hi fellows am working with MM5 in one cluster with a pgi 6.0 and a stand alone MPICH 1.2.5.2 thats works fine but i company buy a new cluster and this one have pgi 7.0-7 plus a stand alone mpich 1.2.5.2, y linux is fedora core6 and I almost do all the instalation of MM5 until i got a several errors compiling the last module MM5 with MPP. the error is to long so am gonna put one of the errors.
One are
PGC-W-0156-Type not specified, ‘int’ assumed (set_padarea.c: 62)
PGC/x86-64 Linux 7.0-7: compilation completed with warnings
/usr/local/mpich/default/bin/mpif90 -c -O -byteswapio set_f_padarea.F
/usr/local/mpich/default/bin/mpicc -c -I/usr/local/mpich/default/include -DMPI -DRSL_SYNCIO -Dlinux -DSWAPBYTES -O -DIMAX_MAKE= -DJMAX_MAKE= -DMAXDOM_MAKE=6 -DMAXPROC_MAKE=256 -DHOST_NODE=0 -DMON_LOW=1 -DALLOW_RSL_168PT=1 domain_def.c
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 193)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 334)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 335)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 336)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 476)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 579)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 612)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 799)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 856)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 925)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 1030)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 1101)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 1213)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 1227)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 1228)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 1229)
PGC-W-0155-Long value is passed to a nonprototyped function - argument #3 (domain_def.c: 1230)
PGC-W-0156-Type not specified, ‘int’ assumed (domain_def.c: 1527)
I dont know if this are to important error.
The other one is
make[1]: Entering directory /data/mm5v3k/MM5/MM5/MPP/build' cut -c1-72 addall.F | sed -e 's///’ -e ‘s/ *$//’ |
expand | /lib/cpp -C -P -traditional -I…/…/MPP -I…/…/MPP/RSL -I…/…/pick -I…/…/MPP/debug -I…/…/MPP/RSL/RSL -DMPP1 -DIOR=2 -DIWORDSIZE=4 -DRWORDSIZE=4 -DLWORDSIZE=4 -DASSUME_HOMOGENEOUS_ENVIRONMENT=1 -DMPI -Dlinux -DDEC_ALPHA -traditional | m4 - > addall.b
…/…/MPP/FLIC/FLIC/flic -F=…/…/MPP/FLICFILE -CPP=‘include<rsl.inc>’ -CPP=‘include<rslcom.inc>’ -H=‘FLIC_RUN_DECL’ -STOP=FKILL_MODEL addall.b > addall.dm
scanning addall.b
parsing addall.b
finished parsing addall.b
m4 …/…/MPP/RSL/LMexp.m4 addall.dm | sed ‘/^$/d’ | /lib/cpp -C -P -traditional -I…/…/MPP -I…/…/MPP/RSL -I…/…/pick -I…/…/MPP/debug -I…/…/MPP/RSL/RSL | …/…/MPP/col_cutter >addall.f
/usr/local/mpich/default/bin/mpif90 -c -O3 -ftz -tp p7-64 -I/usr/local/mpich/default/include -byteswapio addall.f 2> addall.lis
make[1]: [addall.o] Error 1 (ignored)
echo addall.b addall.dm addall.f
cut -c1-72 addrx1c.F | sed -e ‘s/`//’ -e ‘s/ *$//’ |
expand | /lib/cpp -C -P -traditional -I…/…/MPP -I…/…/MPP/RSL -I…/…/pick -I…/…/MPP/debug -I…/…/MPP/RSL/RSL -DMPP1 -DIOR=2 -DIWORDSIZE=4 -DRWORDSIZE=4 -DLWORDSIZE=4 -DASSUME_HOMOGENEOUS_ENVIRONMENT=1 -DMPI -Dlinux -DDEC_ALPHA -traditional | m4 - > addrx1c.b
…/…/MPP/FLIC/FLIC/flic -F=…/…/MPP/FLICFILE -CPP=‘include<rsl.inc>’ -CPP=‘include<rslcom.inc>’ -H=‘FLIC_RUN_DECL’ -STOP=FKILL_MODEL addrx1c.b > addrx1c.dm
scanning addrx1c.b
parsing addrx1c.b
finished parsing addrx1c.b
m4 …/…/MPP/RSL/LMexp.m4 addrx1c.dm | sed ‘/^$/d’ | /lib/cpp -C -P -traditional -I…/…/MPP -I…/…/MPP/RSL -I…/…/pick -I…/…/MPP/debug -I…/…/MPP/RSL/RSL | …/…/MPP/col_cutter >addrx1c.f
/usr/local/mpich/default/bin/mpif90 -c -O3 -ftz -tp p7-64 -I/usr/local/mpich/default/include -byteswapio addrx1c.f 2> addrx1c.lis
make[1]: [addrx1c.o] Error 1 (ignored)
echo addrx1c.b addrx1c.dm addrx1c.f
