I use the latest pgcpp under cygwin.
After successful compilation I get the following messages from the linker:
mriseg.obj : error LNK2019: unresolved external symbol _max__12Opt__tm__2_f referenced in function _Add__12Opt__tm__2_fSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _min__12Opt__tm__2_f referenced in function _Add__12Opt__tm__2_fSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _max__13Opt__tm__3_Uc referenced in function _Add__13Opt__tm__3_UcSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _min__13Opt__tm__3_Uc referenced in function _Add__13Opt__tm__3_UcSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _max__12Opt__tm__2_s referenced in function _Add__12Opt__tm__2_sSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _min__12Opt__tm__2_s referenced in function _Add__12Opt__tm__2_sSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _max__13Opt__tm__3_Us referenced in function _Add__13Opt__tm__3_UsSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _min__13Opt__tm__3_Us referenced in function _Add__13Opt__tm__3_UsSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _max__12Opt__tm__2_d referenced in function _Add__12Opt__tm__2_dSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _min__12Opt__tm__2_d referenced in function _Add__12Opt__tm__2_dSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _max__12Opt__tm__2_i referenced in function _Add__12Opt__tm__2_iSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _min__12Opt__tm__2_i referenced in function _Add__12Opt__tm__2_iSFRCfT1_Z1Z
mriseg.obj : error LNK2019: unresolved external symbol _max__28Opt__tm__17_14ZRGB__tm__3_Uc referenced in function ___sti___10_mriseg_cpp_bad592fd
mriseg.obj : error LNK2019: unresolved external symbol _min__28Opt__tm__17_14ZRGB__tm__3_Uc referenced in function ___sti___10_mriseg_cpp_bad592fd
mriseg.obj : error LNK2019: unresolved external symbol _max__27Opt__tm__16_13ZRGB__tm__2_s referenced in function ___sti___10_mriseg_cpp_bad592fd
mriseg.obj : error LNK2019: unresolved external symbol _min__27Opt__tm__16_13ZRGB__tm__2_s referenced in function ___sti___10_mriseg_cpp_bad592fd
mriseg.obj : error LNK2019: unresolved external symbol _max__27Opt__tm__16_13ZRGB__tm__2_f referenced in function ___sti___10_mriseg_cpp_bad592fd
mriseg.obj : error LNK2019: unresolved external symbol _min__27Opt__tm__16_13ZRGB__tm__2_f referenced in function ___sti___10_mriseg_cpp_bad592fd
mriseg.obj : error LNK2019: unresolved external symbol _max__28Opt__tm__17_14ZRGB__tm__3_Us referenced in function ___sti___10_mriseg_cpp_bad592fd
mriseg.obj : error LNK2019: unresolved external symbol _min__28Opt__tm__17_14ZRGB__tm__3_Us referenced in function ___sti___10_mriseg_cpp_bad592fd
C:\temp/pgcpp2apGobTbfJtDEe.exe : fatal error LNK1120: 20 unresolved externals
Is there any way to find out where these are coming from or to locate the calling functions given by the linker?
thank you
a_bra
