I’ve installed the VIB that shows up in the licensing portal, but the profiles aren’t showing up in the VM settings. We’re runnin ESXi, 6.5.0, 7967591 (and View 7.2). The vib appears to be installed properly, when I run:
I’ve verified the card is in graphics mode (as opposed to compute).
I’ve seen a few comments suggesting that I may have the wrong VIB, but it is the only one offered in the licensing portal. Does anybody have any ideas?
And as an experiment I enabled DirectPath, and at that point the profiles started showing up in the VM settings. After disabling DirectPath again (and after rebooting) I get the following:
Hello sschaber
i have same problem and run dmesg on my host ESXi 7.0 con servidor Dell R740
I get:
ALERT: NVIDIA: module load failed during VIB install/upgrade.
i want virtualized a GPU RTX Quadro 6000
so on my vcenter enviroment my graphix card is available but whitout memory
can you help me
