Both main.c and EV.cu compile into objects main.o and EV.o using nvcc. However, when I attempt to link them, I get the following error:
$ nvcc -o main main.o EV.o -lgsl -lgslcblas -lm -lcuda -lcudart
main.o: In function `main':
main.c:(.text+0x195): undefined reference to `EV'
collect2: ld returned 1 exit status
I expected that if I have the function EV() forward defined in main.c and defined in the compiled EV.o that the linking should proceed without this error. Is there something I am missing?
The CUDA compiler basically has a C++ frontend. This means function names in the object code will be decorated versions of the function name in the source code. C does not use the C++ decorations, so the two names that look identical at source level are in fact not the same at object file level, which is why the linker can’t make the match.
To successfully link the function in your CUDA file with the C code, add
extern "C"
to the function prototype in the CUDA code. This instructs the compiler to refrain from adding C++ decorations for the function name emitted into the object file.
