• Hardware TitanRTX Ubuntu
• Network Type:UNet
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
Configuration of the TAO Toolkit Instance
dockers:
nvidia/tao/tao-toolkit-tf:
docker_registry: nvcr.io
docker_tag: v3.21.08-py3
tasks:
1. augment
2. bpnet
3. classification
4. detectnet_v2
5. dssd
6. emotionnet
7. faster_rcnn
8. fpenet
9. gazenet
10. gesturenet
11. heartratenet
12. lprnet
13. mask_rcnn
14. multitask_classification
15. retinanet
16. ssd
17. unet
18. yolo_v3
19. yolo_v4
20. converter
nvidia/tao/tao-toolkit-pyt:
tasks:
1. speech_to_text
2. speech_to_text_citrinet
3. text_classification
4. question_answering
5. token_classification
6. intent_slot_classification
7. punctuation_and_capitalization
nvidia/tao/tao-toolkit-lm:
tasks:
1. n_gram
format_version: 1.0
toolkit_version: 3.21.08
published_date: 08/17/2021
• How to reproduce the issue ?
while running :
print(“For multi-GPU, change --gpus based on your machine.”)
!tao unet train --gpus=1 --gpu_index=$GPU_INDEX
-e $SPECS_DIR/unet_train_resnet_unet_isbi.txt
-r $USER_EXPERIMENT_DIR/isbi_experiment_unpruned
-m $USER_EXPERIMENT_DIR/pretrained_resnet18/pretrained_semantic_segmentation_vresnet18/resnet_18.hdf5
-n model_isbi
-k $KEY
the log:
2021-09-01 05:28:50,313 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 05:28:50,461 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/root/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/hooks/checkpoint_saver_hook.py:21: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/hooks/pretrained_restore_hook.py:23: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/hooks/pretrained_restore_hook.py:23: The name tf.logging.WARN is deprecated. Please use tf.compat.v1.logging.WARN instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py:405: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
Loading experiment spec at /workspace/tlt-experiments/models/unet/specs/unet_train_resnet_unet_isbi.txt.
2021-09-01 05:28:57,190 [INFO] main: Loading experiment spec at /workspace/tlt-experiments/models/unet/specs/unet_train_resnet_unet_isbi.txt.
2021-09-01 05:28:57,191 [INFO] iva.unet.spec_handler.spec_loader: Merging specification from /workspace/tlt-experiments/models/unet/specs/unet_train_resnet_unet_isbi.txt
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py”, line 419, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py”, line 413, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py”, line 283, in run_experiment
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/spec_handler/spec_loader.py”, line 68, in load_experiment_spec
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/spec_handler/spec_loader.py”, line 48, in load_proto
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/spec_handler/spec_loader.py”, line 32, in _load_from_file
OSError: Specfile not found at: /workspace/tlt-experiments/models/unet/specs/unet_train_resnet_unet_isbi.txt
2021-09-01 05:28:58,476 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
