Hi, I just want to do some alarms infos in dstexample and send that with Messageconverter + Message broker sink.
But the order in deepstream would be two wayts with tee:
1)“Messageconverter + Message broker sink”
2) “dstexample”
It seems like the dstexample works like a sink.
How could I arrange dstexample and “Messageconverter + Message broker sink” in order?
bcao
3
dsexample is a filter plugin, why you think it’s a sink plugin?
Just to understand, you are attempting to add metadata to the buffer, which you then want to send with message broker?
Why do you need a separate element to do this? The deepstream reference application uses a probe function to add metadata to the buffer.
sry, I just rearrange the order of deexample, it works now.
Best wishes!
Yes, I want to use deepstream app to run the pipeline like:
primart=>track=>dstexample
||||=>msgconv+broke
||||=>rtsp
It’s a smalll mistake. thank you for the reply.
