How to send frames through Kafka
**• DeepStream Version ** 6.2
• TensorRT Version
How do I send frames through Kafka?
Right now, I extract RGBA numpy array and convert it into BGR, later encode it into json object along with the metadata to send to a kafka broker. Is there a better way?
i mean if there is any deepstream plugin that directly converts nvmm to bytes
Kafka( Apache Kafka) only support text messages. You need to customize the binary BGR data into text encoding by yourself. And you also need to customize the text to BGR data decoding in the Kafka server side to get the correct BGR data by yourself.
NVMM is a hardware buffer, there is no function or API to convert the content into text.
