Hi
Toolkit - 3.0
GPU - RTX 2070
Driver - 460
I have a dataset which has character ‘O’, as i read on some thread that we cannot train custom model from pre-trained so we have to train from scratch spec file, trying same but getting the below error
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 274, in <module>
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 270, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py", line 195, in run_experiment
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training.py", line 727, in fit
use_multiprocessing=use_multiprocessing)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py", line 603, in fit
steps_name='steps_per_epoch')
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py", line 221, in model_iteration
batch_data = _get_next_batch(generator)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py", line 363, in _get_next_batch
generator_output = next(generator)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/utils/data_utils.py", line 789, in get
six.reraise(*sys.exc_info())
File "/usr/local/lib/python3.6/dist-packages/six.py", line 696, in reraise
raise value
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/utils/data_utils.py", line 783, in get
inputs = self.queue.get(block=True).get()
File "/usr/lib/python3.6/multiprocessing/pool.py", line 644, in get
raise self._value
File "/usr/lib/python3.6/multiprocessing/pool.py", line 119, in worker
result = (True, func(*args, **kwds))
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/utils/data_utils.py", line 571, in get_index
return _SHARED_SEQUENCES[uid][i]
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/dataloader/data_sequence.py", line 109, in __getitem__
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/dataloader/data_sequence.py", line 109, in <listcomp>
KeyError: 'O'
File "/usr/local/bin/lprnet", line 8, in <module>
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/entrypoint/lprnet.py", line 12, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py", line 296, in launch_job
AssertionError: Process run failed.
2021-06-21 18:19:44,784 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
NOTE: i have trained a different dataset through pre-trained as well as from scratch but that dataset didn’t have ‘O’. It worked perfectly
Any ideas what might be the issue
