Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
I had followed this link to build opencv in host machine.
Note: OpenCV is not officially supported nor is it optimized on the Drive platform. These instructions are provided only to help with porting/prototyping and is not maintained by NVIDIA. It is recommended to utilize NVIDIA APIs moving forward.
Cross compiling OpenCV on host
Pre-Conditions:
Drive Software 10.0 is installed on the host machine via SDKManager (both host and device).
cmake is installed (min version 3.10)
The instructions to build OpenCV on Host machine for Drive AGX Linux (V4L)…
How to execute/link opencv related code with driveworks.
Any tutorials are there how to build opencv related code in Host machine.
Dear @alksainath.medam ,
We don’t officially support OpenCV and did not test OpenCV with Nsight eclipse.
Is it like you can not compile DW + OpenCV sample. You need to update CMakefiles with inclusion of libs and headers. Please search in forum for previous posts like Cross-compiling error while using OpenCV in sample_camera application to get info
OK, thanks i will check once.
I am trying to include opencv code with DW.
I had python code which is with opencv.
I converted my model using TensorRT Optimisation tool, initialisation done and wanted to include opencv code with DW code, so that i can execute in Drive AGX.
Executing opencv with DW samples.
Prepared framework and compile, execute in the host did by using following link.
Intro:
The NVIDIA DRIVE™ AGX Developer System enables you to accelerate development with our DRIVE software stack.
The NVIDIA DriveWorks Software Development Kit (SDK) includes a number of open-source reference samples, development tools, and library modules targeting autonomous driving applications.
After properly configuring your development environment, you can customize these samples or develop your own applications on your Linux host machine, executing them either on the host or on the …
Trying to run sample codes to print version of opencv, getting following errors. I think missing to add something i guess can you suggest me.
[100%] Linking CXX executable sample_dms
CMakeFiles/sample_dms.dir/main.cpp.o: In function main': /home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:920: undefined reference to
cv::CommandLineParser::CommandLineParser(int, char const* const*, std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&)’
/home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:921: undefined reference to cv::CommandLineParser::about(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' /home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:922: undefined reference to
cv::CommandLineParser::has(std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&) const’
/home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:924: undefined reference to cv::CommandLineParser::printMessage() const' /home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:926: undefined reference to
cv::CommandLineParser::check() const’
/home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:928: undefined reference to cv::CommandLineParser::printErrors() const' src/dnn/dms/CMakeFiles/sample_dms.dir/build.make:112: recipe for target 'src/dnn/dms/sample_dms' failed /home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:930: undefined reference to
CMakeFiles/Makefile2:631: recipe for target ‘src/dnn/dms/CMakeFiles/sample_dms.dir/all’ failed
Makefile:129: recipe for target ‘all’ failed
/home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:932: undefined reference to cv::getBuildInformation[abi:cxx11]()' /home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:920: undefined reference to
cv::CommandLineParser::~CommandLineParser()’
/home/adascoe/samples-nsight1/samples/src/dnn/dms/main.cpp:920: undefined reference to `cv::CommandLineParser::~CommandLineParser()’
collect2: error: ld returned 1 exit status
make[2]: *** [src/dnn/dms/sample_dms] Error 1
make[1]: *** [src/dnn/dms/CMakeFiles/sample_dms.dir/all] Error 2
make: *** [all] Error 2
15:52:58 Build Finished (took 14s.237ms)
@SivaRamaKrishnaNV
Please, look into this waiting for your reply.
looks like a linker issue. Is this function part of opencv library? Did you update cmakefiles to include the library which has the above function.
Dear @SivaRamaKrishnaNV
This function is part of opencv library.
How to update cmakefiles to include the library which has the required functions?
