[font=“Arial”][b]Hi
I am new in executing opencl codes…I have downloaded the GPU Computing SDK and drivers and executing opencl samples from that…I have included all the .lib files which are there in opencl in SDK…While executing i got the following errors in visual studio 2010
1>------ Build started: Project: testopencl, Configuration: Debug Win32 ------
1> Skipping… (no relevant changes detected)
1> testopencl.cpp
1>testopencl.obj : error LNK2019: unresolved external symbol _shrComparefet referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clEnqueueReadBuffer@36 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clEnqueueNDRangeKernel@36 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clEnqueueWriteBuffer@36 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clSetKernelArg@16 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clCreateKernel@12 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clBuildProgram@24 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clCreateProgramWithSource@20 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _oclLoadProgSource referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _shrFindFilePath referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clCreateBuffer@24 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clCreateCommandQueue@20 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clCreateContext@24 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clGetDeviceIDs@24 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clGetPlatformIDs@12 referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _shrFillArray referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _shrRoundUp referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _shrLog referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _shrSetLogFileName referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _shrCheckCmdLineFlag referenced in function _main
1>testopencl.obj : error LNK2019: unresolved external symbol _clReleaseMemObject@4 referenced in function “void __cdecl Cleanup(int,char * *,int)” (?Cleanup@@YAXHPAPADH@Z)
1>testopencl.obj : error LNK2019: unresolved external symbol _clReleaseContext@4 referenced in function “void __cdecl Cleanup(int,char * *,int)” (?Cleanup@@YAXHPAPADH@Z)
1>testopencl.obj : error LNK2019: unresolved external symbol _clReleaseCommandQueue@4 referenced in function “void __cdecl Cleanup(int,char * *,int)” (?Cleanup@@YAXHPAPADH@Z)
1>testopencl.obj : error LNK2019: unresolved external symbol _clReleaseProgram@4 referenced in function “void __cdecl Cleanup(int,char * *,int)” (?Cleanup@@YAXHPAPADH@Z)
1>testopencl.obj : error LNK2019: unresolved external symbol _clReleaseKernel@4 referenced in function “void __cdecl Cleanup(int,char * *,int)” (?Cleanup@@YAXHPAPADH@Z)
1>C:\Users\Acer\Documents\Visual Studio 2010\Projects\testopencl\Debug\testopencl.exe : fatal error LNK1120: 25 unresolved externals
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I am using Windows7 os 64-bit with nvidia graphic card…It will be great helpful if anyone reply the solution for this problem.
Thank You…[/b][/font]
