If anyone could explain how to use the plugin in the message-broker section and how to configure GST-NVMSGCONV, that could be really helpful. Couldn’t find an example that will really be helpful.
thanks in advance.
thanks in advance.
Did you mean run test5 which use config file to parse the needed parameters? then you could first refer to README under the sample, which have a detailed usage. test4 sample should also be ok. any issue raised when run after, please let me know.
