Addapting CMakeLists to run with openACC
I’m trying to use OpenACC to parallelize a SLAM system. Although i’m having some trouble adapting my makefile or my CMakeLists.txt (I really dont know which should i change).
Until know i’ve only been able to compile a small program to use openACC, following the tutorials of your channel in youtube: https://www.youtube.com/channel/UCOTuufWhV-HTIje7e9jjFQQ
For a simple file i know that i only need to have something like this on the makefile:
choose:
	@echo make c++ or make fortran or make both
CPP=pgc++
FC=pgfortran
TIMER=/usr/bin/time
OPT=
NOPT=-fast -Minfo=opt $(OPT)
ARGS=1000
c++: jsolvec.exe
	$(TIMER) ./jsolvec.exe $(ARGS)
jsolvec.exe: jsolvec.cpp
	$(CPP) -o $@ $< $(NOPT)
fortran: jsolvef.exe
	$(TIMER) ./jsolvef.exe $(STEPS)
jsolvef.exe: jsolvef.F90
	$(FC) -o $@ $< $(NOPT)
both: c++ fortran
clean:
	rm -f *.o *.exe *.s *.mod a.out
An to compile i only need to do: “make c++ OPT=”-ta:tesla:cc50 -Minfo=accel".
But, slam uses a lot of files and has giant makefiles and cmake files. My CMakeLists.txt, which i think is the one i should make the changes looks like this:
SET(PROJECT_NAME DSO)
PROJECT(${PROJECT_NAME})
CMAKE_MINIMUM_REQUIRED(VERSION 2.6)
#set(CMAKE_VERBOSE_MAKEFILE ON)
set(BUILD_TYPE Release)
#set(BUILD_TYPE RelWithDebInfo)
SET(CMAKE_C_COMPILER /opt/pgi/linux86-64/17.10/bin/pgc)
set(EXECUTABLE_OUTPUT_PATH bin)
set(LIBRARY_OUTPUT_PATH lib)
set(CMAKE_MODULE_PATH ${PROJECT_SOURCE_DIR}/cmake)
# required libraries
find_package(SuiteParse REQUIRED)
find_package(Eigen3 REQUIRED)
find_package(Boost COMPONENTS system thread)
# optional libraries
find_package(LibZip QUIET)
find_package(Pangolin 0.2 QUIET)
find_package(OpenCV QUIET)
# flags
add_definitions("-DENABLE_SSE")
set(CMAKE_CXX_FLAGS
   "${SSE_FLAGS} -O3 -g -std=c++0x -march=native"
#   "${SSE_FLAGS} -O3 -g -std=c++0x -fno-omit-frame-pointer"
if (MSVC)
     set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /EHsc")
endif (MSVC)
# Sources files
set(dso_SOURCE_FILES
  ${PROJECT_SOURCE_DIR}/src/FullSystem/FullSystem.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/FullSystemOptimize.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/FullSystemOptPoint.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/FullSystemDebugStuff.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/FullSystemMarginalize.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/Residuals.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/CoarseTracker.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/CoarseInitializer.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/ImmaturePoint.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/HessianBlocks.cpp
  ${PROJECT_SOURCE_DIR}/src/FullSystem/PixelSelector2.cpp
  ${PROJECT_SOURCE_DIR}/src/OptimizationBackend/EnergyFunctional.cpp
  ${PROJECT_SOURCE_DIR}/src/OptimizationBackend/AccumulatedTopHessian.cpp
  ${PROJECT_SOURCE_DIR}/src/OptimizationBackend/AccumulatedSCHessian.cpp
  ${PROJECT_SOURCE_DIR}/src/OptimizationBackend/EnergyFunctionalStructs.cpp
  ${PROJECT_SOURCE_DIR}/src/util/settings.cpp
  ${PROJECT_SOURCE_DIR}/src/util/Undistort.cpp
  ${PROJECT_SOURCE_DIR}/src/util/globalCalib.cpp
include_directories(
  ${PROJECT_SOURCE_DIR}/thirdparty/Sophus
  ${PROJECT_SOURCE_DIR}/thirdparty/sse2neon
  ${EIGEN3_INCLUDE_DIR}
# decide if we have pangolin
if (Pangolin_FOUND)
	message("--- found PANGOLIN, compiling dso_pangolin library.")
	include_directories( ${Pangolin_INCLUDE_DIRS} )
	set(dso_pangolin_SOURCE_FILES
	  ${PROJECT_SOURCE_DIR}/src/IOWrapper/Pangolin/KeyFrameDisplay.cpp
	  ${PROJECT_SOURCE_DIR}/src/IOWrapper/Pangolin/PangolinDSOViewer.cpp)
	set(HAS_PANGOLIN 1)
else ()
	message("--- could not find PANGOLIN, not compiling dso_pangolin library.")
	message("    this means there will be no 3D display / GUI available for dso_dataset.")
	set(dso_pangolin_SOURCE_FILES )
	set(HAS_PANGOLIN 0)
endif ()
# decide if we have openCV
if (OpenCV_FOUND)
	message("--- found OpenCV, compiling dso_opencv library.")
	include_directories( ${OpenCV_INCLUDE_DIRS} )
	set(dso_opencv_SOURCE_FILES
	  ${PROJECT_SOURCE_DIR}/src/IOWrapper/OpenCV/ImageDisplay_OpenCV.cpp
	  ${PROJECT_SOURCE_DIR}/src/IOWrapper/OpenCV/ImageRW_OpenCV.cpp)
	set(HAS_OPENCV 1)
else ()
	message("--- could not find OpenCV, not compiling dso_opencv library.")
	message("    this means there will be no image display, and image read / load functionality.")
	  ${PROJECT_SOURCE_DIR}/src/IOWrapper/ImageDisplay_dummy.cpp
	  ${PROJECT_SOURCE_DIR}/src/IOWrapper/ImageRW_dummy.cpp)
	set(HAS_OPENCV 0)
endif ()
# decide if we have ziplib.
if (LIBZIP_LIBRARY)
	message("--- found ziplib (${LIBZIP_VERSION}), compiling with zip capability.")
	add_definitions(-DHAS_ZIPLIB=1)
	include_directories( ${LIBZIP_INCLUDE_DIR_ZIP} ${LIBZIP_INCLUDE_DIR_ZIPCONF} )
else()
	message("--- not found ziplib (${LIBZIP_LIBRARY}), compiling without zip capability.")
	set(LIBZIP_LIBRARY "")
endif()
# compile main library.
include_directories( ${CSPARSE_INCLUDE_DIR} ${CHOLMOD_INCLUDE_DIR})
add_library(dso ${dso_SOURCE_FILES} ${dso_opencv_SOURCE_FILES} ${dso_pangolin_SOURCE_FILES})
#set_property( TARGET dso APPEND_STRING PROPERTY COMPILE_FLAGS -Wall )
if (${CMAKE_SYSTEM_NAME} MATCHES "Darwin") # OSX
    set(BOOST_THREAD_LIBRARY boost_thread-mt)
else()
    set(BOOST_THREAD_LIBRARY boost_thread)
endif()
# build main executable (only if we have both OpenCV and Pangolin)
if (OpenCV_FOUND AND Pangolin_FOUND)
	message("--- compiling dso_dataset.")
	add_executable(dso_dataset ${PROJECT_SOURCE_DIR}/src/main_dso_pangolin.cpp )
    target_link_libraries(dso_dataset dso boost_system cxsparse ${BOOST_THREAD_LIBRARY} ${LIBZIP_LIBRARY} ${Pangolin_LIBRARIES} ${OpenCV_LIBS})
else()
	message("--- not building dso_dataset, since either don't have openCV or Pangolin.")
endif()
Note that i already added the following line: “SET(CMAKE_C_COMPILER /opt/pgi/linux86-64/17.10/bin/pgc)” as a first attempt to compile with pgc. And it compiled without errors, so i think there’s no problem there. I’ve also tried to change line 30 for somthing like this:
${SSE_FLAGS} -O3 -g -std=c++0x -march=native  -ta:tesla:cc50 -Minfo=accel
This however generates errors because the compiler doesn’t know what “ta” and “Minfo” means.
Any advice on which direction should i take in order to accomplish this?
Hi caap,
I’m not an expert with CMake so may be of limited help. Though, there are a few things I see.
“pgc” is our back-end compiler and shouldn’t be called directly. Please use “pgcc”.
Given you also have “-march=native”, which is a GCC flag, I’m guessing you’re using GCC. I’m not sure if it’s due to the “pgc” typo or if you haven’t set the C compiler correctly.
Note that we did have an intern here last summer that work with Kitware to add OpenACC support to cmake. So more recent versions will have this support.
https://cmake.org/cmake/help/latest/module/FindOpenACC.html
-Mat
I changed the path, and instead of using pgcc i used pgc++ and it already recognizes -ta and Minfo flags. Aren’t these flags suppose to work on pgcc as well?
But now, i do get error becouse of the “-march=native” flag, which, as you said, is a GCC flag, and pgcc doesn’t recognize it. If i try to compile without it e get multiple code errors.
Yes, pgcc recognizes these options.
But now, i do get error becouse of the "-march=native" flag, which, as you said, is a GCC flag, and pgcc doesn't recognize it. If i try to compile without it e get multiple code errors.
The errors are probably something else unrelated to “-march=native”. What are the errors?
-Mat
If i compile for pgcc and with: “set(CMAKE_C_FLAGS
“${SSE_FLAGS} -O3 -g -std=c++0x -march=native -ta=tesla:cc50 -Minfo=accel”)” i get errors like:
/usr/include/c++/5/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
 #error This file requires compiler and library support \
/home/cesar/Documents/dso/src/util/settings.cpp: In function ‘void dso::handleKey(char)’:
/home/cesar/Documents/dso/src/util/settings.cpp:222:55: error: ‘printf’ was not declared in this scope
   printf("new freeDebugParam5: %f!\n", freeDebugParam5);
CMakeFiles/dso.dir/build.make:422: recipe for target 'CMakeFiles/dso.dir/src/util/settings.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/util/settings.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
i change the flag -std=c++0x to -std=c++11 but still get the same errors
So, i managed to compile without errors, doing something like this:
SET(CMAKE_C_COMPILER /opt/pgi/linux86-64/17.10/bin/pgcc)
#SET(CMAKE_CXX_COMPILER /opt/pgi/linux86-64/17.10/bin/pgc++)
# flags
set(CMAKE_CXX_FLAGS
   "${SSE_FLAGS} -O3 -g -std=c++0x -march=native -ta=tesla:cc50 -Minfo=accel"
set(CMAKE_C_FLAGS
   "${SSE_FLAGS} -ta=tesla:cc50 -Minfo=accel"
Although, i don’t think the flags are being used, i get no information taht Minfo is suppose to give, and i added a pragma in the code just to see if it recognizes the language, and it does, i compile without errors, although the pragma isn’t being performed, or at least i get no evidences of that.
I think i have to uncomment the line where i tell the compiler to use pgc++, but if i do that i get an error because pgc++ doens’t know what “-march=native” because it is a gcc flag. And i can’t simply erase that flag
I am sure that i’m compiling with pgc, when calling cmake e get the following messages:
-- The C compiler identification is PGI 17.10.0
-- The CXX compiler identification is PGI 17.10.0
-- Check for working C compiler: /opt/pgi/linux86-64/17.10/bin/pgcc
-- Check for working C compiler: /opt/pgi/linux86-64/17.10/bin/pgcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /opt/pgi/linux86-64/17.10/bin/pgc++
-- Check for working CXX compiler: /opt/pgi/linux86-64/17.10/bin/pgc++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
But, when i compile i get error messages in simple things like ‘;’ :
"/home/cesar/Documents/dso/thirdparty/Sophus/sophus/so3.hpp", line 801:
          warning: type qualifiers are meaningless here
    const ConstQuaternionReference unit_quaternion() const {
"/home/cesar/Documents/dso/src/OptimizationBackend/MatrixAccumulators.h", line
          29: catastrophic error: cannot open source file "SSE2NEON.h"
  #include "SSE2NEON.h"
1 catastrophic error detected in the compilation of "/home/cesar/Documents/dso/src/FullSystem/CoarseInitializer.cpp".
Compilation terminated.
CMakeFiles/dso.dir/build.make:230: recipe for target 'CMakeFiles/dso.dir/src/FullSystem/CoarseInitializer.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/FullSystem/CoarseInitializer.cpp.o] Error 2
1 catastrophic error detected in the compilation of "/home/cesar/Documents/dso/src/OptimizationBackend/AccumulatedTopHessian.cpp".
"/home/cesar/Documents/dso/src/OptimizationBackend/RawResidualJacobian.h", line
          34: warning: extra ";" ignored
  	EIGEN_MAKE_ALIGNED_OPERATOR_NEW;
And i checked that this behavior is due to pgc++, if i compile with pgcc and c++ it compiles fine, but the flags doesn’t work. Compiling with pgcc and pgc++ i get those errors.
Any idea why is pgc++ generating this errors?
Where does SSE2NEON.h come from?
Well, from what i’m seeing, which is weird, that file never existed, but compiling with gcc that is ignored… But now that i forced and copied those files to the project i get this erros:
MakeFiles/dso.dir/build.make:326: recipe for target 'CMakeFiles/dso.dir/src/OptimizationBackend/EnergyFunctional.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/OptimizationBackend/EnergyFunctional.cpp.o] Error 2
"/home/cesar/Documents/dso/thirdparty/sse2neon/SSE2NEON.h", line 123:
          catastrophic error: cannot open source file "arm_neon.h"
  #include "arm_neon.h"
1 catastrophic error detected in the compilation of "/home/cesar/Documents/dso/src/OptimizationBackend/EnergyFunctionalStructs.cpp".
CMakeFiles/dso.dir/build.make:398: recipe for target 'CMakeFiles/dso.dir/src/OptimizationBackend/EnergyFunctionalStructs.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/OptimizationBackend/EnergyFunctionalStructs.cpp.o] Error 2
"/usr/include/boost/smart_ptr/detail/spinlock_pool.hpp", line 38: catastrophic
          error: error while writing intermediate language (4) file: No space
          left on device
      static spinlock pool_[ 41 ];
          error: error while writing intermediate language (2) file: No space
          left on device
"/usr/include/eigen3/Eigen/src/Core/DenseStorage.h", line 46: catastrophic
          error: error while writing intermediate language (5) file: No space
          left on device
    T array[Size];
PGCC-F-0010-File write error occurred (data init file) (/home/cesar/Documents/dso/src/FullSystem/HessianBlocks.cpp)
PGCC/x86 Linux 17.10-0: compilation aborted
"/home/cesar/Documents/Pangolin/include/pangolin/gl/glsl.h", line 532:
          catastrophic error: error while writing intermediate language (5)
          file: No space left on device
      char line[MAXLINESIZE];
CMakeFiles/dso.dir/build.make:278: recipe for target 'CMakeFiles/dso.dir/src/FullSystem/HessianBlocks.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/FullSystem/HessianBlocks.cpp.o] Error 2
1 catastrophic error detected in the compilation of "/home/cesar/Documents/dso/src/FullSystem/ImmaturePoint.cpp".
CMakeFiles/dso.dir/build.make:254: recipe for target 'CMakeFiles/dso.dir/src/FullSystem/ImmaturePoint.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/FullSystem/ImmaturePoint.cpp.o] Error 2
1 catastrophic error detected in the compilation of "/home/cesar/Documents/dso/src/FullSystem/FullSystemOptPoint.cpp".
CMakeFiles/dso.dir/build.make:110: recipe for target 'CMakeFiles/dso.dir/src/FullSystem/FullSystemOptPoint.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/FullSystem/FullSystemOptPoint.cpp.o] Error 2
1 catastrophic error detected in the compilation of "/home/cesar/Documents/dso/src/FullSystem/Residuals.cpp".
1 catastrophic error detected in the compilation of "/home/cesar/Documents/dso/src/IOWrapper/Pangolin/PangolinDSOViewer.cpp".
CMakeFiles/dso.dir/build.make:182: recipe for target 'CMakeFiles/dso.dir/src/FullSystem/Residuals.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/FullSystem/Residuals.cpp.o] Error 2
CMakeFiles/dso.dir/build.make:566: recipe for target 'CMakeFiles/dso.dir/src/IOWrapper/Pangolin/PangolinDSOViewer.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/IOWrapper/Pangolin/PangolinDSOViewer.cpp.o] Error 2
PGCC-S-0000-Internal compiler error. read_debug_info: bad debug file
       0 (/home/cesar/Documents/dso/src/FullSystem/FullSystemDebugStuff.cpp)
PGCC-F-0008-Error limit exceeded (/home/cesar/Documents/dso/src/FullSystem/FullSystemDebugStuff.cpp)
CMakeFiles/dso.dir/build.make:134: recipe for target 'CMakeFiles/dso.dir/src/FullSystem/FullSystemDebugStuff.cpp.o' failed
make[2]: *** [CMakeFiles/dso.dir/src/FullSystem/FullSystemDebugStuff.cpp.o] Error 2
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/dso.dir/all' failed
make[1]: *** [CMakeFiles/dso.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
Oh i see now, because in the files i have:
#if !defined(__SSE3__) && !defined(__SSE2__) && !defined(__SSE1__)
#endif
But i dont know why with gcc that variables are defined and with pgcc they are not
__
