Hi!
Some time ago I had a C-routine that I wanted to link to my FORTRAN code. After some time I succeeded. Now I have a whole utility in C and want to convert it into a subroutine to be called from FORTRAN. My attempts until here were in vain, so I call for help at this place.
Main difference between my earlier problem and the present one is that now I want to read data from a file, whereas in the past I wanted to write data to a file. Plus the conversion of a main program into a subroutine.
Here is what I did:
I copied the utility xyz.c to xyzutils.c and changed:
int main(int argc, char **argv) {
into:
int read_xyz_record ( char *filein_name, long int dump, int nx, int ny, float *array ) {
where filein_name and dump are supposed to be input variables, nx, ny and array are supposed to be output variables. Here I already probably make some errors with pointers etc.
I wrote a wrap-function read_xyz_record_, which has an extra underscore and which simply calls read_xyz_record, just to make sure that FORTRAN will find the C-routine.
I made a headerfile xyzutils.h, which contains just the headers of functions read_xyz_record and read_xyz_record_:
int read_xyz_record ( char *filein_name, long int dump, int nx, int ny, float *array );
int read_xyz_record_ ( char *filein_name, long int dump, int nx, int ny, float *array );
Then, I wrote a fortran module libxyz.f90, containing the following interface:
interface
integer function read_xyz_record(file,dump,nx,ny,darr)
character(*), intent(in) :: file
integer, intent(in) :: dump, nx, ny
REAL(4), dimension(*), intent(out) :: darr
end function read_xyz_record
end interface
and a subroutine that calls read_xys_record as follows:
SUBROUTINE Readxyzje(fname,recnr,darray)
CHARACTER(*), INTENT(IN) :: fname
INTEGER, INTENT(IN) :: recnr
REAL(4), INTENT(INOUT), DIMENSION(:) :: darray
INTEGER :: Rv,NX,NY
Rv = read_xyz_record(fname//char(0),%val(RecNr),%val(nx),%val(ny),darray)
END SUBROUTINE Readxyzje
When I compile a simple test program that just calls fortran routine readxyzje on a file and then makes an ASCII-dump of the resulting array, I get a bunch of zeros.
In my (working) mudule that links C-routines for the handling of bitmap-files, I find:
int bmp_read ( char *filein_name, int *xsize, int *ysize, int **rarray, int **garray, int **barray );
int bmp_write ( char *fileout_name, int xsize, int ysize, int *rarray,
int *garray, int *barray );
Adding the extra “*”-characters to the C-headers didn’t bring what I hoped for… Probably not only the C-routine needs some modification, but also the call to it in the fortran routine and maybe the interface declaration need some attention. Who can tell me how I can make a working fortran routine from the available C-utility?
Best regards and thanks ahead for all contributions,
Arjan
Arjan.van.Dijk@RIVM.nl
