The environment where the equipment is installed is shown as the image. I installed the pytorch by the Command line(pip install --no-cache https://developer.download.nvidia.com/compute/redist/jp/v60/pytorch/torch-2.4.0a0+07cecf4168.nv24.05.14710581-cp310-cp310-linux_aarch64.whl).
I installed the pytorch3d-V0.7.8,but i found that it sames don’t work.
now i want to know which version the pytorch3d was fitted in the jetson
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
- TensorFlow: Installing TensorFlow for Jetson Platform - NVIDIA Docs
- PyTorch: Installing PyTorch for Jetson Platform - NVIDIA Docs
We also have containers that have frameworks preinstalled:
Data Science, Machine Learning, AI, HPC Containers | NVIDIA NGC
3. Tutorial
Startup deep learning tutorial:
- Jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson
- TensorRT sample: Jetson/L4T/TRT Customized Example - eLinux.org
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
