Low Bandwidth with simple data copy
Hallo everyone!
I have a strange problem and I am hoping, that someone might help me.
I played around with some CUDA code to test the effective bandwith with my “Quaddro 4000” card (peak bandwidth about 90GB/s).
I wrote a kernel, that simply copys data from global-mem to global-mem and was hoping to get the maximal badwidth with I read from the Compute Visual Profiler!
So, when I do so… copying data with a datatype “double” I get the maximal bandwidth of about 77 GB/s… OK so far I think!
BUT when I copy the same kernel and now FLOAT data my bandwith goes down and I get only about 60 GB/s!
Why that?! I played around with the threads per block and also copied more or less data, but no better value! What am I doing wrong?
Thanks for any help!!
Jester
Here is the code I am using:
#define CU_ERR_HANDLE( err ) (HandleError( err, __FILE__, __LINE__ ))
static void HandleError(cudaError_t err,const char *file,int line)
    if (err != cudaSuccess)
        printf("%s in %s at line %d\n", cudaGetErrorString( err ),file, line);
        //exit(EXIT_FAILURE);
void init_rand(float* data, int n)
    for (int i = 0; i < n; ++i)
        data[i] = rand() / (float)RAND_MAX ;
__global__ void strided_copy(float* A,  float* C, int M)
    int i = (blockDim.x * blockIdx.x + threadIdx.x);
    if (i < M)
        C[i] = A[i];
int main()
    int N = 10000000;
    int size = N * sizeof(float);
int threadsPerBlock = 512;
    int numOfBlocks     = (N+threadsPerBlock-1)/threadsPerBlock;
float* h_A;
    float* h_C;
    float* d_A;
    float* d_C;
h_A = (float*)malloc(size);
    h_C = (float*)malloc(size);
init_rand(h_A, N);
// Data to Device
    CU_ERR_HANDLE(cudaMalloc((void**)&d_A, size));
    CU_ERR_HANDLE(cudaMalloc((void**)&d_C, size));
    CU_ERR_HANDLE(cudaMemcpy(d_A, h_A, size, cudaMemcpyHostToDevice));
// KERNEL
    strided_copy<<<numOfBlocks,threadsPerBlock> > >(d_A,d_C,N);
// Data back to Host
    CU_ERR_HANDLE(cudaMemcpy(h_C, d_C, size, cudaMemcpyDeviceToHost));
cudaFree(d_A);
    cudaFree(d_C);
    free(h_A);
    free(h_C);
CU_ERR_HANDLE(cudaThreadExit());
return 0;
#endif
Because with [font=“Courier New”]double[/font] your memory transactions are twice as wide. Try copying [font=“Courier New”]float2[/font] to achieve the same bandwidth, or [font=“Courier New”]double2[/font] or [font=“Courier New”]float4[/font] for further improvement.
Thanks very much for your reply! I will try it…
But let me ask one more question:
Why is the memory width relevant for the bandwidth?
I still copy the same amount of data as [font=“Courier New”]double[/font] or as [font=“Courier New”]floa[/font]t.
In my viewing it should result in the same bandwidth if I copy for example 1 million [font=“Courier New”]double[/font] or 2 million [font=“Courier New”]float[/font]?!
Greetings,
Jester
To get this straight:
A float access is a 32-bit acces.
A float2 access is a 64-bit access.
If I issue a normal float (32-bit) accesses with a CUDA Device of compute capability 2.0 I will NEVER be able to achieve the full bandwidth?! External Image
This is really bad and I assume this should be relevant for everyone who uses CUDA for single precision operations, so this should at least be mentioned by nvidia in the Programming Guide!?
