Lost in guides from different years
I’m trying to find the best guide for setting up my AGX Orin using Jetpack 6.1, to use Docker and pytorch, torchvision, and torchaudio. Most guides don’t seem to work on my version. If you’ve been successful, do have notes I might be able to borrow?
Thanks in advance!
p.s. This is my first original topic. I hope it’s in the correct place.
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Thanks for the reply! You’re my first reply. I was worried I was shadow banned.
Thanks for the guide. I’m also working on my own step by step that I’ll be posting as soon as I can finally get something working.
You can set up docker with the instructions shared below:
PyTorch, TorchVision, and TorchAudio prebuilt packages for Jetson can be found in the link below:
https://pypi.jetson-ai-lab.dev/jp6/cu126
