Hi everybody,
I just installed CUDA 3.1 on Fedora 13 the following way:
yum install gcc kernel-devel eclipse-jdt eclipse-cdt freeglut freeglut-devel mesa-libGLU-devel libXmu-devel libXi-devel
Alt+Ctrl+F2 /sbin/init 3
./devdriver_3.1_linux_64_256.35.run
shutdown -r now
#I did yum remove kmod-nvidia previously, nouveau is blacklisted
cudatoolkit_3.1_linux_64_fedora12.run
echo "PATH=\$PATH:/usr/local/cuda/bin
LD_LIBRARY_PATH=\$LD_LIBRARY_PATH:/usr/local/cuda/lib:/usr/local/cuda/lib64
export PATH
export LD_LIBRARY_PATH" >> ~/.bashrc
gpucomputingsdk_3.1_linux.run
However,
cd /home/user/NVIDIA_GPU_Computing_SDK/C/src/fluidsGL/
make
gives me:
/usr/bin/ld: cannot find -lrendercheckgl_x86_64
collect2: ld returned 1 exit status
make: *** [../../bin/linux/release/fluidsGL] Error 1
and the other examples fail in a similar way with the same error.
Just typing nvcc gives:
nvcc �%6X: No input files specified; use option --help for more information
which seems fine to me.
I could post my /var/log/nvidia-installer.log on demand, but it’s very long and ends with
-> Driver file installation is complete.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Shared memory test passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Would you like to run the nvidia-xconfig utility to automatically update you
r X configuration file so that the NVIDIA X driver will be used when you res
tart X? Any pre-existing X configuration file will be backed up. (Answer: Y
es)
-> Your X configuration file has been successfully updated. Installation of
the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 256.35) is
now complete.
cat /proc/driver/nvidia/cards/0 prints
Model: Quadro NVS 140M
IRQ: 16
Video BIOS: 60.86.3e.00.00
Card Type: PCI-E
DMA Size: 40 bits
DMA Mask: 0xffffffffff
Bus Location: 0000:01.00.0
More important cat /proc/driver/nvidia/version:
NVRM version: NVIDIA UNIX x86_64 Kernel Module 256.35 Wed Jun 16 18:42:44 PDT 2010
GCC version: gcc version 4.4.4 20100503 (Red Hat 4.4.4-2) (GCC)
Besides other stuff my /etc/X11/xorg.conf contains
Section "Files"
ModulePath "/usr/lib64/xorg/modules/extensions/nvidia"
ModulePath "/usr/lib64/xorg/modules"
EndSection
Section "ServerFlags"
Option "AIGLX" "on"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Videocard0"
Option "AddARGBGLXVisuals" "True"
SubSection "Display"
Modes "nvidia-auto-select"
EndSubSection
EndSection
Any suggestions are highly appreciated. Thank you in advance.
Keep in mind that these are my first steps using CUDA, so I might be very naive and overlook a simple problem.
Best regards,
djjxkz2
