Stream to kafka using deepstream
• DeepStream Version
• TensorRT Version
i saw deepstream binding apps test4 but it is different from my idea
hi i have a problem can help me in that?
my pipeline is like this : source → uridecode → mux → videoconv → osd → nvmsgconv → nvmsg broker
i want to get each frame with metadata from NVDSFrameMeta but i have some problems in nvmsgconv config file so how can i get frame (binarry or numpy or whatever) and NVDSFrameMeta to send with nvmsgbroker ! or should i say how nvmsgconv config file have to be to doing this ?
for the sake of clarity : if i can’t get one of them to send to kafka how can i get another one to send by kafka? or if i can get both how can i do that?
Thanks a Lot!.
• TensorRT Version
Deepstream 7
GPU T4
driver version : 525.183.01
trt : 8.6.1.6.1+cuda12.0
cuda : 12.2
how can i send frame by msgbroker with the pipeline that i sent earlier(send frame and deepstream meta
  1. about sending NVDSFrameMeta to broker, please refer to DeepStream ready-made sample deeptream-test4. when msg2p-newapi: 0, generate_event_msg_meta in osd_sink_pad_buffer_metadata_probe will add event message meta.
  2. about sending frame to broker, deeptream-test4 also supports sending the image to broker. please refer to “3.Send the image by the broker based on Kafka” in \opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-test4\README.
Thanks a lot
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
