While launching all of the code from cv_samples_v1.3.0/lprnet all works well, but when I replace training data with my own, I gen an error. All changes made to spec file are: max_label_length: 9, num_epochs: 80. Traceback below.
• NVIDIA GeForce RTX 3060
• LPRNet
• TAO Toolkit version: 3.21.11
• Training spec file:
random_seed: 42
lpr_config {
hidden_units: 512
max_label_length: 9
arch: "baseline"
nlayers: 18 #setting nlayers to be 10 to use baseline10 model
training_config {
batch_size_per_gpu: 32
num_epochs: 80
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 1e-6
max_learning_rate: 1e-5
soft_start: 0.001
annealing: 0.5
regularizer {
type: L2
weight: 5e-4
eval_config {
validation_period_during_training: 5
batch_size: 1
augmentation_config {
output_width: 96
output_height: 48
output_channel: 3
max_rotate_degree: 5
rotate_prob: 0.5
gaussian_kernel_size: 5
gaussian_kernel_size: 7
gaussian_kernel_size: 15
blur_prob: 0.5
reverse_color_prob: 0.5
keep_original_prob: 0.3
dataset_config {
data_sources: {
label_directory_path: "/workspace/tao-experiments/data/openalpr/train/label"
image_directory_path: "/workspace/tao-experiments/data/openalpr/train/image"
characters_list_file: "/workspace/tao-experiments/lprnet/specs/us_lp_characters.txt"
validation_data_sources: {
label_directory_path: "/workspace/tao-experiments/data/openalpr/val/label"
image_directory_path: "/workspace/tao-experiments/data/openalpr/val/image"
• Using code from cv_samples_v1.3.0/lprnet
• Traceback
Epoch 1/80
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 279, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 275, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 200, in run_experiment
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training.py", line 727, in fit
use_multiprocessing=use_multiprocessing)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py", line 603, in fit
steps_name='steps_per_epoch')
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py", line 221, in model_iteration
batch_data = _get_next_batch(generator)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py", line 363, in _get_next_batch
generator_output = next(generator)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/utils/data_utils.py", line 789, in get
six.reraise(*sys.exc_info())
File "/usr/local/lib/python3.6/dist-packages/six.py", line 696, in reraise
raise value
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/utils/data_utils.py", line 783, in get
inputs = self.queue.get(block=True).get()
File "/usr/lib/python3.6/multiprocessing/pool.py", line 644, in get
raise self._value
File "/usr/lib/python3.6/multiprocessing/pool.py", line 119, in worker
result = (True, func(*args, **kwds))
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/utils/data_utils.py", line 571, in get_index
return _SHARED_SEQUENCES[uid][i]
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/dataloader/data_sequence.py", line 118, in __getitem__
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/dataloader/data_sequence.py", line 118, in <listcomp>
KeyError: 'O'
2021-12-06 08:22:18,201 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
