I have a question. After compiling my program i got these errors:
/tmp/tmpxft_00001d76_00000000-5.o: In function `calculate_parametric_sets':
tmpxft_00001d76_00000000-4.i:(.text+0x7576): undefined reference to `__vla_alloc'
tmpxft_00001d76_00000000-4.i:(.text+0x75b3): undefined reference to `__vla_alloc'
tmpxft_00001d76_00000000-4.i:(.text+0x75f0): undefined reference to `__vla_alloc'
tmpxft_00001d76_00000000-4.i:(.text+0x7a82): undefined reference to `__vla_dealloc'
tmpxft_00001d76_00000000-4.i:(.text+0x7a8e): undefined reference to `__vla_dealloc'
tmpxft_00001d76_00000000-4.i:(.text+0x7a9a): undefined reference to `__vla_dealloc'
collect2: ld returned 1 exit status
I think it has something to do with the allocation of memory but I don’t know that exactly. I hope some can help me with this problem
Here the code of calculate_parametric_sets
#include <stdio.h>
__global__ void calculate_parametric_sets(
float *alpha_x, float *alpha_y, float *alpha_z,
const float *delta_x, const float *delta_y, const float *delta_z,
const float *i_min, const float *j_min, const float *k_min,
const float *i_max, const float *j_max, const float *k_max,
const int *n_total_summed,
int gridY,
unsigned int blockSize_x, unsigned int blockSize_y, unsigned int offset_x, unsigned int offset_y
// set blockindex
int bx = blockIdx.x;
int by = blockIdx.y;
// set threadindex
int tx = threadIdx.x;
int ty = threadIdx.y;
// determine x, y and z pending on threadindex and blocksize
int i = (tx+offset_x) + (bx % gridY) * blockSize_x; // offset is used to tell which subblock will be calculated
int j = (ty+offset_y) + by * blockSize_y;
int k = floorf(bx / gridY);
// determine index of voxel
int index = i + (nx-1)*(j + k *(ny-1));
__shared__ float dx_inv_deltax;
__shared__ float dy_inv_deltay;
__shared__ float dz_inv_deltaz;
__shared__ float l_delta_x;
__shared__ float l_delta_y;
__shared__ float l_delta_z;
__shared__ float l_alpha_x[(int)(i_max[index]-i_min[index]+1)];
__shared__ float l_alpha_y[(int)(j_max[index]-j_min[index]+1)];
__shared__ float l_alpha_z[(int)(k_max[index]-k_min[index]+1)];
l_delta_x = delta_x[index];
l_delta_y = delta_y[index];
l_delta_z = delta_z[index];
dx_inv_deltax = dx / l_delta_x;
dy_inv_deltay = dy / l_delta_y;
dz_inv_deltaz = dz / l_delta_z;
if(l_delta_x > 0){
alpha_x[0] = (x_plane + (i_min[index] - 1)*dx-xsource) / l_delta_x;
for(int i=1; i<(i_max[index]-i_min[index]); i++) {
alpha_x[i] = alpha_x[i - 1] + dx_inv_deltax;
} else {
alpha_x[0] = (x_plane + (i_max[index] - 1)*dx-xsource) / l_delta_x;
for(int i=1; i<i_max[index]-i_min[index]; i++) {
if(l_delta_y > 0){
alpha_y[0] = (y_plane + (j_min[index] - 1)*dy-ysource) / l_delta_y;
for(int i=1; i<(j_max[index]-j_min[index]); i++) {
alpha_y[i] = alpha_y[i - 1] + dy_inv_deltay;
} else {
alpha_y[0] = (y_plane + (j_max[index] - 1)*dy-ysource) / l_delta_y;
for(int i=1; i<j_max[index]-j_min[index]; i++) {
if(l_delta_z > 0){
alpha_z[0] = (z_plane + (k_min[index] - 1)*dz-zsource) / l_delta_z;
for(int i=1; i<(k_max[index]-k_min[index]); i++) {
alpha_z[i] = alpha_z[i - 1] + dz_inv_deltaz;
} else {
alpha_z[0] = (z_plane + (k_max[index] - 1)*dz-zsource) / l_delta_z;
for(int i=1; i<k_max[index]-k_min[index]; i++) {
// printf("%f\n",alpha_x[0]);
