Hello CUDA Community,
I’ve encountered multiple compilation issues while trying to compile my CUDA code (GpuProcessing.cu
, just a simple example) with different GCC compiler versions (g+±11, g+±12, g+±13, g+±14) using CUDA Toolkit 12.5 and 12.6.
Summary of Issues:
1. GCC-11:
nvcc warning : incompatible redefinition for option 'compiler-bindir', the last value of this option was used
/usr/lib/gcc/x86_64-linux-gnu/11/include/amxtileintrin.h(42): error: identifier "__builtin_ia32_ldtilecfg" is undefined
__builtin_ia32_ldtilecfg (__config);
/usr/lib/gcc/x86_64-linux-gnu/11/include/amxtileintrin.h(49): error: identifier "__builtin_ia32_sttilecfg" is undefined
__builtin_ia32_sttilecfg (__config);
2 errors detected in the compilation of "/home/vladislavsemykin/Documents/Work/Start/src/GpuProcessing.cu".
make[2]: *** [CMakeFiles/nia_start_core.dir/build.make:91: CMakeFiles/nia_start_core.dir/src/GpuProcessing.cu.o] Error 2
make[2]: *** Waiting for unfinished jobs....
2. GCC-12:
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512bf16vlintrin.h(53): error: identifier "__builtin_ia32_cvtne2ps2bf16_v16hi" is undefined
return (__m256bh)__builtin_ia32_cvtne2ps2bf16_v16hi(__A, __B);
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512bf16vlintrin.h(60): error: identifier "__builtin_ia32_cvtne2ps2bf16_v16hi_mask" is undefined
return (__m256bh)__builtin_ia32_cvtne2ps2bf16_v16hi_mask(__C, __D, __A, __B);
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512bf16vlintrin.h(67): error: identifier "__builtin_ia32_cvtne2ps2bf16_v16hi_maskz" is undefined
return (__m256bh)__builtin_ia32_cvtne2ps2bf16_v16hi_maskz(__B, __C, __A);
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512bf16vlintrin.h(74): error: identifier "__builtin_ia32_cvtne2ps2bf16_v8hi" is undefined
return (__m128bh)__builtin_ia32_cvtne2ps2bf16_v8hi(__A, __B);
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512bf16intrin.h(67): error: identifier "__builtin_ia32_cvtne2ps2bf16_v32hi_mask" is undefined
return (__m512bh)__builtin_ia32_cvtne2ps2bf16_v32hi_mask(__C, __D, __A, __B);
/usr/lib/gcc/x86_64-linux-gnu/12/include/avx512bf16intrin.h(74): error: identifier "__builtin_ia32_cvtne2ps2bf16_v32hi_maskz" is undefined
return (__m512bh)__builtin_ia32_cvtne2ps2bf16_v32hi_maskz(__B, __C, __A);
/usr/lib/gcc/x86_64-linux-gnu/12/include/amxtileintrin.h(42): error: identifier "__builtin_ia32_ldtilecfg" is undefined
/usr/lib/gcc/x86_64-linux-gnu/12/include/amxtileintrin.h(49): error: identifier "__builtin_ia32_sttilecfg" is undefined
3. GCC-13:
[ 94%] Building CXX object CMakeFiles/nia_start_core.dir/src/ModelingMainDriver.cpp.o
/usr/lib/gcc/x86_64-linux-gnu/13/include/amxtileintrin.h(42): error: identifier "__builtin_ia32_ldtilecfg" is undefined
/usr/lib/gcc/x86_64-linux-gnu/13/include/amxtileintrin.h(49): error: identifier "__builtin_ia32_sttilecfg" is undefined
^Cmake[2]: *** [CMakeFiles/nia_start_core.dir/build.make:76: CMakeFiles/nia_start_core.dir/src/main.cpp.o] Interrupt
make[2]: *** [CMakeFiles/nia_start_core.dir/build.make:105: CMakeFiles/nia_start_core.dir/src/ModelingMainDriver.cpp.o] Interrupt
make[1]: *** [CMakeFiles/Makefile2:285: CMakeFiles/nia_start_core.dir/all] Interrupt
make: *** [Makefile:91: all] Interrupt
4. GCC-14 (unsopported yet as I understand, but I used flag -allow-unsupported-compiler
just for test):
/usr/include/x86_64-linux-gnu/c++/14/bits/c++config.h(827): error: user-defined literal operator not found
typedef __decltype(0.0bf16) __bfloat16_t;
/usr/include/c++/14/type_traits(529): error: type name is not allowed
: public __bool_constant<__is_array(_Tp)>
/usr/include/c++/14/type_traits(529): error: identifier "__is_array" is undefined
/usr/include/c++/14/type_traits(581): error: type name is not allowed
: public __bool_constant<__is_member_object_pointer(_Tp)>
/usr/include/c++/14/type_traits(581): error: identifier "__is_member_object_pointer" is undefined
/usr/include/c++/14/type_traits(603): error: type name is not allowed
: public __bool_constant<__is_member_function_pointer(_Tp)>
/usr/include/c++/14/type_traits(603): error: identifier "__is_member_function_pointer" is undefined
/usr/lib/gcc/x86_64-linux-gnu/14/include/avx512vlbwintrin.h(5136): error: identifier "__builtin_shufflevector" is undefined
__v16qi __T1 = (__v16qi)__W; __v16qi __T2 = __builtin_shufflevector (__T1, __T1, 8, 9, 10, 11, 12, 13, 14, 15, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T3 = __T1 & __T2; __v16qi __T4 = __builtin_shufflevector (__T3, __T3, 4, 5, 6, 7, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T5 = __T3 & __T4; __v16qi __T6 = __builtin_shufflevector (__T5, __T5, 2, 3, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T7 = __T5 & __T6; __v16qi __T8 = __builtin_shufflevector (__T7, __T7, 1, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T9 = __T7 & __T8; return __T9[0];
/usr/lib/gcc/x86_64-linux-gnu/14/include/avx512vlbwintrin.h(5144): error: identifier "__builtin_shufflevector" is undefined
__v16qi __T1 = (__v16qi)__W; __v16qi __T2 = __builtin_shufflevector (__T1, __T1, 8, 9, 10, 11, 12, 13, 14, 15, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T3 = __T1 | __T2; __v16qi __T4 = __builtin_shufflevector (__T3, __T3, 4, 5, 6, 7, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T5 = __T3 | __T4; __v16qi __T6 = __builtin_shufflevector (__T5, __T5, 2, 3, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T7 = __T5 | __T6; __v16qi __T8 = __builtin_shufflevector (__T7, __T7, 1, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15); __v16qi __T9 = __T7 | __T8; return __T9[0];
Error limit reached.
100 errors detected in the compilation of "/home/vladislavsemykin/Documents/Work/Start/src/GpuProcessing.cu".
Compilation terminated.
make[2]: *** [CMakeFiles/nia_start_core.dir/build.make:91: CMakeFiles/nia_start_core.dir/src/GpuProcessing.cu.o] Error 4
make[1]: *** [CMakeFiles/Makefile2:285: CMakeFiles/nia_start_core.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
Details:
- CUDA Toolkit Version: 12.5/12.6
- nvcc:
nvcc warning: incompatible redefinition for option 'compiler-bindir'
- Driver: NVIDIA Driver 560.35.03
- GNU GCC/G++ compilers versions: 11, 12, 13, 14
- OS: Debian-based Linux (Linux loveit 6.10.9-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.10.9-1 (2024-09-08) x86_64 GNU/Linux)
CMakeLists.txt
Here are only those parts which are related to CUDA:
set(ENV{CC} /usr/bin/gcc-13)
set(ENV{CXX} /usr/bin/g++-13)
set(ENV{CUDAHOSTCXX} /usr/bin/g++-13)
set(CMAKE_C_COMPILER gcc-13)
set(CMAKE_CXX_COMPILER g++-13)
set(CMAKE_CUDA_COMPILER nvcc)
project(...
LANGUAGES CXX CUDA)
set(CUDA_TOOLKIT_ROOT_DIR /usr/local/cuda-12.6)
set(CMAKE_CUDA_STANDARD 20)
set(CMAKE_CUDA_STANDARD_REQUIRED ON)
set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -ccbin g++-13")
message(STATUS "C Compiler: ${CMAKE_C_COMPILER}")
message(STATUS "C++ Compiler: ${CMAKE_CXX_COMPILER}")
message(STATUS "CUDA Host Compiler: ${CUDAHOSTCXX}")
message(STATUS "CUDA Compiler: ${CMAKE_CUDA_COMPILER}")
target_link_libraries(...
${CUDA_LIBRARIES}
Basic GPU info
nvidia-smi
Result:
| NVIDIA-SMI 560.35.03 Driver Version: 560.35.03 CUDA Version: 12.6 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4060 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 36C P4 14W / 30W | 15MiB / 8188MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 29559 G /usr/lib/xorg/Xorg 4MiB |
Problem
The compilation process halts due to errors in various header files for intrinsic functions (such as __builtin_ia32_ldtilecfg
, __builtin_ia32_cvtne2ps2bf16
, etc.). These errors occur with multiple versions of GCC while compiling CUDA code, specifically when using advanced instruction sets like AVX-512 and AMX.
Some observations:
- Incompatible GCC versions: Versions 11 through 14 seem to introduce errors related to undefined intrinsics when compiling CUDA code.
- nvcc warning: There’s a warning about an “incompatible redefinition for option ‘compiler-bindir’” that might indicate a conflict between nvcc and CMake configurations.
- Built-in functions: Many intrinsic functions (related to AMX and AVX-512 instructions) are not being recognized by nvcc during the build process.
Questions
- Is there a known incompatibility between CUDA Toolkit 12.5 and GCC versions 11-14, specifically regarding AVX/AMX intrinsics?
- Are there specific compiler flags or packages I should install to make these built-in functions recognized by nvcc?
- Should I downgrade to an earlier version of GCC or CUDA to resolve these issues?
- Is there a known fix or workaround to get nvcc to work with newer GCC versions and avoid these errors?
Any guidance or suggestions to resolve this would be greatly appreciated!
Thank you in advance for your help!
Best regards,
Vladislav Semykin
