I am trying to load the model attached. I can’t figure out how to correctly set up the batch size of the model. It looks like the input is configured to have batch size = 8 (shape [8, 3, 640, 640], but the output has batch size = 1 (shapes [1, 3, 80, 80, 85], [1, 3, 40, 40, 85], [1, 3, 20, 20, 85]. Why?
Python code
trt_settings = dict(
inputs= [
"name": None,
"shape": [8, 3, 640, 640]
outputs=[
"name": "classes",
"shape": [8, 3, 80, 80, 85]
"name": "boxes",
"shape": [8, 3, 40, 40, 85]
"name": "444",
"shape": [8, 3, 20, 20, 85]
# model_path=self.onnx_path
model_path="yolov5s.onnx"
# Required for ONNX engines
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
with trt.Builder(self.trt_logger) as builder, builder.create_network(EXPLICIT_BATCH) as network, trt.OnnxParser(
network, self.trt_logger
) as parser:
try:
builder.max_workspace_size = 1 << 30 # self.max_workspace_size
builder.max_batch_size = 8
builder.fp16_mode = True
trt_required_inputs = trt_settings.get("inputs", list())
trt_required_outputs = trt_settings.get("outputs", list())
with open(trt_settings.get('model_path'), "rb") as model:
logger.info("Beginning ONNX file parsing...")
if not parser.parse(model.read()):
logger.error("ERROR: Failed to parse the ONNX file.")
for error in range(parser.num_errors):
logger.error(parser.get_error(error))
raise RuntimeError
for index, model_input in enumerate(trt_required_inputs):
network.get_input(index).shape = model_input["shape"]
logger.info("Building TensorRT engine. This may take few minutes.")
return builder.build_cuda_engine(network)
except Exception:
logger.error("Error creating CUDA Engine...")
logger.error(traceback.format_exc())
raise RuntimeError
Note: I know that Yolo v5 provides a TensorRT implementation written in C++. However, without going into too many details, I need to convert the model from its ONNX version (basically I need to use Yolo v5m). If you are not familiar with Yolo v5, you can simply forget about this comment.
yolov5s.onnx.zip (23.7 MB)
