Live Camera for mobilenet-ssd model, if a persion detected, send a counter metric message to AWS cloudwatch?
Hi all,
I’m following tutorial to retrain mobilenet-ssd, jetson-inference/pytorch-ssd.md at master · dusty-nv/jetson-inference · GitHub.
And for step " Running the Live Camera Program"
detectnet --model=models/fruit/ssd-mobilenet.onnx --labels=models/fruit/labels.txt \
          --input-blob=input_0 --output-cvg=scores --output-bbox=boxes \
            csi://0
Is it possible to add some side actions, for example, if from the live camera, if a person detected, send a counter metric message to AWS-Cloudwatch?
I’m a newbie on this topic and please excuse me for this naive question. (I’m not even sure if this is a valid question…)
Thank you very much!
P.S.
I searched around but seems not such a similar question as mine
(and new user can only put in one link??? :cry:)
  • https ://forums.developer.nvidia.com/t/how-to-show-metrics-in-custom-object-detection-model/237366
  • https ://forums.developer.nvidia.com/t/jetson-inference-retraining-ssd-mobilenet/193836
  • https ://forums.developer.nvidia.com/t/running-original-tensorflow-model-for-ssd-mobilenet-v2-with-live-usb-camera-capture-on-jetson-nano/76781
  • https ://forums.developer.nvidia.com/t/object-detection-with-mobilenet-ssd-slower-than-mentioned-speed/72736/7
I’ve also checked the Jetbot where I believe there is some inference result triggered action, for sending a metric message to AWS-Cloudwatch, I can do something similar to update() method here?
def update(change):
    global blocked_slider, robot
    x = change['new']
    x = preprocess(x)
    y = model(x)
    # we apply the `softmax` function to normalize the output vector so it sums to 1 (which makes it a probability distribution)
    y = F.softmax(y, dim=1)
    prob_blocked = float(y.flatten()[0])
    blocked_slider.value = prob_blocked
    if prob_blocked < 0.5:
        robot.forward(speed_slider.value)
    else:
        robot.left(speed_slider.value)
    time.sleep(0.001)
update({'new': camera.value})  # we call the function once to initialize
as in jetbot/live_demo.ipynb at master · NVIDIA-AI-IOT/jetbot · GitHub
Isn’t CloudWatch for monitoring your AWS resources? Maybe you want to run a Lambda function? I would start by writing the logic for that, whatever it is, in python.
Then add your function to the main loop of detectNet sample.
jetson-inference/detectnet.py at master · dusty-nv/jetson-inference (github.com)
Maybe DeepStream is a better tool for the job? How to integrate NVIDIA DeepStream on Jetson Modules with AWS IoT Core and AWS IoT Greengrass | The Internet of Things on AWS – Official Blog (amazon.com)
Thank you for your prompt reply.
And it’s exactly what I’m looking for, adding my function (either aws-cloudwatch or a lambda call) to the main loop of detectNet sample.
But it seems detectnet.py only supporting pre-trained models?
from jetson_inference import detectNet
parser.add_argument("--network", type=str, default="ssd-mobilenet-v2", help="pre-trained model to load (see below for options)")
# load the object detection network
net = detectNet(args.network, sys.argv, args.threshold)
So to plugin my re-trained model to detectNet as parameter, after re-training and converting to onnx format python3 onnx_export.py --model-dir=models/fruit, I can give my re-trained onnx model as parameter:
# note: to hard-code the paths to load a model, the following API can be used:
net = detectNet(model="model/ssd-mobilenet.onnx", labels="model/labels.txt",
                input_blob="input_0", output_cvg="scores", output_bbox="boxes",
                threshold=args.threshold)
Is this the right understanding?
Thank you!
Hi @renxin.ubc, yes that is correct, detectnet.py can run either pre-trained or custom models (that you trained with train_ssd.py). detectnet.py can load your custom models either using the hard-coded function you have above, or with command-line syntax like shown here.
Then you can add your own actions/triggers inside the main loop like this:
while True:
	# capture the next image
	img = input.Capture()
	# detect objects in the image (with overlay)
	detections = net.Detect(img, overlay=args.overlay)
	for detection in detections:
		if net.GetClassDesc(detection.ClassID) == 'person':
			# perform a custom action
			print('detected a person!')
Thank you Dustin!
I tried my self, and it worked.
I modified detectnet.py in build folder with path ~/jetson-inference/build/aarch64/bin:
  1. input/output, from original reading from input parameters to hard-coded device path of my jetson-nano setup
  2. add print line print("Xin is about to do something on the inference dectection results") after inference done
# create video sources and outputs
#input = videoSource(args.input_URI, argv=sys.argv)
#output = videoOutput(args.output_URI, argv=sys.argv+is_headless)
input = videoSource("/dev/video0")
output = videoOutput("display://0")
		print(detection)
        # render the image
	output.Render(img)
And then when I run it, I got the print line I added
xin@xin-desktop:~/jetson-inference/build/aarch64/bin$ ./detectnet.py
[TRT]    ------------------------------------------------
[TRT]    Timing Report networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT]    Pre-Process   CPU   0.07172ms  CUDA   0.83979ms
[TRT]    Network       CPU  53.65486ms  CUDA  42.77724ms
[TRT]    Post-Process  CPU   0.04636ms  CUDA   0.04724ms
[TRT]    Visualize     CPU   0.24578ms  CUDA  10.53187ms
[TRT]    Total         CPU  54.01872ms  CUDA  54.19614ms
detected 1 objects in image
<detectNet.Detection object>
   -- ClassID: 1
   -- Confidence: 0.921387
   -- Left:    0
   -- Top:     8.96484
   -- Right:   1033.75
   -- Bottom:  715.078
   -- Width:   1033.75
   -- Height:  706.113
   -- Area:    729945
   -- Center:  (516.875, 362.021)
OK, great! Just a word of warning - if you were to run cmake or make again at some point, it would overwrite your changes with the original copy from jetson-inference/python/examples. So you may want to re-name your edited version to something else or store it somewhere else.
sure will do that, thank you Dustin and all the best to you :)
