nvdsanalytics.py file, and copy the file “dstest2_sgie1_config.txt” from the sample folder “deepstream-test2” to
“deepstream-nvdsanalytics”.
To run the code please use:
python3 deepstream_nvdsanalytics.py file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4
#!/usr/bin/env python3
import sys
sys.path.append('../')
import gi
import configparser
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
from gi.repository import GLib
from ctypes import *
import time
import sys
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import GETFPS
import pyds
fps_streams={}
MAX_DISPLAY_LEN=64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=1080
MUXER_BATCH_TIMEOUT_USEC=4000000
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
GST_CAPS_FEATURES_NVMM="memory:NVMM"
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
def nvanalytics_src_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame:
        try:
        except StopIteration:
            break
        frame_number=frame_meta.frame_num
        l_obj=frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        obj_counter = {
        PGIE_CLASS_ID_VEHICLE:0,
        PGIE_CLASS_ID_PERSON:0,
        PGIE_CLASS_ID_BICYCLE:0,
        PGIE_CLASS_ID_ROADSIGN:0
        print("#"*50)
        while l_obj:
            try:
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            # Here, I tried to extract meta data from the secondary model
            try:
                print(obj_meta.parent.class_id)
                print("Error")
            obj_counter[obj_meta.class_id] += 1
            l_user_meta = obj_meta.obj_user_meta_list
            while l_user_meta:
                try:
                    user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
                    if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSOBJ.USER_META"):
                        user_meta_data = pyds.NvDsAnalyticsObjInfo.cast(user_meta.user_meta_data)
                        if user_meta_data.dirStatus: print("Object {0} moving in direction: {1}".format(obj_meta.object_id, user_meta_data.dirStatus))
                        if user_meta_data.lcStatus: print("Object {0} line crossing status: {1}".format(obj_meta.object_id, user_meta_data.lcStatus))
                        if user_meta_data.ocStatus: print("Object {0} overcrowding status: {1}".format(obj_meta.object_id, user_meta_data.ocStatus))
                        if user_meta_data.roiStatus: print("Object {0} roi status: {1}".format(obj_meta.object_id, user_meta_data.roiStatus))
                    break
                try:
                    l_user_meta = l_user_meta.next
                    break
            try:
                l_obj=l_obj.next
                break
        l_user = frame_meta.frame_user_meta_list
        while l_user:
            try:
                user_meta = pyds.NvDsUserMeta.cast(l_user.data)
                if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META"):
                    user_meta_data = pyds.NvDsAnalyticsFrameMeta.cast(user_meta.user_meta_data)
                    if user_meta_data.objInROIcnt: print("Objs in ROI: {0}".format(user_meta_data.objInROIcnt))
                    if user_meta_data.objLCCumCnt: print("Linecrossing Cumulative: {0}".format(user_meta_data.objLCCumCnt))
                    if user_meta_data.objLCCurrCnt: print("Linecrossing Current Frame: {0}".format(user_meta_data.objLCCurrCnt))
                    if user_meta_data.ocStatus: print("Overcrowding status: {0}".format(user_meta_data.ocStatus))
                break
            try:
                l_user = l_user.next
                break
        print("Frame Number=", frame_number, "stream id=", frame_meta.pad_index, "Number of Objects=",num_rects,"Vehicle_count=",obj_counter[PGIE_CLASS_ID_VEHICLE],"Person_count=",obj_counter[PGIE_CLASS_ID_PERSON])
        fps_streams["stream{0}".format(frame_meta.pad_index)].get_fps()
        try:
            l_frame=l_frame.next
            break
        print("#"*50)
    return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad,data):
    print("In cb_newpad\n")
    caps=decoder_src_pad.get_current_caps()
    gststruct=caps.get_structure(0)
    gstname=gststruct.get_name()
    source_bin=data
    features=caps.get_features(0)
    print("gstname=",gstname)
    if(gstname.find("video")!=-1):
        print("features=",features)
        if features.contains("memory:NVMM"):
            bin_ghost_pad=source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
    print("Decodebin child added:", name, "\n")
    if(name.find("decodebin") != -1):
        Object.connect("child-added",decodebin_child_added,user_data)
def create_source_bin(index,uri):
    print("Creating source bin")
    bin_name="source-bin-%02d" %index
    print(bin_name)
    nbin=Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    uri_decode_bin.set_property("uri",uri)
    uri_decode_bin.connect("pad-added",cb_newpad,nbin)
    uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
    Gst.Bin.add(nbin,uri_decode_bin)
    bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def main(args):
    if len(args) < 2:
        sys.stderr.write("usage: %s <uri1> [uri2] ... [uriN]\n" % args[0])
        sys.exit(1)
    for i in range(0,len(args)-1):
        fps_streams["stream{0}".format(i)]=GETFPS(i)
    number_sources=len(args)-1
    GObject.threads_init()
    Gst.init(None)
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ",i," \n ")
        uri_name=args[i+1]
        if uri_name.find("rtsp://") == 0 :
            is_live = True
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    queue1=Gst.ElementFactory.make("queue","queue1")
    queue2=Gst.ElementFactory.make("queue","queue2")
    queue3=Gst.ElementFactory.make("queue","queue3")
    queue4=Gst.ElementFactory.make("queue","queue4")
    queue5=Gst.ElementFactory.make("queue","queue5")
    queue6=Gst.ElementFactory.make("queue","queue6")
    queue7=Gst.ElementFactory.make("queue","queue7")
    # I added an additional query
    queue8=Gst.ElementFactory.make("queue","queue8")
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(queue3)
    pipeline.add(queue4)
    pipeline.add(queue5)
    pipeline.add(queue6)
    pipeline.add(queue7)
    pipeline.add(queue8)
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    print("Creating nvtracker \n ")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    #I added the secondary model
    sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie1 \n")
    print("Creating nvdsanalytics \n ")
    nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
    if not nvanalytics:
        sys.stderr.write(" Unable to create nvanalytics \n")
    nvanalytics.set_property("config-file", "config_nvdsanalytics.txt")
    print("Creating tiler \n ")
    tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvosd.set_property('process-mode',OSD_PROCESS_MODE)
    nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
    if(is_aarch64()):
        print("Creating transform \n ")
        transform=Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
        if not transform:
            sys.stderr.write(" Unable to create transform \n")
    print("Creating EGLSink \n")
    sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
    if not sink:
        sys.stderr.write(" Unable to create egl sink \n")
    if is_live:
        print("Atleast one of the sources is live")
        streammux.set_property('live-source', 1)
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', "dsnvanalytics_pgie_config.txt")
    pgie_batch_size=pgie.get_property("batch-size")
    if(pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
        pgie.set_property("batch-size",number_sources)
    tiler_rows=int(math.sqrt(number_sources))
    tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
    tiler.set_property("rows",tiler_rows)
    tiler.set_property("columns",tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    sink.set_property("qos",0)
    #I added the secondary model from the new deepstream_test_2 sample
    sgie1.set_property('config-file-path', "dstest2_sgie1_config.txt")
    sgie1.set_property("unique-id",2)
    config = configparser.ConfigParser()
    config.read('dsnvanalytics_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config.getint('tracker', key)
            tracker.set_property('enable_batch_process', tracker_enable_batch_process)
        if key == 'enable-past-frame' :
            tracker_enable_past_frame = config.getint('tracker', key)
            tracker.set_property('enable_past_frame', tracker_enable_past_frame)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(sgie1)
    pipeline.add(nvanalytics)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    if is_aarch64():
        pipeline.add(transform)
    pipeline.add(sink)
    print("Linking elements in the Pipeline \n")
    queue1.link(pgie)
    pgie.link(queue2)
    #Added the queue and sgie1
    queue3.link(sgie1)
    sgie1.link(queue4)
    queue5.link(tiler)
    tiler.link(queue6)
    queue7.link(nvosd)
    if is_aarch64():
        nvosd.link(queue8)
        queue8.link(transform)
        transform.link(sink)
    else:
        nvosd.link(queue8)
        queue8.link(sink)
    loop = GObject.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    nvanalytics_src_pad=nvanalytics.get_static_pad("src")
    if not nvanalytics_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        nvanalytics_src_pad.add_probe(Gst.PadProbeType.BUFFER, nvanalytics_src_pad_buffer_probe, 0)
    print("Now playing...")
    for i, source in enumerate(args):
        if (i != 0):
            print(i, ": ", source)
    print("Starting pipeline \n")
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    sys.exit(main(sys.argv))
Note: My comments indicate which code was added to the original deepstream-nvdsanalytics.py
If the information can be displayed correctly, the OSD plugin get those information in the meta data. Can you have a try to check those meta data in the sink pad of OSD?
It is difficult to work with NVIDIA due to its vague information. I figured out the solution reading the bindings. I share the source code (based on Deepstream_test2.py) to someone else that have the same issue in the future:
while l_frame is not None:
    try:
        break
    while l_obj is not None:
        try:
            break
        class_obj=obj_meta.classifier_meta_list
        while class_obj is not None:
            try:
                class_meta=pyds.NvDsClassifierMeta.cast(class_obj.data)
                break
            c_obj=class_meta.label_info_list
            while c_obj is not None:
                try:
                    c_meta=pyds.NvDsLabelInfo.cast(c_obj.data)
                    break
                print(c_meta.result_label)
                try:
                    c_obj=c_obj.next
                    break
            try:
                class_obj=class_obj.next
                break
        try:
            l_obj=l_obj.next
            break
You found the solution. Great! Thanks for sharing.
