My source code is as below:
#include <opencv2/highgui.hpp>
#include <opencv2/core.hpp>
int mian(int argc, char* argv[])
argc = argc;
cv::Mat a = cv::imread(argv[1]);
cv::imshow("test", a);
cv::waitKey(10);
return 0;
My CMakeLists.txt is as below
# Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
project(opencv C CXX)
# Project files
set(PUBLIC_DOCS
README.md
set(SOURCES
main.cpp
find_package(OpenCV REQUIRED PATHS /home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_b/usr/local)
include_directories(${Opencv_INCLUDE_DIR})
set(LIBRARIES
samples_framework
${Driveworks_LIBRARIES}
${OpenCV_LIBRARIES}
# Final target
add_executable(${PROJECT_NAME} ${SOURCES})
target_link_libraries(${PROJECT_NAME} ${LIBRARIES})
set_property(TARGET ${PROJECT_NAME} PROPERTY FOLDER "Samples")
# Install target
sdk_add_sample(${PROJECT_NAME})
When I try to do make, it endup with below errors.
/home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../a$
rch64-linux-gnu/bin/ld: warning: libEGL.so.1, needed by /home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs/usr/local/driveworks-2.2/tar$
ets/aarch64-Linux/lib/libnvinfer.so.5, not found (try using -rpath or -rpath-link)
/home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../aarch64-linux-gnu/libc/usr/lib/crt1.o: In fun$
tion `_start':
/home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/aarch64-linux-gnu/snapshots/glibc.git~release~2.25~master/csu/../sysdeps/aarch64/star$
.S:86: undefined reference to `main'
/home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_b/lib/aarch64-linux-gnu/libc-2.27.so: undefined reference to `_dl_exception_create@G$
IBC_PRIVATE'
/home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_b/usr/local/lib/libopencv_imgproc.so.3.4.2: undefined reference to `expf@GLIBC_2.27'
/home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_b/lib/aarch64-linux-gnu/libc-2.27.so: undefined reference to `__tunable_get_val@GLIB$_PRIVATE'
/home/hero/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_E3550/DRIVEOS/drive-t186ref-linux/targetfs_b/usr/local/lib/libopencv_core.so.3.4.2: undefined reference to `logf@GLIBC_2.27'
collect2: error: ld returned 1 exit status
src/opencv/CMakeFiles/opencv.dir/build.make:124: recipe for target 'src/opencv/opencv' failed
make[2]: *** [src/opencv/opencv] Error 1
CMakeFiles/Makefile2:421: recipe for target 'src/opencv/CMakeFiles/opencv.dir/all' failed
make[1]: *** [src/opencv/CMakeFiles/opencv.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
Opencv libraries are cross-compiled and installed to targetfs/usr/local.I can find libc.so and libc-2.27.so in targetfs/usr/lib/aarch64-linux-gnu/, compiling opencv i follow https://devtalk.nvidia.com/default/topic/1044512/general/opencv-unable-to-stop-the-stream-inappropriate-ioctl-for-device/?offset=2#
