makefile for OpenAcc fortran code
I am trying to accelerate my fortran code using OpenACC.
It seems the code is not palatalized with following makefile.
I have tested my computer using examples on this webpage and they works well. Account Login | PGI
I found a template here, should I modify my makefile like this?
https://github.com/pathscale/OpenACC-benchmarks/blob/master/matmul/pgi/makefile
Thanks,
Guanfeng
F90=pgfortran
# -------------------End-macro-Defs---------------------------
# Here is the link step
EMUNE3D:Objects.obj Global_variables.obj module_precision.obj Input_subroutines.obj Horizon.obj  Get_family.obj damage.obj peri_motion.obj dynamics.obj Solver.obj EMUNE3D.obj
	 $(F90) -acc -Minfo -o EMUNE3D Objects.obj Global_variables.obj module_precision.obj Input_subroutines.obj Horizon.obj Get_family.obj damage.obj peri_motion.obj dynamics.obj Solver.obj EMUNE3D.obj
# Here are the compile steps
module_precision.obj:./module_precision.f90
	 $(F90) -c ./module_precision.f90
Hi Guanfeng,
As written, the Makefile isn’t adding any OpenACC compiler flags to the compilation, only the link. In the example Makefile you based this on, they put these flags as part of the compiler variable. Instead, I’d recommend adding an “OPT” variable.
F90=pgfortran
OPT=-acc -Minfo=accel
    $(F90) $(OPT) -o EMUNE3D Objects.obj Global_variables.obj module_precision.obj Input_subroutines.obj Horizon.obj Get_family.obj damage.obj peri_motion.obj dynamics.obj Solver.obj EMUNE3D.obj
    $(F90) $(OPT) -c ./module_precision.f90
Hope this helps,
Mat
Thanks Mat, now I can get accelerator messages now.
Thanks,
Guanfeng
