Mac address is assigned to wrong port of Mellanox
Hi all,
I am trying to get sriov working with Mellanox. I have KVM hypervisor, and I have 2 port Mellanox cards. I am using port 1 of all cards.
This is my output of lspci | grep Mel
[root@hyp-1 hyp-1]# lspci | grep Mel
02:00.0 Ethernet controller: Mellanox Technologies MT27520 Family [ConnectX-3 Pro]
02:00.1 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
02:00.2 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
02:00.3 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
02:00.4 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
02:00.5 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
03:00.0 Ethernet controller: Mellanox Technologies MT27520 Family [ConnectX-3 Pro]
03:00.1 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
03:00.2 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
03:00.3 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
03:00.4 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
03:00.5 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
04:00.0 Ethernet controller: Mellanox Technologies MT27520 Family [ConnectX-3 Pro]
04:00.1 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
04:00.2 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
04:00.3 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
04:00.4 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
04:00.5 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
82:00.0 Ethernet controller: Mellanox Technologies MT27520 Family [ConnectX-3 Pro]
82:00.1 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
82:00.2 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
82:00.3 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
82:00.4 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
82:00.5 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3 Virtual Function]
When I bring up a vm through an xml file, whatever mac address is specified in the xml file gets assigned to the vf of port 2 instead of being assigned to vf of port 1. shouldn’t it get assigned to the vf of the physical port that is in use? I have to do an ip link set manually on the correct ports vf to get it working
Hi, thanks a lot for your response.
This is my xml file:
<VM_LABEL>
<VM_UUID>
Timos VM
62914560
62914560
11
hvm
/usr/libexec/qemu-kvm
Regards,
Kavita
Can you provide XML file? Did you check a RedHat web site - 13.2. Using SR-IOV 13.2. Using SR-IOV Red Hat Enterprise Linux 6 | Red Hat Customer Portal
Did you use exact instruction how to add device data to the XML file?
