Hello AI World - now supports Python and onboard training with PyTorch!
External Media
Hi all, just merged a large set of updates and new features into jetson-inference master:
  • Python API support for imageNet, detectNet, and camera/display utilities
  • Python examples for processing static images and live camera streaming
  • Support for interacting with numpy ndarrays from CUDA
  • Onboard re-training of ResNet-18 models with PyTorch
  • Example datasets: 800MB Cat/Dog and 1.5GB PlantCLEF
  • Camera-based tool for collecting and labeling custom datasets
  • Text UI tool for selecting/downloading pre-trained models
  • New pre-trained image classification models (on 1000-class ImageNet ILSVRC)
    • ResNet-18, ResNet-50, ResNet-101, ResNet-152
    • VGG-16, VGG-19
    • Inception-v4
  • New pre-trained object detection models (on 90-class MS-COCO)
    • SSD-Mobilenet-v1
    • SSD-Mobilenet-v2
    • SSD-Inception-v2
  • API Reference documentation for C++ and Python
  • Command line usage info for all examples, run with --help
  • Output of network profiler times, including pre/post-processing
  • Improved font rasterization using system TTF fonts
Screencast video - Realtime Object Detection in 10 Lines of Python Code on Jetson Nano
Here’s an object detection example in 10 lines of Python code using SSD-Mobilenet-v2 (90-class MS-COCO) with TensorRT, which runs at 25FPS on Jetson Nano on a live camera stream with OpenGL visualization:
import jetson.inference
import jetson.utils
net = jetson.inference.detectNet("ssd-mobilenet-v2")
camera = jetson.utils.gstCamera()
display = jetson.utils.glDisplay()
while display.IsOpen():
	img, width, height = camera.CaptureRGBA()
	detections = net.Detect(img, width, height)
	display.RenderOnce(img, width, height)
	display.SetTitle("Object Detection | Network {:.0f} FPS".format(1000.0 / net.GetNetworkTime()))
Thanks to all the beta testers of the new features from here on the forums!
Project Link…https://github.com/dusty-nv/jetson-inference/
Model Mirror…https://github.com/dusty-nv/jetson-inference/releases
Hello, when I tried this pytorch install, it faield with numpy installing. It seems that the torch wheel file depends on a newer version of numpy.
My Jestson Xavier has already installed numpy with this command “sudo apt-get install libpython3-dev python3-numpy”
And I also tried “sudo pip3 install numpy” manually. It stopped the installing process anyway at the step “Building wheel for numpy…” and cannot move on anymore.
Collecting numpy
Downloading https://files.pythonhosted.org/packages/ff/59/d3f6d46aa1fd220d020bdd61e76ca51f6548c6ad6d24ddb614f4037cf49d/numpy-1.17.4.zip (6.4MB)
|████████████████████████████████| 6.4MB 58kB/s
Building wheels for collected packages: numpy
Building wheel for numpy (setup.py) … -
Hi 290844930, sometimes it takes awhile to build the required version of numpy - are you sure the process is not still working? Is there another error message?
Hi all, we’ve just posted a screencast tutorial for Hello AI World - check it out!
Hi, can you explain or give me some links on how to train my own ssd inception model optimized with TensorRT ?
Hi @marconi.k, please refer to this post: DIGITS or somthing else - #7 by dusty_nv
Also, I am currently working on adding to the Hello AI World tutorial a part where you can re-train SSD-Mobilenet using PyTorch onboard your Jetson. It should be ready in the coming weeks, so stay tuned.
Happy to hear that ! Thanks for the quick reply ,will stay stuned for this :)
Hi! Thank you for a great kick-start material.
Would appreciate if you can add a method to stream the output video to be able to monitor it on the laptop/cellphone screen rather than on the Jetson itself
