Hi all
the question is basically in the topic description…
I'm stuck with VS2010 but need to prototype a tool using OpenCL or Cuda
For that I'd like to compile and play with the SDK samples (for ex the ocl particles one)
Unfortunately I've heaps of errors when I try to compile it.
It looks like I've found a dirty solution from MS (http://social.msdn.microsoft.com/Forums/en/vcgeneral/thread/5ac28a31-3339-4db1-90f4-68edad360309)
But before trying it I just wanted to know if there was a proper solution available from NVidia !?
Cheers
S.Bertout
the errors I get :
1>shrUtils64D.lib(shrUtils.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ) referenced in function "public: class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > & __cdecl std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::erase(unsigned __int64,unsigned __int64)" (?erase@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QEAAAEAV12@_K0@Z)
1>shrUtils64D.lib(cmd_arg_reader.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
1>oclUtils64D.lib(oclUtils.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
1>shrUtils64D.lib(shrUtils.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ) referenced in function "public: class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > & __cdecl std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::append(char const *,unsigned __int64)" (?append@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QEAAAEAV12@PEBD_K@Z)
1>shrUtils64D.lib(cmd_arg_reader.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
1>oclUtils64D.lib(oclUtils.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
1>shrUtils64D.lib(shrUtils.obj) : error LNK2019: unresolved external symbol "private: static void __cdecl std::locale::facet::facet_Register(class std::locale::facet *)" (?facet_Register@facet@locale@std@@CAXPEAV123@@Z) referenced in function "public: void __cdecl std::locale::facet::_Register(void)" (?_Register@facet@locale@std@@QEAAXXZ)
1>shrUtils64D.lib(cmd_arg_reader.obj) : error LNK2001: unresolved external symbol "private: static void __cdecl std::locale::facet::facet_Register(class std::locale::facet *)" (?facet_Register@facet@locale@std@@CAXPEAV123@@Z)
1>shrUtils64D.lib(shrUtils.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl std::_Locinfo::_Locinfo_ctor(class std::_Locinfo *,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?_Locinfo_ctor@_Locinfo@std@@SAXPEAV12@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@2@@Z) referenced in function "public: __cdecl std::_Locinfo::_Locinfo(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (??0_Locinfo@std@@QEAA@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@1@@Z)
1>shrUtils64D.lib(cmd_arg_reader.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_Locinfo::_Locinfo_ctor(class std::_Locinfo *,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?_Locinfo_ctor@_Locinfo@std@@SAXPEAV12@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@2@@Z)
1>…\…\bin\Win64\Debug\oclParticles.exe : fatal error LNK1120: 4 unresolved externals
