Build OpenCV with CUDA accelerated on PX2 failed
I’m trying to build OpenCV with CUDA accelerated on PX2 board,
follow the step as below link to compile,
http://docs.opencv.org/master/d6/d15/tutorial_building_tegra_cuda.html
but it always compile failed, I found that because “opencv/build/modules/python2/header.txt” is empty!
Is OpenCV3.1.0 have compatibility problem with PX2 or CUDA-8.0?.
Does anyone have any idea?
My environment :
Operating system: Ubuntu 16.04 LTS
Compiler: gcc 5.4.0
CUDA version (if applicable): cuda-8.0
CUDNN version (if applicable): cuDNN v.6
OpenCV version : 3.2.0
thanks!
Hello Vincent_CH_Wu,
Please see below link for OpenCV installation on DPX2. Thanks.
Hi Steve,
Thanks for your reply,
I’m follow the step the below link you provide, but the problem are still exist!
the file “opencv/build/modules/python2/header.txt” is empty!
Do you have any idea?
thanks!
Dear Vincent_CH_Wu,
Could you let me know your compilation step in detail or log? I will take a look your compilation step. Thanks.
Hi Steve,
I was follow the step with below link,
http://docs.opencv.org/3.2.0/d6/d15/tutorial_building_tegra_cuda.html
  1. Clone the opencv repository locally:
    $ git clone GitHub - opencv/opencv: Open Source Computer Vision Library
  2. Check out to 3.1.0
    $ cd opencv
    $ git checkout -b v3.1.0 3.1.0
  3. Cherry pick some necessary patch.
    $ git cherry-pick 10896
    $ git cherry-pick cdb9c
    $ git cherry-pick 24dbb
  4. Clone the opencv_extra reoisitory.
    $ cd …
    $ git clone GitHub - opencv/opencv_extra: OpenCV extra data
    $ cd opencv_extra
  5. Check out to 3.1.0
  6. cmake configuration
    $ cd …/opencv
    $ mkdir build
    $ cd build
    $ cmake
    -DCMAKE_BUILD_TYPE=Release
    -DCMAKE_INSTALL_PREFIX=/home/nvidia/vincent/opencv_cuda_lib/opencv-lib
    -DBUILD_PNG=OFF
    -DBUILD_TIFF=OFF
    -DBUILD_TBB=OFF
    -DBUILD_JPEG=OFF
    -DBUILD_JASPER=OFF
    -DBUILD_ZLIB=OFF
    -DBUILD_EXAMPLES=ON
    -DBUILD_opencv_java=OFF
    -DBUILD_opencv_python2=ON
    -DBUILD_opencv_python3=OFF
    -DENABLE_NEON=ON
    -DWITH_OPENCL=OFF
    -DWITH_OPENMP=OFF
    -DWITH_FFMPEG=ON
    -DWITH_GSTREAMER=OFF
    -DWITH_GSTREAMER_0_10=OFF
    -DWITH_CUDA=ON
    -DWITH_GTK=ON
    -DWITH_VTK=OFF
    -DWITH_TBB=ON
    -DWITH_1394=OFF
    -DWITH_OPENEXR=OFF
    -DCUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-8.0
    -DCUDA_ARCH_BIN=‘6.1 6.2’
    -DCUDA_ARCH_PTX=“”
    -DINSTALL_C_EXAMPLES=ON
    -DINSTALL_TESTS=OFF
    -DOPENCV_TEST_DATA_PATH=…/opencv_extra/testdata
  7. compile
    $ make -j1
an error occurred,
File “/home/nvidia/vincent/opencv_cuda_lib/opencv/modules/python/python2/…//src2/gen2.py”, line 954, in
generator.gen(srcfiles, dstdir)
File “/home/nvidia/vincent/opencv_cuda_lib/opencv/modules/python/python2/…//src2/gen2.py”, line 852, in gen
decls = self.parser.parse(hdr)
File “/home/nvidia/vincent/opencv_cuda_lib/opencv/modules/python/src2/hdr_parser.py”, line 762, in parse
f = io.open(hname, ‘rt’, encoding=‘utf-8’)
IOError: [Errno 2] No such file or directory: ‘…/core/include/opencv2/core.hpp’
modules/python2/CMakeFiles/opencv_python2.dir/build.make:63: recipe for target ‘modules/python2/pyopencv_generated_include.h’ failed
make[2]: *** [modules/python2/pyopencv_generated_include.h] Error 1
Hi Steve,
Do you have any idea with my compilation step?
thanks!
Dear Vincent_CH_Wu,
I already checked the step and successfully installed OpenCV on my DPX2.
One thing, could you please re-try it with default option first? Thanks.
[b]=> -DCMAKE_INSTALL_PREFIX=/usr [/b]
I am following the same steps with cuda 9.0 on DPX2(replaced cuda8.0 → cuda 9.0). I am getting the following error
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUDA_nppi_LIBRARY (ADVANCED)
    linked by target "opencv_cudev" in directory /home/nvidia/opencv/modules/cudev
    linked by target "opencv_test_cudev" in directory /home/nvidia/opencv/modules/cudev/test
    linked by target "opencv_core" in directory /home/nvidia/opencv/modules/core
    linked by target "opencv_test_core" in directory /home/nvidia/opencv/modules/core
    linked by target "opencv_perf_core" in directory /home/nvidia/opencv/modules/core
    linked by target "opencv_perf_cudaarithm" in directory /home/nvidia/opencv/modules/cudaarithm
    linked by target "opencv_cudaarithm" in directory /home/nvidia/opencv/modules/cudaarithm
    linked by target "opencv_test_cudaarithm" in directory /home/nvidia/opencv/modules/cudaarithm
    linked by target "opencv_flann" in directory /home/nvidia/opencv/modules/flann
    linked by target "opencv_test_flann" in directory /home/nvidia/opencv/modules/flann
    linked by target "opencv_imgproc" in directory /home/nvidia/opencv/modules/imgproc
    linked by target "opencv_test_imgproc" in directory /home/nvidia/opencv/modules/imgproc
    linked by target "opencv_perf_imgproc" in directory /home/nvidia/opencv/modules/imgproc
    linked by target "opencv_ml" in directory /home/nvidia/opencv/modules/ml
    linked by target "opencv_test_ml" in directory /home/nvidia/opencv/modules/ml
    linked by target "opencv_video" in directory /home/nvidia/opencv/modules/video
    linked by target "opencv_test_video" in directory /home/nvidia/opencv/modules/video
    linked by target "opencv_perf_video" in directory /home/nvidia/opencv/modules/video
    linked by target "opencv_cudabgsegm" in directory /home/nvidia/opencv/modules/cudabgsegm
    linked by target "opencv_test_cudabgsegm" in directory /home/nvidia/opencv/modules/cudabgsegm
    linked by target "opencv_perf_cudabgsegm" in directory /home/nvidia/opencv/modules/cudabgsegm
    linked by target "opencv_cudafilters" in directory /home/nvidia/opencv/modules/cudafilters
    linked by target "opencv_test_cudafilters" in directory /home/nvidia/opencv/modules/cudafilters
    linked by target "opencv_perf_cudafilters" in directory /home/nvidia/opencv/modules/cudafilters
    linked by target "opencv_cudaimgproc" in directory /home/nvidia/opencv/modules/cudaimgproc
    linked by target "opencv_test_cudaimgproc" in directory /home/nvidia/opencv/modules/cudaimgproc
    linked by target "opencv_perf_cudaimgproc" in directory /home/nvidia/opencv/modules/cudaimgproc
    linked by target "opencv_cudawarping" in directory /home/nvidia/opencv/modules/cudawarping
    linked by target "opencv_test_cudawarping" in directory /home/nvidia/opencv/modules/cudawarping
    linked by target "opencv_perf_cudawarping" in directory /home/nvidia/opencv/modules/cudawarping
    linked by target "opencv_test_imgcodecs" in directory /home/nvidia/opencv/modules/imgcodecs
    linked by target "opencv_imgcodecs" in directory /home/nvidia/opencv/modules/imgcodecs
    linked by target "opencv_perf_imgcodecs" in directory /home/nvidia/opencv/modules/imgcodecs
    linked by target "opencv_test_photo" in directory /home/nvidia/opencv/modules/photo
    linked by target "opencv_photo" in directory /home/nvidia/opencv/modules/photo
    linked by target "opencv_perf_photo" in directory /home/nvidia/opencv/modules/photo
    linked by target "opencv_shape" in directory /home/nvidia/opencv/modules/shape
    linked by target "opencv_test_shape" in directory /home/nvidia/opencv/modules/shape
    linked by target "opencv_videoio" in directory /home/nvidia/opencv/modules/videoio
    linked by target "opencv_test_videoio" in directory /home/nvidia/opencv/modules/videoio
    linked by target "opencv_perf_videoio" in directory /home/nvidia/opencv/modules/videoio
    linked by target "opencv_test_cudacodec" in directory /home/nvidia/opencv/modules/cudacodec
    linked by target "opencv_cudacodec" in directory /home/nvidia/opencv/modules/cudacodec
    linked by target "opencv_perf_cudacodec" in directory /home/nvidia/opencv/modules/cudacodec
    linked by target "opencv_test_highgui" in directory /home/nvidia/opencv/modules/highgui
    linked by target "opencv_highgui" in directory /home/nvidia/opencv/modules/highgui
    linked by target "opencv_objdetect" in directory /home/nvidia/opencv/modules/objdetect
    linked by target "opencv_perf_objdetect" in directory /home/nvidia/opencv/modules/objdetect
    linked by target "opencv_test_objdetect" in directory /home/nvidia/opencv/modules/objdetect
    linked by target "opencv_ts" in directory /home/nvidia/opencv/modules/ts
    linked by target "opencv_features2d" in directory /home/nvidia/opencv/modules/features2d
    linked by target "opencv_test_features2d" in directory /home/nvidia/opencv/modules/features2d
    linked by target "opencv_perf_features2d" in directory /home/nvidia/opencv/modules/features2d
    linked by target "opencv_test_calib3d" in directory /home/nvidia/opencv/modules/calib3d
    linked by target "opencv_calib3d" in directory /home/nvidia/opencv/modules/calib3d
    linked by target "opencv_perf_calib3d" in directory /home/nvidia/opencv/modules/calib3d
    linked by target "opencv_perf_cudafeatures2d" in directory /home/nvidia/opencv/modules/cudafeatures2d
    linked by target "opencv_cudafeatures2d" in directory /home/nvidia/opencv/modules/cudafeatures2d
    linked by target "opencv_test_cudafeatures2d" in directory /home/nvidia/opencv/modules/cudafeatures2d
    linked by target "opencv_cudalegacy" in directory /home/nvidia/opencv/modules/cudalegacy
    linked by target "opencv_test_cudalegacy" in directory /home/nvidia/opencv/modules/cudalegacy
    linked by target "opencv_perf_cudalegacy" in directory /home/nvidia/opencv/modules/cudalegacy
    linked by target "opencv_perf_cudaobjdetect" in directory /home/nvidia/opencv/modules/cudaobjdetect
    linked by target "opencv_cudaobjdetect" in directory /home/nvidia/opencv/modules/cudaobjdetect
    linked by target "opencv_test_cudaobjdetect" in directory /home/nvidia/opencv/modules/cudaobjdetect
    linked by target "opencv_cudaoptflow" in directory /home/nvidia/opencv/modules/cudaoptflow
    linked by target "opencv_test_cudaoptflow" in directory /home/nvidia/opencv/modules/cudaoptflow
    linked by target "opencv_perf_cudaoptflow" in directory /home/nvidia/opencv/modules/cudaoptflow
    linked by target "opencv_perf_cudastereo" in directory /home/nvidia/opencv/modules/cudastereo
    linked by target "opencv_cudastereo" in directory /home/nvidia/opencv/modules/cudastereo
    linked by target "opencv_test_cudastereo" in directory /home/nvidia/opencv/modules/cudastereo
    linked by target "opencv_test_stitching" in directory /home/nvidia/opencv/modules/stitching
    linked by target "opencv_perf_stitching" in directory /home/nvidia/opencv/modules/stitching
    linked by target "opencv_stitching" in directory /home/nvidia/opencv/modules/stitching
    linked by target "opencv_superres" in directory /home/nvidia/opencv/modules/superres
    linked by target "opencv_test_superres" in directory /home/nvidia/opencv/modules/superres
    linked by target "opencv_perf_superres" in directory /home/nvidia/opencv/modules/superres
    linked by target "opencv_videostab" in directory /home/nvidia/opencv/modules/videostab
    linked by target "opencv_traincascade" in directory /home/nvidia/opencv/apps/traincascade
    linked by target "opencv_createsamples" in directory /home/nvidia/opencv/apps/createsamples
    linked by target "opencv_annotation" in directory /home/nvidia/opencv/apps/annotation
    linked by target "cpp-tutorial-pnp_detection" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_watershed" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_tvl1_optical_flow" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_LATCH_match" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_cloning_gui" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_decolor" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_objectDetection2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_objectDetection" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_non_linear_svms" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_introduction_to_svm" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_introduction_to_pca" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_introduction_windows_vs" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_AKAZE_match" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_mat_mask_operations" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_interoperability_with_OpenCV_1" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_file_input_output" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_discrete_fourier_transform" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Drawing_2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_camera_calibration" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_cornerSubPix_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_hull_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_generalContours_demo1" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_findContours_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_cloning_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_imageSegmentation" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_filter2D_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_logistic_regression" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_mask_tmpl" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_edge" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_stereo_calib" in directory /home/nvidia/opencv/samples/cpp
    linked by target "cpp-tutorial-pnp_registration" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_lsd_lines" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_minarea" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_intelperc_capture" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_detect_blob" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_imagelist_creator" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_planar_tracking" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Morphology_1" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_display_image" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_kalman" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_image_sequence" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_CannyDetector_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Laplace_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_hdr_imaging" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_polar_transforms" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_image" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_houghlines" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_kmeans" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_houghcircles" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_filestorage" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_ffilldemo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_mat_the_basic_image_container" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_lkdemo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_pointPolygonTest_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_fback" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_stitching_detailed" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_fitellipse" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_facedetect" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Smoothing" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_connected_components" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_cloning_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_letter_recog" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_moments_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_dbt_face_detection" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_camshiftdemo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_pca" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_bg_sub" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_stitching" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_autofocus" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_contours2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_HoughLines_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_detect_mser" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_phase_corr" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_cornerHarris_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_compareHist_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_facial_features" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_starter_video" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_convexhull" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_dft" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_calibration" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_inpaint" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_generalContours_demo2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_create_mask" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_npr_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Morphology_3" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_starter_imagelist" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_cornerDetector_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_select3dobj" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_bgfg_segm" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_tree_engine" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_grabcut" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_video-write" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_delaunay2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Geometric_Transforms_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_laplace" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_calcBackProject_Demo1" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Drawing_1" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_example" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_distrans" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_image_alignment" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_EqualizeHist_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_videostab" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_video-input-psnr-ssim" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_matchmethod_orb_akaze_brisk" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_npr_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_morphology2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_gpu-basics-similarity" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_opencv_version" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_how_to_scan_images" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_openni_capture" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_BasicLinearTransformsTrackbar" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_demhist" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_train_HOG" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_points_classifier" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_3calibration" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_segment_objects" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_shape_example" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_SBM_Sample" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_squares" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_stereo_match" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_goodFeaturesToTrack_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_BasicLinearTransforms" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_copyMakeBorder_demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_cloning_gui" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_AddingImagesTrackbar" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_gdal-image" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_calcBackProject_Demo2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_em" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_calcHist_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_cout_mat" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_AddingImages" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Morphology_2" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_smiledetect" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Remap_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Pyramids" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Threshold" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_HoughCircle_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_MatchTemplate_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_drawing" in directory /home/nvidia/opencv/samples/cpp
    linked by target "tutorial_Sobel_Demo" in directory /home/nvidia/opencv/samples/cpp
    linked by target "example_gpu_hog" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_generalized_hough" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_houghlines" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_optical_flow" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_alpha_comp" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_bgfg_segm" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_morphology" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_surf_keypoint_matcher" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_video_reader" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_farneback_optical_flow" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_performance" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_stereo_multi" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_opticalflow_nvidia_api" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_driver_api_multi" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_cascadeclassifier_nvidia_api" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_pyrlk_optical_flow" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_stereo_match" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_driver_api_stereo_multi" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_cascadeclassifier" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_super_resolution" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_multi" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_gpu_video_writer" in directory /home/nvidia/opencv/samples/gpu
    linked by target "example_tapi_hog" in directory /home/nvidia/opencv/samples/tapi
    linked by target "example_tapi_camshift" in directory /home/nvidia/opencv/samples/tapi
    linked by target "example_tapi_bgfg_segm" in directory /home/nvidia/opencv/samples/tapi
    linked by target "example_tapi_squares" in directory /home/nvidia/opencv/samples/tapi
    linked by target "example_tapi_pyrlk_optical_flow" in directory /home/nvidia/opencv/samples/tapi
    linked by target "example_tapi_tvl1_optical_flow" in directory /home/nvidia/opencv/samples/tapi
    linked by target "example_tapi_clahe" in directory /home/nvidia/opencv/samples/tapi
    linked by target "example_tapi_ufacedetect" in directory /home/nvidia/opencv/samples/tapi
-- Configuring incomplete, errors occurred!
See also "/home/nvidia/opencv/build/CMakeFiles/CMakeOutput.log".
See also "/home/nvidia/opencv/build/CMakeFiles/CMakeError.log".
Not a DPX2 bug, its a cuda 9.0 bug, fix available here, opencv - CMake Error: Variables are set to NOTFOUND - Stack Overflow
