“make O=$TEGRA_KERNEL_OUT dtbs” is errors at jetson TX1 at R28.2 .
I will add own camera dtsi in device tree.
I change the tegra210-jetson-cv-base-p2597-2180-a00.dts is below
#include "jetson-platforms/tegra210-jetson-cv-camera-modules.dtsi"
#include "jetson-plugin-manager/tegra210-jetson-cv-camera-plugin-manager.dtsi"
the errors is:
ros@ubuntu:~/JetPack-L4T-3.2/64_TX1/Linux_for_Tegra/sources/kernel/kernel-4.4$ make -j22 O=$TEGRA_KERNEL_OUT dtbs
make[1]: Entering directory '/home/ros/JetPack-L4T-3.2/64_TX1/Linux_for_Tegra/images'
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-imx274-hdmi.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-a00-auo-1080p-edp.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-android-devkit.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-base-p2595-0000-a00.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-e-p2595-0000-a00-00.dtb
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dtb
Error: /home/ros/JetPack-L4T-3.2/64_TX1/Linux_for_Tegra/sources/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/jetson-platforms/tegra210-jetson-cv-camera-imx274-hdmi.dtsi:88.5-6 syntax error
FATAL ERROR: Unable to parse input tree
/home/ros/JetPack-L4T-3.2/64_TX1/Linux_for_Tegra/sources/kernel/kernel-4.4/arch/arm64/boot/dts/Makefile:94: recipe for target 'arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-imx274-hdmi.dtb' failed
make[2]: *** [arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-p2597-2180-imx274-hdmi.dtb] Error 1
make[2]: *** Waiting for unfinished jobs....
arch/arm64/Makefile:105: recipe for target 'dtbs' failed
make[1]: *** [dtbs] Error 2
make[1]: Leaving directory '/home/ros/JetPack-L4T-3.2/64_TX1/Linux_for_Tegra/images'
Makefile:150: recipe for target 'sub-make' failed
make: *** [sub-make] Error 2
How can fix this question?
