royn
#1
**• Hardware Platform (Jetson / GPU) - Nano
• DeepStream Version - 6.0
• JetPack Version (valid for Jetson only) - 4.6.2
I’m using usb camera to stream live object detection inference using rtmp sink from deepstream pipeline. Below is the pipeline used:
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! “video/x-raw,format=(string)UYVY” ! nvvideoconvert ! “video/x-raw(memory:NVMM),width=1280,height=720,framerate=30/1” ! nvvideoconvert ! “video/x-raw,format=(string)NV12,width=1280,height=720,framerate=30/1” ! nvvideoconvert ! mux.sink_0 nvstreammux live-source=1 name=mux batch-size=1 width=1280 height=720 ! nvinfer config-file-path=dstest1_pgie_config.txt batch-size=1 ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! queue ! flvmux name=muxer alsasrc device=hw:1 ! audioresample ! “audio/x-raw,rate=48000” ! queue ! voaacenc bitrate=32000 ! aacparse ! queue ! muxer. muxer. ! rtmpsink location= rtmp://a.rtmp.youtube.com/live2/xxxxxxxx sync=false -v
It is streaming only the video NOT the inference output with bounding box and its classes.
When i tried to display locally it works fine with the below command :
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! “video/x-raw,format=(string)UYVY” ! nvvidconv ! “video/x-raw(memory:NVMM),width=1280,height=720,framerate=30/1” ! nvvidconv ! “video/x-raw,format=(string)NV12,width=1280,height=720,framerate=30/1” ! nvvidconv ! mux.sink_0 nvstreammux live-source=1 name=mux batch-size=1 width=1280 height=720 ! nvinfer config-file-path=dstest1_pgie_config.txt ! nvvidconv ! nvv4l2h264enc ! h264parse ! queue ! flvmux name=muxer alsasrc device=hw:1 ! audioresample ! “audio/x-raw,rate=48000” ! queue ! voaacenc bitrate=32000 ! aacparse ! queue ! muxer. muxer. ! nveglglesink -e
How to stream the object detection output via rtmp sink?
Any help would be appreciated.
Your pipeline looks fine. It should work.
I don’t think nveglglessink can be connected to flvmux src pad. This is a wrong pipeline.
royn
#5
With the above command - it is not streaming the inference output - instead it is streaming only the camera input.
Any suggestions?
royn
#7
Attached the output image of the pipeline graph here.
Let me know anything is missing.
Please use nvdsosd to draw the bbox and print text. Gst-nvdsosd — DeepStream 6.1 Release documentation
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! “video/x-raw,format=(string)UYVY” ! nvvideoconvert ! “video/x-raw(memory:NVMM),width=1280,height=720,framerate=30/1” ! nvvideoconvert ! “video/x-raw,format=(string)NV12,width=1280,height=720,framerate=30/1” ! nvvideoconvert ! mux.sink_0 nvstreammux live-source=1 name=mux batch-size=1 width=1280 height=720 ! nvinfer config-file-path=dstest1_pgie_config.txt batch-size=1 ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! queue ! flvmux name=muxer alsasrc device=hw:1 ! audioresample ! “audio/x-raw,rate=48000” ! queue ! voaacenc bitrate=32000 ! aacparse ! queue ! muxer. muxer. ! rtmpsink location= rtmp://a.rtmp.youtube.com/live2/xxxxxxxx sync=false -v
royn
#9
Thanks for you suggestion.
It works now - However there is a latency of 30 sec to 1 minute in the live streaming.
Any recommendations to reduce the latency in this pipeline?
Please create new topic for the latency issue.
system
closed
#11
