Hello AI World - new object detection training and video interfaces
Hi everyone,
Happy to have just merged a significant set of updates and new features to jetson-inference master:
note: API changes from this update are intended to be backwards-compatible, so previous code should still run.
The same code can now run from images/video/cameras and encoded network streams (RTP/RTSP):
import jetson.inference
import jetson.utils
import argparse
import sys
# parse the command line
parser = argparse.ArgumentParser(description="Locate objects in a live camera stream using an object detection DNN.")
parser.add_argument("input_URI", type=str, default="", nargs='?', help="URI of the input stream")
parser.add_argument("output_URI", type=str, default="", nargs='?', help="URI of the output stream")
parser.add_argument("--network", type=str, default="ssd-mobilenet-v2", help="pre-trained model to load (see below for options)")
try:
	opt = parser.parse_known_args()[0]
except:
	print("")
	parser.print_help()
	sys.exit(0)
# load the object detection network
net = jetson.inference.detectNet(opt.network, sys.argv)
# create video sources & outputs
input = jetson.utils.videoSource(opt.input_URI, argv=sys.argv)
output = jetson.utils.videoOutput(opt.output_URI, argv=sys.argv)
# process frames until EOS or the user exits
while True:
	img = input.Capture()
	detections = net.Detect(img)
	output.Render(img)
	output.SetStatus("{:s} | Network {:.0f} FPS".format(opt.network, net.GetNetworkFPS()))
	net.PrintProfilerTimes()
	if not input.IsStreaming() or not output.IsStreaming():
		break
For more info, see these new pages from the repo:
Thanks to everyone from the forums and GitHub who helped to test these updates in advance!
