Hi everyone,
Happy to have just merged a significant set of updates and new features to jetson-inference
master:
- Re-training SSD-Mobilenet Object Detection tutorial with PyTorch
- Support for collection of object detection datasets and bounding-box labeling in
camera-capture
tool videoSource
andvideoOutput
APIs for C++/Python that supports multiple types of video streams:- Unified the
-console
and-camera
samples to process both images and video streams - Support for
uchar3/uchar4/float3/float4
images (default is nowuchar3
as opposed tofloat4
) - Replaced opaque Python memory capsule with
jetson.utils.cudaImage
object- See Image Capsules in Python for more info
- Images are now subscriptable/indexable from Python to directly access the pixel dataset
- Numpy ndarray conversion now supports
formats
cudaConvertColor()
automated colorspace conversion function (RGB, BGR, YUV, Bayer, grayscale, ect)- Python CUDA bindings for
cudaResize()
,cudaCrop()
,cudaNormalize()
,cudaOverlay()
- See Image Manipulation with CUDA and
cuda-examples.py
for examples of using these
- Transitioned to using Python3 by default since Python 2.7 is now past EOL
- DIGITS tutorial is now marked as deprecated (replaced by PyTorch transfer learning tutorial)
- Logging can now be controlled/disabled from the command line (e.g.
--log-level=verbose
note: API changes from this update are intended to be backwards-compatible, so previous code should still run.
The same code can now run from images/video/cameras and encoded network streams (RTP/RTSP):
import jetson.inference
import jetson.utils
import argparse
import sys
# parse the command line
parser = argparse.ArgumentParser(description="Locate objects in a live camera stream using an object detection DNN.")
parser.add_argument("input_URI", type=str, default="", nargs='?', help="URI of the input stream")
parser.add_argument("output_URI", type=str, default="", nargs='?', help="URI of the output stream")
parser.add_argument("--network", type=str, default="ssd-mobilenet-v2", help="pre-trained model to load (see below for options)")
try:
opt = parser.parse_known_args()[0]
except:
print("")
parser.print_help()
sys.exit(0)
# load the object detection network
net = jetson.inference.detectNet(opt.network, sys.argv)
# create video sources & outputs
input = jetson.utils.videoSource(opt.input_URI, argv=sys.argv)
output = jetson.utils.videoOutput(opt.output_URI, argv=sys.argv)
# process frames until EOS or the user exits
while True:
img = input.Capture()
detections = net.Detect(img)
output.Render(img)
output.SetStatus("{:s} | Network {:.0f} FPS".format(opt.network, net.GetNetworkFPS()))
net.PrintProfilerTimes()
if not input.IsStreaming() or not output.IsStreaming():
break
For more info, see these new pages from the repo:
- Camera Streaming and Multimedia
- Image Manipulation with CUDA
- Collecting your own Detection Datasets
Thanks to everyone from the forums and GitHub who helped to test these updates in advance!
