Hi guys,
So I just upgraded OpenCv to 3.2 on my TX1 and I was trying to run a same program I used to run with opencv 2.4.3. But When I tried cmake … the following error pops:
CMake Error at CMakeLists.txt:7 (find_package):
By not providing "FindOpenCV.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "OpenCV", but
CMake did not find one.
Could not find a package configuration file provided by "OpenCV" with any
of the following names:
OpenCVConfig.cmake
opencv-config.cmake
Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
"OpenCV_DIR" to a directory containing one of the above files. If "OpenCV"
provides a separate development package or SDK, be sure it has been
installed.
-- Configuring incomplete, errors occurred!
See also "/home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeOutput.log".
and here is my CMakeLists.txt, same as the official OpenCv Guide
cmake_minimum_required (VERSION 2.8)
set(CUDA_USE_STATIC_CUDA_RUNTIME OFF)
project(HOG_SVM)
find_package(OpenCV REQUIRED)
include_directories(${OpenCV_INCLUDE_DIRS})
add_executable(cv_HOG main.cpp)
target_link_libraries(cv_HOG ${OpenCV_LIBS})
Any ideas?
I had this same issue earlier today. I believe that OpenCV and CUDA failed to install on my device, so I’ve been trying to reflash it. Check in usr/share/ to see if there is and OpenCV/ directory. There should be if OpenCV is on your device.
By no means am I an expert. I’ve been trying to reflash my device for about 6 hours now, so take my advice with a grain of salt. Just hope I can point you in the right direction.
Thanks for your question.
Please attach “/home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeOutput.log” for us debugging.
For opencv3.2, this page can give you some hint:
http://dev.t7.ai/jetson/opencv/
Thanks for help out, here is the log file
The system is: Linux - 3.10.96-tegra - aarch64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler: /usr/bin/cc
Build flags:
Id flags:
The output was:
0
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "a.out"
The C compiler identification is GNU, found in "/home/ubuntu/works/HOG_SVM/build/CMakeFiles/3.5.1/CompilerIdC/a.out"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler: /usr/bin/c++
Build flags:
Id flags:
The output was:
0
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "a.out"
The CXX compiler identification is GNU, found in "/home/ubuntu/works/HOG_SVM/build/CMakeFiles/3.5.1/CompilerIdCXX/a.out"
Determining if the C compiler works passed with the following output:
Change Dir: /home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/make" "cmTC_f8819/fast"
/usr/bin/make -f CMakeFiles/cmTC_f8819.dir/build.make CMakeFiles/cmTC_f8819.dir/build
make[1]: Entering directory '/home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_f8819.dir/testCCompiler.c.o
/usr/bin/cc -o CMakeFiles/cmTC_f8819.dir/testCCompiler.c.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeTmp/testCCompiler.c
Linking C executable cmTC_f8819
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f8819.dir/link.txt --verbose=1
/usr/bin/cc CMakeFiles/cmTC_f8819.dir/testCCompiler.c.o -o cmTC_f8819 -rdynamic
make[1]: Leaving directory '/home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeTmp'
Detecting C compiler ABI info compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_492cd/fast"
/usr/bin/make -f CMakeFiles/cmTC_492cd.dir/build.make CMakeFiles/cmTC_492cd.dir/build
Building C object CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o
/usr/bin/cc -o CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake-3.5/Modules/CMakeCCompilerABI.c
Linking C executable cmTC_492cd
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_492cd.dir/link.txt --verbose=1
/usr/bin/cc -v CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o -o cmTC_492cd -rdynamic
Using built-in specs.
COLLECT_GCC=/usr/bin/cc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/5/lto-wrapper
Target: aarch64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-5 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-5-arm64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-5-arm64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-arm64 --with-arch-directory=aarch64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu
Thread model: posix
gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4)
COMPILER_PATH=/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/aarch64-linux-gnu/5/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-v' '-o' 'cmTC_492cd' '-rdynamic' '-mlittle-endian' '-mabi=lp64'
/usr/lib/gcc/aarch64-linux-gnu/5/collect2 -plugin /usr/lib/gcc/aarch64-linux-gnu/5/liblto_plugin.so -plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/5/lto-wrapper -plugin-opt=-fresolution=/tmp/cc5NBXLy.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --sysroot=/ --build-id --eh-frame-hdr --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib/ld-linux-aarch64.so.1 -X -EL -maarch64linux --fix-cortex-a53-843419 -z relro -o cmTC_492cd /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crt1.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crti.o /usr/lib/gcc/aarch64-linux-gnu/5/crtbegin.o -L/usr/lib/gcc/aarch64-linux-gnu/5 -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib -L/lib/aarch64-linux-gnu -L/lib/../lib -L/usr/lib/aarch64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/aarch64-linux-gnu/5/../../.. CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/aarch64-linux-gnu/5/crtend.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crtn.o
Parsed C implicit link information from above output:
link line regex: [^( *|.*[/\])(ld|([^/\]+-)?ld|collect2)[^/\]*( |$)]
ignore line: [Change Dir: /home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeTmp]
ignore line: []
ignore line: [Run Build Command:"/usr/bin/make" "cmTC_492cd/fast"]
ignore line: [/usr/bin/make -f CMakeFiles/cmTC_492cd.dir/build.make CMakeFiles/cmTC_492cd.dir/build]
ignore line: [make[1]: Entering directory '/home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeTmp']
ignore line: [Building C object CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o]
ignore line: [/usr/bin/cc -o CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake-3.5/Modules/CMakeCCompilerABI.c]
ignore line: [Linking C executable cmTC_492cd]
ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_492cd.dir/link.txt --verbose=1]
ignore line: [/usr/bin/cc -v CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o -o cmTC_492cd -rdynamic ]
ignore line: [Using built-in specs.]
ignore line: [COLLECT_GCC=/usr/bin/cc]
ignore line: [COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/5/lto-wrapper]
ignore line: [Target: aarch64-linux-gnu]
ignore line: [Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-5 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-5-arm64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-5-arm64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-arm64 --with-arch-directory=aarch64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu]
ignore line: [Thread model: posix]
ignore line: [gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ]
ignore line: [COMPILER_PATH=/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/]
ignore line: [LIBRARY_PATH=/usr/lib/gcc/aarch64-linux-gnu/5/:/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/aarch64-linux-gnu/5/../../../:/lib/:/usr/lib/]
ignore line: [COLLECT_GCC_OPTIONS='-v' '-o' 'cmTC_492cd' '-rdynamic' '-mlittle-endian' '-mabi=lp64']
link line: [ /usr/lib/gcc/aarch64-linux-gnu/5/collect2 -plugin /usr/lib/gcc/aarch64-linux-gnu/5/liblto_plugin.so -plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/5/lto-wrapper -plugin-opt=-fresolution=/tmp/cc5NBXLy.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --sysroot=/ --build-id --eh-frame-hdr --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib/ld-linux-aarch64.so.1 -X -EL -maarch64linux --fix-cortex-a53-843419 -z relro -o cmTC_492cd /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crt1.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crti.o /usr/lib/gcc/aarch64-linux-gnu/5/crtbegin.o -L/usr/lib/gcc/aarch64-linux-gnu/5 -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib -L/lib/aarch64-linux-gnu -L/lib/../lib -L/usr/lib/aarch64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/aarch64-linux-gnu/5/../../.. CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/aarch64-linux-gnu/5/crtend.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crtn.o]
arg [/usr/lib/gcc/aarch64-linux-gnu/5/collect2] ==> ignore
arg [-plugin] ==> ignore
arg [/usr/lib/gcc/aarch64-linux-gnu/5/liblto_plugin.so] ==> ignore
arg [-plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/5/lto-wrapper] ==> ignore
arg [-plugin-opt=-fresolution=/tmp/cc5NBXLy.res] ==> ignore
arg [-plugin-opt=-pass-through=-lgcc] ==> ignore
arg [-plugin-opt=-pass-through=-lgcc_s] ==> ignore
arg [-plugin-opt=-pass-through=-lc] ==> ignore
arg [--sysroot=/] ==> ignore
arg [--build-id] ==> ignore
arg [--eh-frame-hdr] ==> ignore
arg [--hash-style=gnu] ==> ignore
arg [--as-needed] ==> ignore
arg [-export-dynamic] ==> ignore
arg [-dynamic-linker] ==> ignore
arg [/lib/ld-linux-aarch64.so.1] ==> ignore
arg [-X] ==> ignore
arg [-EL] ==> ignore
arg [-maarch64linux] ==> ignore
arg [--fix-cortex-a53-843419] ==> ignore
arg [-zrelro] ==> ignore
arg [-o] ==> ignore
arg [cmTC_492cd] ==> ignore
arg [/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crt1.o] ==> ignore
arg [/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crti.o] ==> ignore
arg [/usr/lib/gcc/aarch64-linux-gnu/5/crtbegin.o] ==> ignore
arg [-L/usr/lib/gcc/aarch64-linux-gnu/5] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/5]
arg [-L/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu]
arg [-L/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib]
arg [-L/lib/aarch64-linux-gnu] ==> dir [/lib/aarch64-linux-gnu]
arg [-L/lib/../lib] ==> dir [/lib/../lib]
arg [-L/usr/lib/aarch64-linux-gnu] ==> dir [/usr/lib/aarch64-linux-gnu]
arg [-L/usr/lib/../lib] ==> dir [/usr/lib/../lib]
arg [-L/usr/lib/gcc/aarch64-linux-gnu/5/../../..] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/5/../../..]
arg [CMakeFiles/cmTC_492cd.dir/CMakeCCompilerABI.c.o] ==> ignore
arg [-lgcc] ==> lib [gcc]
arg [-lgcc_s] ==> lib [gcc_s]
arg [--no-as-needed] ==> ignore
arg [-lc] ==> lib [c]
arg [/usr/lib/gcc/aarch64-linux-gnu/5/crtend.o] ==> ignore
arg [/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crtn.o] ==> ignore
remove lib [gcc]
remove lib [gcc_s]
remove lib [gcc]
remove lib [gcc_s]
collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/5] ==> [/usr/lib/gcc/aarch64-linux-gnu/5]
collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu] ==> [/usr/lib/aarch64-linux-gnu]
collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib] ==> [/usr/lib]
collapse library dir [/lib/aarch64-linux-gnu] ==> [/lib/aarch64-linux-gnu]
collapse library dir [/lib/../lib] ==> [/lib]
collapse library dir [/usr/lib/aarch64-linux-gnu] ==> [/usr/lib/aarch64-linux-gnu]
collapse library dir [/usr/lib/../lib] ==> [/usr/lib]
collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/5/../../..] ==> [/usr/lib]
implicit libs: [c]
implicit dirs: [/usr/lib/gcc/aarch64-linux-gnu/5;/usr/lib/aarch64-linux-gnu;/usr/lib;/lib/aarch64-linux-gnu;/lib]
implicit fwks: []
Detecting C [-std=c11] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_1514f/fast"
/usr/bin/make -f CMakeFiles/cmTC_1514f.dir/build.make CMakeFiles/cmTC_1514f.dir/build
Building C object CMakeFiles/cmTC_1514f.dir/feature_tests.c.o
/usr/bin/cc -std=c11 -o CMakeFiles/cmTC_1514f.dir/feature_tests.c.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/feature_tests.c
Linking C executable cmTC_1514f
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_1514f.dir/link.txt --verbose=1
/usr/bin/cc CMakeFiles/cmTC_1514f.dir/feature_tests.c.o -o cmTC_1514f -rdynamic
Feature record: C_FEATURE:1c_function_prototypes
Feature record: C_FEATURE:1c_restrict
Feature record: C_FEATURE:1c_static_assert
Feature record: C_FEATURE:1c_variadic_macros
Detecting C [-std=c99] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_bfbea/fast"
/usr/bin/make -f CMakeFiles/cmTC_bfbea.dir/build.make CMakeFiles/cmTC_bfbea.dir/build
Building C object CMakeFiles/cmTC_bfbea.dir/feature_tests.c.o
/usr/bin/cc -std=c99 -o CMakeFiles/cmTC_bfbea.dir/feature_tests.c.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/feature_tests.c
Linking C executable cmTC_bfbea
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_bfbea.dir/link.txt --verbose=1
/usr/bin/cc CMakeFiles/cmTC_bfbea.dir/feature_tests.c.o -o cmTC_bfbea -rdynamic
Feature record: C_FEATURE:0c_static_assert
Detecting C [-std=c90] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_ec309/fast"
/usr/bin/make -f CMakeFiles/cmTC_ec309.dir/build.make CMakeFiles/cmTC_ec309.dir/build
Building C object CMakeFiles/cmTC_ec309.dir/feature_tests.c.o
/usr/bin/cc -std=c90 -o CMakeFiles/cmTC_ec309.dir/feature_tests.c.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/feature_tests.c
Linking C executable cmTC_ec309
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_ec309.dir/link.txt --verbose=1
/usr/bin/cc CMakeFiles/cmTC_ec309.dir/feature_tests.c.o -o cmTC_ec309 -rdynamic
Feature record: C_FEATURE:0c_restrict
Feature record: C_FEATURE:0c_variadic_macros
Determining if the CXX compiler works passed with the following output:
Run Build Command:"/usr/bin/make" "cmTC_ff55f/fast"
/usr/bin/make -f CMakeFiles/cmTC_ff55f.dir/build.make CMakeFiles/cmTC_ff55f.dir/build
Building CXX object CMakeFiles/cmTC_ff55f.dir/testCXXCompiler.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTC_ff55f.dir/testCXXCompiler.cxx.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
Linking CXX executable cmTC_ff55f
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_ff55f.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTC_ff55f.dir/testCXXCompiler.cxx.o -o cmTC_ff55f -rdynamic
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_77d21/fast"
/usr/bin/make -f CMakeFiles/cmTC_77d21.dir/build.make CMakeFiles/cmTC_77d21.dir/build
Building CXX object CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o
/usr/bin/c++ -o CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake-3.5/Modules/CMakeCXXCompilerABI.cpp
Linking CXX executable cmTC_77d21
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_77d21.dir/link.txt --verbose=1
/usr/bin/c++ -v CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o -o cmTC_77d21 -rdynamic
COLLECT_GCC=/usr/bin/c++
Thread model: posix
COLLECT_GCC_OPTIONS='-v' '-o' 'cmTC_77d21' '-rdynamic' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64'
/usr/lib/gcc/aarch64-linux-gnu/5/collect2 -plugin /usr/lib/gcc/aarch64-linux-gnu/5/liblto_plugin.so -plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/5/lto-wrapper -plugin-opt=-fresolution=/tmp/ccSIMsfZ.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --sysroot=/ --build-id --eh-frame-hdr --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib/ld-linux-aarch64.so.1 -X -EL -maarch64linux --fix-cortex-a53-843419 -z relro -o cmTC_77d21 /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crt1.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crti.o /usr/lib/gcc/aarch64-linux-gnu/5/crtbegin.o -L/usr/lib/gcc/aarch64-linux-gnu/5 -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib -L/lib/aarch64-linux-gnu -L/lib/../lib -L/usr/lib/aarch64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/aarch64-linux-gnu/5/../../.. CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/aarch64-linux-gnu/5/crtend.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crtn.o
Parsed CXX implicit link information from above output:
ignore line: []
ignore line: [Run Build Command:"/usr/bin/make" "cmTC_77d21/fast"]
ignore line: [/usr/bin/make -f CMakeFiles/cmTC_77d21.dir/build.make CMakeFiles/cmTC_77d21.dir/build]
ignore line: [Building CXX object CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o]
ignore line: [/usr/bin/c++ -o CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake-3.5/Modules/CMakeCXXCompilerABI.cpp]
ignore line: [Linking CXX executable cmTC_77d21]
ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_77d21.dir/link.txt --verbose=1]
ignore line: [/usr/bin/c++ -v CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o -o cmTC_77d21 -rdynamic ]
ignore line: [COLLECT_GCC=/usr/bin/c++]
ignore line: [COLLECT_GCC_OPTIONS='-v' '-o' 'cmTC_77d21' '-rdynamic' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64']
link line: [ /usr/lib/gcc/aarch64-linux-gnu/5/collect2 -plugin /usr/lib/gcc/aarch64-linux-gnu/5/liblto_plugin.so -plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/5/lto-wrapper -plugin-opt=-fresolution=/tmp/ccSIMsfZ.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --sysroot=/ --build-id --eh-frame-hdr --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib/ld-linux-aarch64.so.1 -X -EL -maarch64linux --fix-cortex-a53-843419 -z relro -o cmTC_77d21 /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crt1.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crti.o /usr/lib/gcc/aarch64-linux-gnu/5/crtbegin.o -L/usr/lib/gcc/aarch64-linux-gnu/5 -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu -L/usr/lib/gcc/aarch64-linux-gnu/5/../../../../lib -L/lib/aarch64-linux-gnu -L/lib/../lib -L/usr/lib/aarch64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/aarch64-linux-gnu/5/../../.. CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/aarch64-linux-gnu/5/crtend.o /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/crtn.o]
arg [-plugin-opt=-fresolution=/tmp/ccSIMsfZ.res] ==> ignore
arg [-X] ==> ignore
arg [-o] ==> ignore
arg [cmTC_77d21] ==> ignore
arg [CMakeFiles/cmTC_77d21.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
arg [-lstdc++] ==> lib [stdc++]
arg [-lm] ==> lib [m]
remove lib [gcc_s]
remove lib [gcc]
remove lib [gcc_s]
remove lib [gcc]
implicit libs: [stdc++;m;c]
implicit fwks: []
Detecting CXX [-std=c++14] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_a2cb2/fast"
/usr/bin/make -f CMakeFiles/cmTC_a2cb2.dir/build.make CMakeFiles/cmTC_a2cb2.dir/build
Building CXX object CMakeFiles/cmTC_a2cb2.dir/feature_tests.cxx.o
/usr/bin/c++ -std=c++14 -o CMakeFiles/cmTC_a2cb2.dir/feature_tests.cxx.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_a2cb2
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_a2cb2.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTC_a2cb2.dir/feature_tests.cxx.o -o cmTC_a2cb2 -rdynamic
Feature record: CXX_FEATURE:1cxx_aggregate_default_initializers
Feature record: CXX_FEATURE:1cxx_alias_templates
Feature record: CXX_FEATURE:1cxx_alignas
Feature record: CXX_FEATURE:1cxx_alignof
Feature record: CXX_FEATURE:1cxx_attributes
Feature record: CXX_FEATURE:1cxx_attribute_deprecated
Feature record: CXX_FEATURE:1cxx_auto_type
Feature record: CXX_FEATURE:1cxx_binary_literals
Feature record: CXX_FEATURE:1cxx_constexpr
Feature record: CXX_FEATURE:1cxx_contextual_conversions
Feature record: CXX_FEATURE:1cxx_decltype
Feature record: CXX_FEATURE:1cxx_decltype_auto
Feature record: CXX_FEATURE:1cxx_decltype_incomplete_return_types
Feature record: CXX_FEATURE:1cxx_default_function_template_args
Feature record: CXX_FEATURE:1cxx_defaulted_functions
Feature record: CXX_FEATURE:1cxx_defaulted_move_initializers
Feature record: CXX_FEATURE:1cxx_delegating_constructors
Feature record: CXX_FEATURE:1cxx_deleted_functions
Feature record: CXX_FEATURE:1cxx_digit_separators
Feature record: CXX_FEATURE:1cxx_enum_forward_declarations
Feature record: CXX_FEATURE:1cxx_explicit_conversions
Feature record: CXX_FEATURE:1cxx_extended_friend_declarations
Feature record: CXX_FEATURE:1cxx_extern_templates
Feature record: CXX_FEATURE:1cxx_final
Feature record: CXX_FEATURE:1cxx_func_identifier
Feature record: CXX_FEATURE:1cxx_generalized_initializers
Feature record: CXX_FEATURE:1cxx_generic_lambdas
Feature record: CXX_FEATURE:1cxx_inheriting_constructors
Feature record: CXX_FEATURE:1cxx_inline_namespaces
Feature record: CXX_FEATURE:1cxx_lambdas
Feature record: CXX_FEATURE:1cxx_lambda_init_captures
Feature record: CXX_FEATURE:1cxx_local_type_template_args
Feature record: CXX_FEATURE:1cxx_long_long_type
Feature record: CXX_FEATURE:1cxx_noexcept
Feature record: CXX_FEATURE:1cxx_nonstatic_member_init
Feature record: CXX_FEATURE:1cxx_nullptr
Feature record: CXX_FEATURE:1cxx_override
Feature record: CXX_FEATURE:1cxx_range_for
Feature record: CXX_FEATURE:1cxx_raw_string_literals
Feature record: CXX_FEATURE:1cxx_reference_qualified_functions
Feature record: CXX_FEATURE:1cxx_relaxed_constexpr
Feature record: CXX_FEATURE:1cxx_return_type_deduction
Feature record: CXX_FEATURE:1cxx_right_angle_brackets
Feature record: CXX_FEATURE:1cxx_rvalue_references
Feature record: CXX_FEATURE:1cxx_sizeof_member
Feature record: CXX_FEATURE:1cxx_static_assert
Feature record: CXX_FEATURE:1cxx_strong_enums
Feature record: CXX_FEATURE:1cxx_template_template_parameters
Feature record: CXX_FEATURE:1cxx_thread_local
Feature record: CXX_FEATURE:1cxx_trailing_return_types
Feature record: CXX_FEATURE:1cxx_unicode_literals
Feature record: CXX_FEATURE:1cxx_uniform_initialization
Feature record: CXX_FEATURE:1cxx_unrestricted_unions
Feature record: CXX_FEATURE:1cxx_user_literals
Feature record: CXX_FEATURE:1cxx_variable_templates
Feature record: CXX_FEATURE:1cxx_variadic_macros
Feature record: CXX_FEATURE:1cxx_variadic_templates
Detecting CXX [-std=c++11] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_9cb22/fast"
/usr/bin/make -f CMakeFiles/cmTC_9cb22.dir/build.make CMakeFiles/cmTC_9cb22.dir/build
Building CXX object CMakeFiles/cmTC_9cb22.dir/feature_tests.cxx.o
/usr/bin/c++ -std=c++11 -o CMakeFiles/cmTC_9cb22.dir/feature_tests.cxx.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_9cb22
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_9cb22.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTC_9cb22.dir/feature_tests.cxx.o -o cmTC_9cb22 -rdynamic
Feature record: CXX_FEATURE:0cxx_aggregate_default_initializers
Feature record: CXX_FEATURE:0cxx_attribute_deprecated
Feature record: CXX_FEATURE:0cxx_binary_literals
Feature record: CXX_FEATURE:0cxx_contextual_conversions
Feature record: CXX_FEATURE:0cxx_decltype_auto
Feature record: CXX_FEATURE:0cxx_digit_separators
Feature record: CXX_FEATURE:0cxx_generic_lambdas
Feature record: CXX_FEATURE:0cxx_lambda_init_captures
Feature record: CXX_FEATURE:0cxx_relaxed_constexpr
Feature record: CXX_FEATURE:0cxx_return_type_deduction
Feature record: CXX_FEATURE:0cxx_variable_templates
Detecting CXX [-std=c++98] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_f23e0/fast"
/usr/bin/make -f CMakeFiles/cmTC_f23e0.dir/build.make CMakeFiles/cmTC_f23e0.dir/build
Building CXX object CMakeFiles/cmTC_f23e0.dir/feature_tests.cxx.o
/usr/bin/c++ -std=c++98 -o CMakeFiles/cmTC_f23e0.dir/feature_tests.cxx.o -c /home/ubuntu/works/HOG_SVM/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_f23e0
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f23e0.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTC_f23e0.dir/feature_tests.cxx.o -o cmTC_f23e0 -rdynamic
Feature record: CXX_FEATURE:0cxx_alias_templates
Feature record: CXX_FEATURE:0cxx_alignas
Feature record: CXX_FEATURE:0cxx_alignof
Feature record: CXX_FEATURE:0cxx_attributes
Feature record: CXX_FEATURE:0cxx_auto_type
Feature record: CXX_FEATURE:0cxx_constexpr
Feature record: CXX_FEATURE:0cxx_decltype_incomplete_return_types
Feature record: CXX_FEATURE:0cxx_default_function_template_args
Feature record: CXX_FEATURE:0cxx_defaulted_functions
Feature record: CXX_FEATURE:0cxx_defaulted_move_initializers
Feature record: CXX_FEATURE:0cxx_delegating_constructors
Feature record: CXX_FEATURE:0cxx_deleted_functions
Feature record: CXX_FEATURE:0cxx_enum_forward_declarations
Feature record: CXX_FEATURE:0cxx_explicit_conversions
Feature record: CXX_FEATURE:0cxx_extended_friend_declarations
Feature record: CXX_FEATURE:0cxx_extern_templates
Feature record: CXX_FEATURE:0cxx_final
Feature record: CXX_FEATURE:0cxx_func_identifier
Feature record: CXX_FEATURE:0cxx_generalized_initializers
Feature record: CXX_FEATURE:0cxx_inheriting_constructors
Feature record: CXX_FEATURE:0cxx_inline_namespaces
Feature record: CXX_FEATURE:0cxx_lambdas
Feature record: CXX_FEATURE:0cxx_local_type_template_args
Feature record: CXX_FEATURE:0cxx_long_long_type
Feature record: CXX_FEATURE:0cxx_noexcept
Feature record: CXX_FEATURE:0cxx_nonstatic_member_init
Feature record: CXX_FEATURE:0cxx_nullptr
Feature record: CXX_FEATURE:0cxx_override
Feature record: CXX_FEATURE:0cxx_range_for
Feature record: CXX_FEATURE:0cxx_raw_string_literals
Feature record: CXX_FEATURE:0cxx_reference_qualified_functions
Feature record: CXX_FEATURE:0cxx_right_angle_brackets
Feature record: CXX_FEATURE:0cxx_rvalue_references
Feature record: CXX_FEATURE:0cxx_sizeof_member
Feature record: CXX_FEATURE:0cxx_static_assert
Feature record: CXX_FEATURE:0cxx_strong_enums
Feature record: CXX_FEATURE:0cxx_thread_local
Feature record: CXX_FEATURE:0cxx_trailing_return_types
Feature record: CXX_FEATURE:0cxx_unicode_literals
Feature record: CXX_FEATURE:0cxx_uniform_initialization
Feature record: CXX_FEATURE:0cxx_unrestricted_unions
Feature record: CXX_FEATURE:0cxx_user_literals
Feature record: CXX_FEATURE:0cxx_variadic_macros
Feature record: CXX_FEATURE:0cxx_variadic_templates
Hi thanks for the help,
Any luck with your opencv? Mine’s still not working
One possible cause is that your app’s cmake config uses pkg-config to get opencv paths, and if you have removed the 2.4 package these can’t be found.
Assuming you’ve installed opencv-3.2.0 in /usr/local/opencv-3.2.0, using
cmake -DOpenCV_DIR=/usr/local/opencv-3.2.0 ...and other cmake options for your app
for configuring your app build may help you to get further.
Be aware however that there are a few differences in opencv3 API, include files and libraries, that you may have to adjust as compared to opencv-2.4.
cmake -DOpenCV_DIR /usr/local.opencv-3.2.0 ...and other cmake options for your app
Thanks for the reply,
So I have located the OpenCVConfig.cmake file in
/home/ubuntu/opencv3.2.0/share/OpenCV
And I used this command
cmake -D CMAKE_PREFIX_PATH=/home/ubuntu/opencv3.2.0/share/OpenCV
But I am still not able to run my own code. Do I need to re make -j4 the whole Opencv?
The question would be what was your setting to CMAKE_INSTALL_PREFIX when configuring your opencv-3.2.0 build, and if after building with
make
if you’ve installed with
sudo make install
Is /home/ubuntu/opencv3.2.0/share/OpenCV the path to your opencv-3.2.0 sources or the install path ?
If you’ve set
cmake -DCMAKE_PREFIX_PATH=/home/ubuntu/opencv3.2.0/share/OpenCV
when configuring opencv-3.2.0, then run make successfuly in opencv-3.2.0 build directory and then sudo make install, then
ls /home/ubuntu/opencv3.2.0/share/OpenCV/lib
should show the opencv3 libraries.
Then configuring your app with
cmake -DOpenCV_DIR<b>=</b>/home/ubuntu/opencv3.2.0/share/OpenCV
may help.
Thanks for your feedback.
I tried your cmake file and can build and run without the error.
Based on CMakeCache, cmake looks for opencv from ‘/usr/local/share/opencv’
//The directory containing a CMake configuration file for OpenCV.
OpenCV_DIR:PATH=/usr/local/share/OpenCV
Please make sure you have installed opencv to /usr/local/share/opencv.
This should be done via this command when building opencv3.2.0:
sudo make install
Please let us know the results.
Hi yall,
So finally it worked with
make -D OpenCV_DIR=/home/ubuntu/opencv-3.2.0/share/OpenCV ..
But I have to manually type this every time I use cmake now. Here is what I put in my CMakeLists.txt file, not sure why this won’t work
set(OpenCV_DIR=/home/opencv-3.2.0/share/OpenCV)
project(PED_STUDY)
add_executable(cv_PED main.cpp)
target_link_libraries(cv_PED ${OpenCV_LIBS})
Does anyine know how to modify the CMakeLists.txt so that I don’t need to retype each and every time?
Hi yall,
project(PED_STUDY)
you may change :
to
set(OpenCV_DIR=/home/ubuntu/opencv-3.2.0/share/OpenCV)
OMG!I’m soooo stupid. Thanks for point out!:)
