Release highlights since 375.10:
- Fixed a bug that could cause displays in SLI Mosaic to blank when applying a transformation matrix.
- Added EGL support to the GL Vendor Neutral Dispatch Library (libGLVND). The installer package now includes both GLVND and non-GLVND versions of the EGL libraries: the --glvnd-egl-client and --no-glvnd-egl-client options in nvidia-installer can be used to select which to install.
- Added support for the following GPUs:
- GeForce GTX 1050
- GeForce GTX 1050 Ti
- Quadro M620
- Quadro M5000 SE
- Tesla P100-PCIE-12GB
- Tesla P100-PCIE-16GB
- Tesla P100-SXM2-16GB
- Tesla P4
- Fixed a bug that prevented G-SYNC from working on notebook displays.
- Fixed a bug that caused DisplayPort multistream devices to go blank after the console is restored.
- Fixed a bug that caused a kernel crash when starting X for the second time when more than one DisplayPort multistream device is connected to a single DisplayPort connector via a branch device.
- Updated nvidia-settings to not have a build-time dependence on an external nvml development package (a regression introduced in 375.10).
- Fixed a crash in nvidia-settings when adding Application Profile Rule and Profile entries.
- Removed the "Enable Tooltip" option in nvidia-settings for the GTK 2 interface.
- Raised the on-disk OpenGL shader cache size from 64MB to 128MB. Refer to the "Specifying OpenGL Environment Variable Settings" section of the driver README for details on how to select its location or disable it.
- Fixed a bug in synchronization primitives shared between X and OpenGL.
- Added support for X.Org xserver ABI 23 (xorg-server 1.19)
[README | Linux x86 | Linux x86_64 | Linux ARM | Solaris | FreeBSD x86 | FreeBSD x86_64]
