We know that device to device band width of Quadro FX 5600 is 80GBs/ peak.
In my opinion the transfer operation includes two operations
read from global source memory to register (or local shared)
write value from register to the global destination memory
So actually some simple operation like add a constant to the source memory and write result to the global memory should yields the same bandwidth . However when i try a simple kernel
template<class T>
__global__ void cuvppMul_C1( T* g_idata, T* g_odata, const T s)
const unsigned int idx = threadIdx.x + blockIdx.x * blockDim.x;
g_odata[idx] = g_idata[idx] * s;
and measure the bandwidth, with len = 1 << 22
nIters = 10000, num_threads = 128
dim3 threads(num_threads, 1, 1);
dim3 grid(len/num_threads, 1, 1);
cuvppMul_C1<T><<< grid, threads >>>(d_idata, d_odata, 4.5f);
cudaThreadSynchronize();
CUT_SAFE_CALL( cutResetTimer( timer));
// execute the kernel
for (int i=0; i < nIters; ++i){
CUT_SAFE_CALL( cutStartTimer( timer));
CUT_SAFE_CALL( cutStopTimer( timer));
runTime = cutGetAverageTimerValue(timer);
printf("Average time: %f ms\n", runTime);
printf("Bandwidth: %f GB/s\n\n", (len * sizeof(T)) / (runTime * 1.0e6));
I can only get 30GB. Why i can not get the peak rate. How can i reach the peak rate.
Any idea is appreciated
