Release highlights since 515.86.01:
Fixed a bug that could cause fullscreen PRIME Render Offload applications and/or X to crash when an NVIDIA GPU is driving multiple displays with Reverse PRIME.
Added support for console restoration when using simpledrm.
Disabled Fixed Rate Link (FRL) when using passive DisplayPort to HDMI dongles, which are incompatible with FRL.
Updated nvidia-modprobe to create symbolic links in /dev/char when creating the /dev/nvidia* device nodes. This resolves an issue that prevented the device nodes from working with newer versions of runc:
Newer runc versions break support for NVIDIA GPUs · Issue #3708 · opencontainers/runc · GitHub
[README | Linux x86_64 | Solaris | FreeBSD x86_64 | Kernel driver source]
