[ 99%] Built target tutorial_interoperability_with_OpenCV_1
[ 99%] Building CXX object samples/cpp/CMakeFiles/example_lkdemo.dir/lkdemo.cpp.o
Scanning dependencies of target tutorial_mat_the_basic_image_container
[ 99%] Built target tutorial_AddingImagesTrackbar
[ 99%] Linking CXX executable ../../bin/cpp-example-train_svmsgd
Scanning dependencies of target example_grabcut
[ 99%] Linking CXX executable ../../bin/cpp-tutorial-gdal-image
[ 99%] Building CXX object samples/cpp/CMakeFiles/tutorial_mat_the_basic_image_container.dir/tutorial_code/core/mat_the_basic_image_container/mat_the_basic_image_container.cpp.o
[ 99%] Building CXX object samples/cpp/CMakeFiles/example_grabcut.dir/grabcut.cpp.o
[ 99%] Built target example_train_svmsgd
[ 99%] Built target tutorial_gdal-image
Scanning dependencies of target tutorial_how_to_use_OpenCV_parallel_for_
Scanning dependencies of target tutorial_file_input_output
[ 99%] Building CXX object samples/cpp/CMakeFiles/tutorial_how_to_use_OpenCV_parallel_for_.dir/tutorial_code/core/how_to_use_OpenCV_parallel_for_/how_to_use_OpenCV_parallel_for_.cpp.o
[ 99%] Building CXX object samples/cpp/CMakeFiles/tutorial_file_input_output.dir/tutorial_code/core/file_input_output/file_input_output.cpp.o
[ 99%] Linking CXX executable ../../bin/cpp-example-example
[ 99%] Linking CXX executable ../../bin/cpp-example-openni_capture
[ 99%] Built target example_example
[ 99%] Built target example_openni_capture
Scanning dependencies of target tutorial_discrete_fourier_transform
Scanning dependencies of target tutorial_objectDetection
[ 99%] Linking CXX executable ../../bin/cpp-example-cloning_gui
[ 99%] Building CXX object samples/cpp/CMakeFiles/tutorial_discrete_fourier_transform.dir/tutorial_code/core/discrete_fourier_transform/discrete_fourier_transform.cpp.o
[ 99%] Building CXX object samples/cpp/CMakeFiles/tutorial_objectDetection.dir/tutorial_code/objectDetection/objectDetection.cpp.o
[ 99%] Linking CXX executable ../../bin/cpp-tutorial-Drawing_1
[ 99%] Built target example_cloning_gui
[100%] Linking CXX executable ../../bin/cpp-tutorial-how_to_scan_images
[100%] Linking CXX executable ../../bin/cpp-example-distrans
[100%] Built target tutorial_Drawing_1
[100%] Linking CXX executable ../../bin/cpp-tutorial-mat_mask_operations
[100%] Built target tutorial_how_to_scan_images
[100%] Built target example_distrans
[100%] Linking CXX executable ../../bin/cpp-tutorial-how_to_use_OpenCV_parallel_for_
[100%] Linking CXX executable ../../bin/cpp-example-lkdemo
[100%] Built target tutorial_mat_mask_operations
[100%] Linking CXX executable ../../bin/cpp-tutorial-mat_the_basic_image_container
[100%] Built target tutorial_how_to_use_OpenCV_parallel_for_
[100%] Built target example_lkdemo
[100%] Built target tutorial_mat_the_basic_image_container
[100%] Linking CXX executable ../../bin/cpp-tutorial-file_input_output
[100%] Built target tutorial_file_input_output
[100%] Linking CXX executable ../../bin/cpp-example-grabcut
[100%] Built target example_grabcut
[100%] Linking CXX executable ../../bin/cpp-tutorial-objectDetection
[100%] Linking CXX executable ../../bin/cpp-tutorial-discrete_fourier_transform
[100%] Built target tutorial_objectDetection
[100%] Built target tutorial_discrete_fourier_transform
But when I try to cross-compile in driveworks, I faced the same errors.
cc1plus: error: include location “/usr/include/opencv” is unsafe for cross-compilation [-Werror=poison-system-directories]
compilation terminated due to -Wfatal-errors.
cc1plus: all warnings being treated as errors
~$ make -j12[ 1%] Building NVCC (Device) object src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/gen_YoloLayer.cu.o
Scanning dependencies of target dw_samples_framework
Scanning dependencies of target update_cuda_deps
[ 1%] Building NVCC (Device) object src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/gen_UpsampleLayer.cu.o
[ 2%] Dependencies for /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/gen_UpsampleLayer.cu.o.depend.stamp
[ 2%] Dependencies for /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/gen_YoloLayer.cu.o.depend.stamp
[ 3%] Dependencies for /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.stamp
[ 4%] Dependencies for /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir//gen_utils.cu.o.depend.stamp
-- Removing /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_YoloLayer.cu.o
-- Removing /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_UpsampleLayer.cu.o
/usr/bin/cmake -E remove /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_YoloLayer.cu.o
/usr/bin/cmake -E remove /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_UpsampleLayer.cu.o
-- Generating /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_YoloLayer.cu.o
-- Generating /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_UpsampleLayer.cu.o
/usr/local/cuda-9.0/bin/nvcc /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu -c -o /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_YoloLayer.cu.o -ccbin /home/mec-lab/PX2/5050bL_SDK/DriveSDK/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-g++ -m64 -DVIBRANTE -DVIBRANTE_V5L -DVIBRANTE_PDK_VERSION=\"5.0.5.0\" -DVIBRANTE_PDK_MAJOR=5 -DVIBRANTE_PDK_MINOR=0 -DVIBRANTE_PDK_PATCH=5 -DVIBRANTE_PDK_BUILD=0 -DVIBRANTE -DVIBRANTE_V5L -DVIBRANTE_PDK_VERSION=\"5.0.5.0\" -DVIBRANTE_PDK_MAJOR=5 -DVIBRANTE_PDK_MINOR=0 -DVIBRANTE_PDK_PATCH=5 -DVIBRANTE_PDK_BUILD=0 -DDW_USE_NVMEDIA -DDW_USE_EGL -Xcompiler ,\"-fPIC\",\"-Wall\",\"-Werror\",\"-Wunused\",\"-Wunused-value\",\"-Wunused-parameter\",\"-Wall\",\"-Ofast\",\"-Wfatal-errors\",\"-Wno-error=unused-parameter\",\"-Wno-error=unused-variable\",\"-Wno-error=unused-but-set-variable\",\"-Wall\",\"-Ofast\",\"-Wfatal-errors\",\"-D_MWAITXINTRIN_H_INCLUDED\",\"-O3\",\"-DNDEBUG\" -arch=sm_30 -lineinfo -std=c++11 -D_FORCE_INLINES -Xcompiler -fPIC -DNVCC -I/usr/local/cuda-9.0/include -I/usr/local/nvidia/tensorrt/targets/aarch64-linux-gnu/include -I/usr/local/cuda-9.0/targets/aarch64-linux/include -I/home/mec-lab/PX2/5050bL_SDK/DriveSDK/drive-t186ref-linux/include -I/usr/local/nvidia/tensorrt/targets/aarch64-linux-gnu/include -I/usr/local/cuda-9.0/include -I/usr/local/cuda-9.0/targets/aarch64-linux/include -I/home/mec-lab/LBX/driveworks-0.6/build_PX2/configured -I/usr/local/driveworks-0.6/targets/aarch64-linux/include -I/home/mec-lab/LBX/driveworks-0.6/build_PX2/configured/samples -I/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include
/usr/local/cuda-9.0/bin/nvcc /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cu -c -o /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_UpsampleLayer.cu.o -ccbin /home/mec-lab/PX2/5050bL_SDK/DriveSDK/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-g++ -m64 -DVIBRANTE -DVIBRANTE_V5L -DVIBRANTE_PDK_VERSION=\"5.0.5.0\" -DVIBRANTE_PDK_MAJOR=5 -DVIBRANTE_PDK_MINOR=0 -DVIBRANTE_PDK_PATCH=5 -DVIBRANTE_PDK_BUILD=0 -DVIBRANTE -DVIBRANTE_V5L -DVIBRANTE_PDK_VERSION=\"5.0.5.0\" -DVIBRANTE_PDK_MAJOR=5 -DVIBRANTE_PDK_MINOR=0 -DVIBRANTE_PDK_PATCH=5 -DVIBRANTE_PDK_BUILD=0 -DDW_USE_NVMEDIA -DDW_USE_EGL -Xcompiler ,\"-fPIC\",\"-Wall\",\"-Werror\",\"-Wunused\",\"-Wunused-value\",\"-Wunused-parameter\",\"-Wall\",\"-Ofast\",\"-Wfatal-errors\",\"-Wno-error=unused-parameter\",\"-Wno-error=unused-variable\",\"-Wno-error=unused-but-set-variable\",\"-Wall\",\"-Ofast\",\"-Wfatal-errors\",\"-D_MWAITXINTRIN_H_INCLUDED\",\"-O3\",\"-DNDEBUG\" -arch=sm_30 -lineinfo -std=c++11 -D_FORCE_INLINES -Xcompiler -fPIC -DNVCC -I/usr/local/cuda-9.0/include -I/usr/local/nvidia/tensorrt/targets/aarch64-linux-gnu/include -I/usr/local/cuda-9.0/targets/aarch64-linux/include -I/home/mec-lab/PX2/5050bL_SDK/DriveSDK/drive-t186ref-linux/include -I/usr/local/nvidia/tensorrt/targets/aarch64-linux-gnu/include -I/usr/local/cuda-9.0/include -I/usr/local/cuda-9.0/targets/aarch64-linux/include -I/home/mec-lab/LBX/driveworks-0.6/build_PX2/configured -I/usr/local/driveworks-0.6/targets/aarch64-linux/include -I/home/mec-lab/LBX/driveworks-0.6/build_PX2/configured/samples -I/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include
[ 4%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Grid.cpp.o
[ 4%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SampleFramework.cpp.o
[ 5%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/DriveWorksSample.cpp.o
[ 6%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProgramArguments.cpp.o
[ 8%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MathUtils.cpp.o
[ 8%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowGLFW.cpp.o
[ 8%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MouseView3D.cpp.o
[ 9%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Log.cpp.o
[ 9%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProfilerCUDA.cpp.o
[ 10%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/GenericImage.cpp.o
[ 11%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleCamera.cpp.o
[ 11%] Built target update_cuda_deps
[ 11%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRenderer.cpp.o
[ 12%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRecordingPlayer.cpp.o
[ 13%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowEGL.cpp.o
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu(33): warning: variable "a" was declared but never referenced
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu(48): warning: variable "a" was declared but never referenced
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/UpsampleLayer.h:38:37: warning: unused parameter 'maxBatchSize' [-Wunused-parameter]
virtual size_t getWorkspaceSize(int maxBatchSize) const override { return 0;}
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cu:50:98: warning: unused parameter 'workspace' [-Wunused-parameter]
int UpsampleLayerPlugin::enqueue(int batchSize, const void*const * inputs, void** outputs, void* workspace, cudaStream_t stream)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/YoloLayer.h:44:36: warning: unused parameter 'inputDims' [-Wunused-parameter]
void configure(const Dims* inputDims, int nbInputs, const Dims* outputDims, int nbOutputs, int) override {};
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/YoloLayer.h:44:51: warning: unused parameter 'nbInputs' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/YoloLayer.h:44:73: warning: unused parameter 'outputDims' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/YoloLayer.h:44:89: warning: unused parameter 'nbOutputs' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/YoloLayer.h:50:37: warning: unused parameter 'maxBatchSize' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu:29:59: warning: unused parameter 'length' [-Wunused-parameter]
YoloLayerPlugin::YoloLayerPlugin(const void* data, size_t length)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu:78:47: warning: unused parameter 'index' [-Wunused-parameter]
Dims YoloLayerPlugin::getOutputDimensions(int index, const Dims* inputs, int nbInputDims)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu:78:66: warning: unused parameter 'inputs' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu:78:78: warning: unused parameter 'nbInputDims' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu:220:90: warning: unused parameter 'stream' [-Wunused-parameter]
void YoloLayerPlugin::forwardGpu(const float *const * inputs,float * output,cudaStream_t stream) {
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu:243:34: warning: unused parameter 'batchSize' [-Wunused-parameter]
int YoloLayerPlugin::enqueue(int batchSize, const void*const * inputs, void** outputs, void* workspace, cudaStream_t stream)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/YoloLayer.cu:243:94: warning: unused parameter 'workspace' [-Wunused-parameter]
Generated /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_UpsampleLayer.cu.o successfully.
Generated /home/mec-lab/LBX/driveworks-0.6/build_PX2/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/./gen_YoloLayer.cu.o successfully.
Scanning dependencies of target TrtNet
[ 14%] Building CXX object src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/UpsampleLayer.cpp.o
[ 15%] Building CXX object src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/TrtNet.cpp.o
[ 14%] Building CXX object src/dnn/sample_trt_yolov3/tensorRTWrapper/code/CMakeFiles/TrtNet.dir/src/EntroyCalibrator.cpp.o
[ 15%] Linking CXX static library libdw_samples_framework.a
[ 15%] Built target dw_samples_framework
Scanning dependencies of target sample_camera_usb
Scanning dependencies of target sample_egomotion
Scanning dependencies of target sample_gps_logger
Scanning dependencies of target sample_camera_multiple_replay
Scanning dependencies of target sample_sensors_info
Scanning dependencies of target sample_camera_replay
Scanning dependencies of target sample_camera_seek
Scanning dependencies of target sample_camera_pointgrey
Scanning dependencies of target sample_imu_logger
[ 16%] Building CXX object src/sensors/gps/CMakeFiles/sample_gps_logger.dir/main.cpp.o
[ 17%] Building CXX object src/sensors/imu/CMakeFiles/sample_imu_logger.dir/main.cpp.o
[ 17%] Building CXX object src/sensors/info/CMakeFiles/sample_sensors_info.dir/main.cpp.o
[ 17%] Building CXX object src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/main.cpp.o
[ 18%] Building CXX object src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/main.cpp.o
[ 19%] Building CXX object src/egomotion/CMakeFiles/sample_egomotion.dir/main.cpp.o
[ 20%] Building CXX object src/sensors/camera_multiple_replay/CMakeFiles/sample_camera_multiple_replay.dir/main.cpp.o
[ 21%] Building CXX object src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/main.cpp.o
[ 21%] Building CXX object src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/main.cpp.o
In file included from /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:1:0:
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/UpsampleLayer.h:38:45: warning: unused parameter 'maxBatchSize' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp: In constructor 'nvinfer1::UpsampleLayerPlugin::UpsampleLayerPlugin(const void*, size_t)':
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:20:19: warning: unused variable 'a' [-Wunused-variable]
const char *a = d;
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp: At global scope:
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:16:69: warning: unused parameter 'length' [-Wunused-parameter]
UpsampleLayerPlugin::UpsampleLayerPlugin(const void* data, size_t length)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp: In member function 'virtual void nvinfer1::UpsampleLayerPlugin::serialize(void*)':
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:36:13: warning: unused variable 'a' [-Wunused-variable]
char *a = d;
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:59:51: warning: unused parameter 'inputDims' [-Wunused-parameter]
void UpsampleLayerPlugin::configure(const Dims* inputDims, int nbInputs, const Dims* outputDims, int nbOutputs, int)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:59:66: warning: unused parameter 'nbInputs' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:59:88: warning: unused parameter 'outputDims' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:59:104: warning: unused parameter 'nbOutputs' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:69:53: warning: unused parameter 'index' [-Wunused-parameter]
Dims UpsampleLayerPlugin::getOutputDimensions(int index, const Dims* inputs, int nbInputDims)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/UpsampleLayer.cpp:69:84: warning: unused parameter 'nbInputDims' [-Wunused-parameter]
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/EntroyCalibrator.cpp:32:78: warning: unused parameter 'names' [-Wunused-parameter]
bool Int8EntropyCalibrator::getBatch(void* bindings[], const char* names[], int nbBindings)
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/EntroyCalibrator.cpp:32:85: warning: unused parameter 'nbBindings' [-Wunused-parameter]
[ 22%] Building CXX object src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/ResourceManager.cpp.o
In file included from /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/PluginFactory.h:7:0,
from /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/TrtNet.h:11,
from /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/src/TrtNet.cpp:1:
In file included from /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/PluginFactory.h:8:0,
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/YoloLayer.h:50:45: warning: unused parameter 'maxBatchSize' [-Wunused-parameter]
In file included from /home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/TrtNet.h:11:0,
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/PluginFactory.h:41:101: warning: unused parameter 'weights' [-Wunused-parameter]
virtual nvinfer1::IPlugin* createPlugin(const char* layerName, const nvinfer1::Weights* weights, int nbWeights) override
/home/mec-lab/LBX/driveworks-0.6/samples/src/dnn/sample_trt_yolov3/tensorRTWrapper/code/include/PluginFactory.h:41:114: warning: unused parameter 'nbWeights' [-Wunused-parameter]
Scanning dependencies of target sample_record
[ 23%] Building CXX object src/sensors/record/CMakeFiles/sample_record.dir/main.cpp.o
[ 24%] Linking CXX executable sample_imu_logger
[ 25%] Linking CXX executable sample_gps_logger
[ 26%] Building CXX object src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/ResourceManager.cpp.o
Scanning dependencies of target sample_canbus_logger
[ 27%] Linking CXX executable sample_sensors_info
[ 27%] Building CXX object src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/main.cpp.o
[ 28%] Linking CXX executable sample_camera_usb
[ 28%] Built target sample_imu_logger
[ 29%] Linking CXX executable sample_camera_multiple_replay
Scanning dependencies of target sample_canbus_interpreter
[ 29%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/main.cpp.o
[ 29%] Built target sample_gps_logger
[ 30%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/interpreter.cpp.o
[ 30%] Built target sample_sensors_info
Scanning dependencies of target sample_lidar_replay
[ 30%] Built target sample_camera_usb
Scanning dependencies of target sample_radar_replay
[ 30%] Built target sample_camera_multiple_replay
[ 31%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/main.cpp.o
Scanning dependencies of target sample_third_party_camera
[ 32%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o
[ 32%] Building CXX object src/sensors/third_party_camera/CMakeFiles/sample_third_party_camera.dir/main.cpp.o
[ 32%] Linking CXX executable sample_egomotion
[ 32%] Built target sample_egomotion
[ 32%] Linking CXX executable sample_camera_pointgrey
[ 32%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/userInput.cpp.o
Scanning dependencies of target sample_camera_gmsl
[ 32%] Building CXX object src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/main.cpp.o
[ 32%] Built target sample_camera_pointgrey
Scanning dependencies of target sample_camera_gmsl_custom
[ 32%] Building CXX object src/sensors/camera_gmsl_custom/CMakeFiles/sample_camera_gmsl_custom.dir/captureConfig.cpp.o
[ 33%] Linking CXX executable sample_camera_replay
[ 33%] Linking CXX executable sample_camera_seek
[ 34%] Linking CXX executable sample_canbus_interpreter
[ 34%] Built target sample_camera_replay
[ 35%] Linking CXX executable sample_canbus_logger
[ 36%] Building CXX object src/sensors/camera_gmsl_custom/CMakeFiles/sample_camera_gmsl_custom.dir/main.cpp.o
Scanning dependencies of target sample_camera_multiple_gmsl
[ 37%] Building CXX object src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/main.cpp.o
[ 37%] Built target sample_camera_seek
Scanning dependencies of target sample_camera_gmsl_raw
[ 38%] Linking CXX executable sample_lidar_replay
[ 39%] Linking CXX executable sample_third_party_camera
[ 39%] Building CXX object src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/main.cpp.o
[ 39%] Built target sample_canbus_interpreter
Scanning dependencies of target sample_camera_tracker
[ 39%] Built target sample_canbus_logger
Scanning dependencies of target sample_camera_scaling_tracker
[ 39%] Linking CXX executable sample_record
[ 40%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/main.cpp.o
[ 40%] Building CXX object src/features/camera_scaling_tracker/CMakeFiles/sample_camera_scaling_tracker.dir/main.cpp.o
[ 40%] Built target sample_lidar_replay
[ 40%] Built target sample_third_party_camera
[ 40%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/SensorIOCuda.cpp.o
[ 40%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/radarDynamics.cpp.o
[ 40%] Built target sample_record
Scanning dependencies of target sample_occupancy_grid
[ 41%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/SensorIONvmedia.cpp.o
[ 41%] Building CXX object src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/main.cpp.o
[ 42%] Linking CXX executable sample_camera_gmsl
[ 42%] Built target sample_camera_gmsl
Scanning dependencies of target sample_rig_configuration
[ 42%] Building CXX object src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/main.cpp.o
Scanning dependencies of target sample_renderer
[ 43%] Building CXX object src/renderer/CMakeFiles/sample_renderer.dir/main.cpp.o
Scanning dependencies of target sample_sfm
[ 44%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/main.cpp.o
[ 44%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/SensorIOCuda.cpp.o
[ 45%] Linking CXX executable sample_rig_configuration
[ 46%] Linking CXX executable sample_camera_gmsl_raw
[ 47%] Linking CXX executable sample_camera_tracker
[ 48%] Linking CXX executable sample_radar_replay
[ 48%] Built target sample_rig_configuration
Scanning dependencies of target dw_samples_dnn_common
[ 48%] Built target sample_camera_gmsl_raw
[ 50%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/DNNInference.cpp.o
[ 50%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/SensorIOCuda.cpp.o
[ 51%] Linking CXX executable sample_camera_gmsl_custom
[ 51%] Built target sample_camera_tracker
[ 52%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/SensorIONvmedia.cpp.o
[ 52%] Built target sample_radar_replay
[ 53%] Linking CXX executable sample_renderer
[ 53%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/SensorIONvmedia.cpp.o
[ 53%] Built target sample_camera_gmsl_custom
Scanning dependencies of target dw_samples_laneDetection_common
[ 54%] Linking CXX executable sample_occupancy_grid
[ 54%] Built target sample_renderer
[ 55%] Building CXX object src/laneDetection/laneDetection_common/CMakeFiles/dw_samples_laneDetection_common.dir/LaneDetectionCommon.cpp.o
Scanning dependencies of target sample_color_correction
[ 55%] Linking CXX executable sample_camera_multiple_gmsl
[ 55%] Building CXX object src/colorcorrection/CMakeFiles/sample_color_correction.dir/main.cpp.o
[ 55%] Built target sample_occupancy_grid
[ 55%] Built target sample_camera_multiple_gmsl
Scanning dependencies of target sample_isp
Scanning dependencies of target sample_video_rectifier
Scanning dependencies of target sample_ipc_socketclientserver
[ 55%] Building CXX object src/isp/CMakeFiles/sample_isp.dir/main.cpp.o
[ 55%] Building CXX object src/rectifier/CMakeFiles/sample_video_rectifier.dir/main.cpp.o
[ 55%] Building CXX object src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/sample_ipc_socketclientserver.cpp.o
Scanning dependencies of target sample_hello_world
[ 55%] Building CXX object src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o
[ 56%] Building NVCC (Device) object src/image/image_common/CMakeFiles/dw_samples_image_common.dir/gen_utils.cu.o
[ 57%] Linking CXX static library libdw_samples_dnn_common.a
[ 57%] Built target dw_samples_dnn_common
Scanning dependencies of target sample_image_streamer_cross
[ 58%] Building CXX object src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/main.cpp.o
[ 58%] Building NVCC (Device) object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/gen_utils.cu.o
[ 59%] Linking CXX executable sample_hello_world
[ 60%] Linking CXX executable sample_color_correction
[ 60%] Built target sample_hello_world
Scanning dependencies of target sample_freespace_detection
[ 61%] Building CXX object src/freespace/CMakeFiles/sample_freespace_detection.dir/main.cpp.o
[ 61%] Linking CXX static library libTrtNet.a
[ 61%] Built target sample_color_correction
[ 61%] Built target TrtNet
Scanning dependencies of target dw_samples_drivenet_common
[ 62%] Linking CXX static library libdw_samples_laneDetection_common.a
Scanning dependencies of target sample_maps
[ 62%] Built target dw_samples_laneDetection_common
Scanning dependencies of target sample_template
[ 62%] Building CXX object src/drivenet/common/CMakeFiles/dw_samples_drivenet_common.dir/DriveNetApp.cpp.o
[ 63%] Building CXX object src/maps/CMakeFiles/sample_maps.dir/main.cpp.o
Scanning dependencies of target dw_samples_image_common
[ 64%] Linking CXX static library libdw_samples_image_common.a
[ 64%] Building CXX object src/template/CMakeFiles/sample_template.dir/main.cpp.o
[ 64%] Built target dw_samples_image_common
Scanning dependencies of target sample_icp
[ 65%] Linking CXX executable sample_camera_scaling_tracker
[ 66%] Building CXX object src/icp/CMakeFiles/sample_icp.dir/main.cpp.o
[ 67%] Linking CXX executable sample_isp
[ 68%] Linking CXX executable sample_ipc_socketclientserver
[ 69%] Linking CXX executable sample_image_streamer_cross
[ 69%] Built target sample_camera_scaling_tracker
Scanning dependencies of target sample_lidar_accumulator
[ 70%] Building CXX object src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/main.cpp.o
[ 70%] Built target sample_isp
[ 70%] Built target sample_ipc_socketclientserver
[ 71%] Building CXX object src/drivenet/common/CMakeFiles/dw_samples_drivenet_common.dir/common.cpp.o
Scanning dependencies of target sample_calibration_camera
[ 71%] Built target sample_image_streamer_cross
Scanning dependencies of target sample_vehicleio
[ 72%] Linking CXX executable sample_video_rectifier
[ 72%] Building CXX object src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/main.cpp.o
[ 73%] Building CXX object src/vehicleio/CMakeFiles/sample_vehicleio.dir/main.cpp.o
[ 73%] Built target sample_video_rectifier
Scanning dependencies of target sample_object_detector
Scanning dependencies of target dw_samples_stereo_common
[ 74%] Building CXX object src/dnn/sample_object_detector/CMakeFiles/sample_object_detector.dir/main.cpp.o
[ 75%] Building CXX object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/stereoCommon.cpp.o
[ 76%] Linking CXX executable sample_template
[ 77%] Linking CXX executable sample_sfm
[ 77%] Linking CXX executable sample_freespace_detection
Scanning dependencies of target sample_object_tracker
[ 77%] Linking CXX executable sample_maps
[ 78%] Building CXX object src/dnn/sample_object_tracker/CMakeFiles/sample_object_tracker.dir/main.cpp.o
[ 78%] Built target sample_sfm
[ 78%] Built target sample_template
[ 79%] Building CXX object src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/userInput.cpp.o
[ 79%] Building CXX object src/dnn/sample_object_tracker/CMakeFiles/sample_object_tracker.dir/FeatureTracker2D.cpp.o
[ 79%] Built target sample_freespace_detection
Scanning dependencies of target sample_object_dwdetector
[ 79%] Building CXX object src/dnn/sample_object_dwdetector/CMakeFiles/sample_object_dwdetector.dir/main.cpp.o
[ 79%] Built target sample_maps
Scanning dependencies of target sample_trt_yolov3
[ 80%] Building CXX object src/dnn/sample_trt_yolov3/CMakeFiles/sample_trt_yolov3.dir/main.cpp.o
cc1plus: error: include location "/usr/include/opencv" is unsafe for cross-compilation [-Werror=poison-system-directories]
src/dnn/sample_trt_yolov3/CMakeFiles/sample_trt_yolov3.dir/build.make:62: recipe for target 'src/dnn/sample_trt_yolov3/CMakeFiles/sample_trt_yolov3.dir/main.cpp.o' failed
make[2]: *** [src/dnn/sample_trt_yolov3/CMakeFiles/sample_trt_yolov3.dir/main.cpp.o] Error 1
CMakeFiles/Makefile2:1949: recipe for target 'src/dnn/sample_trt_yolov3/CMakeFiles/sample_trt_yolov3.dir/all' failed
make[1]: *** [src/dnn/sample_trt_yolov3/CMakeFiles/sample_trt_yolov3.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 81%] Building CXX object src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/CameraCalibrationSample.cpp.o
[ 82%] Linking CXX executable sample_vehicleio
[ 83%] Linking CXX executable sample_object_detector
[ 83%] Built target sample_object_detector
[ 83%] Built target sample_vehicleio
[ 84%] Linking CXX static library libdw_samples_stereo_common.a
[ 84%] Built target dw_samples_stereo_common
[ 84%] Linking CXX executable sample_icp
[ 84%] Built target sample_icp
[ 84%] Linking CXX executable sample_lidar_accumulator
[ 84%] Built target sample_lidar_accumulator
[ 85%] Linking CXX static library libdw_samples_drivenet_common.a
[ 86%] Linking CXX executable sample_object_tracker
[ 86%] Built target dw_samples_drivenet_common
[ 86%] Built target sample_object_tracker
[ 87%] Linking CXX executable sample_object_dwdetector
[ 87%] Built target sample_object_dwdetector
[ 88%] Linking CXX executable sample_calibration_camera
[ 88%] Built target sample_calibration_camera
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Am I missed any step?
