hi,everyone!
i have modified and source ~/.bashrc before.
[code]gris@gris-RESCUER-R720-15IKBN:~$ sudo dpkg --add-architecture arm64
[sudo] password for gris:
Odd number of elements in hash assignment at /usr/share/pkg-config-dpkghook line 30.
gris@gris-RESCUER-R720-15IKBN:~$ vim ~/.bashrc
gris@gris-RESCUER-R720-15IKBN:~$ sudo apt-get update
Hit:1 https://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial InRelease
Hit:2 https://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-updates InRelease
Hit:3 https://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-backports InRelease
Hit:4 https://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-security InRelease
Hit:5 https://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-proposed InRelease
Hit:6 http://archive.ubuntu.com/ubuntu xenial InRelease
Ign:7 http://ports.ubuntu.com trusty InRelease
Hit:8 http://ports.ubuntu.com trusty-security InRelease
Hit:9 http://ports.ubuntu.com trusty-backports InRelease
Ign:10 http://ports.ubuntu.com/ubuntu-ports trusty InRelease
Hit:11 http://ports.ubuntu.com/ubuntu-ports trusty-updates InRelease
Hit:12 http://ports.ubuntu.com/ubuntu-ports trusty-security InRelease
Hit:13 http://ports.ubuntu.com trusty Release
Hit:15 http://ports.ubuntu.com/ubuntu-ports trusty Release
Reading package lists... Done
gris@gris-RESCUER-R720-15IKBN:~$ sudo apt-get install cuda-cross-aarch64-9-0
Building dependency tree
Reading state information... Done
cuda-cross-aarch64-9-0 is already the newest version (9.0.225-1).
0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded.
gris@gris-RESCUER-R720-15IKBN:~$ nvcc --version
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Sun_Oct_22_03:08:45_CDT_2017
Cuda compilation tools, release 9.0, V9.0.225
gris@gris-RESCUER-R720-15IKBN:~$ sudo mkdir
mkdir: missing operand
Try 'mkdir --help' for more information.
gris@gris-RESCUER-R720-15IKBN:~$ sudo mkdir build
gris@gris-RESCUER-R720-15IKBN:~$ cd build
gris@gris-RESCUER-R720-15IKBN:~/build$ sudo cmake -DCMAKE_BUILD_TYPE=Release \
> -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-1.2/samples/cmake/Toolchain-V5L.cmake \
> sudo cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-1.2/samples/cmake/Toolchain-V5L.cmake \exit
CMake Error: The source directory "/home/gris/build/exit" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
> -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-0.6/samples/cmake/Toolchain-V4L.cmake \
> -DVIBRANTE_PDK:STRING=/home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux \
-- VIBRANTE_PDK = /home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux
-- VIBRANTE_PDK_DEVICE = t186ref
-- VIBRANTE_PDK_BRANCH = 5.0.5.0
-- Vibrante version 5.0.5.0
-- The C compiler identification is GNU 4.9.2
-- The CXX compiler identification is GNU 4.9.2
-- Check for working C compiler: /home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc
-- Check for working C compiler: /home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-g++
-- Check for working CXX compiler: /home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/../toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found CUDA: /usr/local/cuda (found version "9.0")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found TensorRT:
-- - Includes: /usr/local/nvidia/tensorrt/targets/aarch64-linux-gnu/include
-- - Libraries: /usr/local/nvidia/tensorrt/targets/aarch64-linux-gnu/lib/libnvinfer.so;/usr/local/nvidia/tensorrt/targets/aarch64-linux-gnu/lib/libnvcaffe_parser.so
-- Found libcudnn:
-- - Includes: /usr/local/cuda/targets/aarch64-linux/include
-- - Libraries: /usr/local/cuda/targets/aarch64-linux/lib/libcudnn.so
-- Cross Compiling for Vibrante
-- Found vibrante lib: /usr/local/driveworks-0.6/samples/3rdparty/linux-aarch64/vibrante/lib/libudev.so
-- Found vibrante lib: /usr/local/driveworks-0.6/samples/3rdparty/linux-aarch64/vibrante/lib/libusb-1.0.so
-- Found vibrante_Xlib: /usr/local/driveworks-0.6/samples/3rdparty/linux-aarch64/vibrante_Xlibs/lib/libXrandr.so
-- Found vibrante_Xlib: /usr/local/driveworks-0.6/samples/3rdparty/linux-aarch64/vibrante_Xlibs/lib/libXinerama.so
-- Found vibrante_Xlib: /usr/local/driveworks-0.6/samples/3rdparty/linux-aarch64/vibrante_Xlibs/lib/libXi.so
-- Found vibrante_Xlib: /usr/local/driveworks-0.6/samples/3rdparty/linux-aarch64/vibrante_Xlibs/lib/libXcursor.so
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Found EGL: /home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/lib-target/libEGL.so
-- Driveworks Samples install dir: /home/gris/build/install
-- Driveworks found at: /usr/local/driveworks-0.6/targets/aarch64-linux
-- Found Driveworks
-- Configuring done
-- Generating done
-- Build files have been written to: /home/gris/build
gris@gris-RESCUER-R720-15IKBN:~/build$ sudo make -j
Scanning dependencies of target update_cuda_deps
Scanning dependencies of target dw_samples_framework
[ 2%] Dependencies for /home/gris/build/src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir//gen_utils.cu.o.depend.stamp
[ 2%] Dependencies for /home/gris/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.stamp
[ 3%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SampleFramework.cpp.o
[ 4%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/DriveWorksSample.cpp.o
[ 6%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Grid.cpp.o
[ 4%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProgramArguments.cpp.o
[ 6%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MathUtils.cpp.o
[ 7%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MouseView3D.cpp.o
[ 5%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowGLFW.cpp.o
[ 8%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleCamera.cpp.o
[ 9%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Log.cpp.o
[ 9%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRecordingPlayer.cpp.o
[ 10%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRenderer.cpp.o
[ 11%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/GenericImage.cpp.o
[ 11%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProfilerCUDA.cpp.o
[ 12%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowEGL.cpp.o
[ 12%] Built target update_cuda_deps
[ 13%] Linking CXX static library libdw_samples_framework.a
[ 13%] Built target dw_samples_framework
Scanning dependencies of target sample_gps_logger
Scanning dependencies of target sample_egomotion
Scanning dependencies of target sample_camera_replay
Scanning dependencies of target sample_sensors_info
Scanning dependencies of target sample_rig_configuration
Scanning dependencies of target sample_camera_scaling_tracker
Scanning dependencies of target sample_canbus_interpreter
Scanning dependencies of target sample_record
Scanning dependencies of target sample_ipc_socketclientserver
Scanning dependencies of target sample_camera_pointgrey
Scanning dependencies of target sample_camera_gmsl_custom
Scanning dependencies of target sample_camera_multiple_gmsl
Scanning dependencies of target sample_radar_replay
Scanning dependencies of target sample_camera_seek
Scanning dependencies of target sample_isp
[ 14%] Building NVCC (Device) object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/gen_utils.cu.o
Scanning dependencies of target sample_imu_logger
Scanning dependencies of target dw_samples_laneDetection_common
Scanning dependencies of target sample_lidar_replay
Scanning dependencies of target sample_third_party_camera
[ 13%] Building NVCC (Device) object src/image/image_common/CMakeFiles/dw_samples_image_common.dir/gen_utils.cu.o
Scanning dependencies of target sample_camera_multiple_replay
Scanning dependencies of target sample_occupancy_grid
Scanning dependencies of target sample_camera_tracker
Scanning dependencies of target sample_camera_usb
Scanning dependencies of target sample_canbus_logger
Scanning dependencies of target sample_color_correction
Scanning dependencies of target sample_template
Scanning dependencies of target sample_camera_gmsl_raw
Scanning dependencies of target sample_sfm
Scanning dependencies of target sample_maps
Scanning dependencies of target sample_video_rectifier
Scanning dependencies of target dw_samples_drivenet_common
[ 14%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/interpreter.cpp.o
Scanning dependencies of target sample_hello_world
[ 15%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/main.cpp.o
Scanning dependencies of target sample_vehicleio
Scanning dependencies of target sample_renderer
Scanning dependencies of target sample_lidar_accumulator
[ 15%] Building CXX object src/sensors/gps/CMakeFiles/sample_gps_logger.dir/main.cpp.o
Scanning dependencies of target dw_samples_dnn_common
Scanning dependencies of target sample_icp
Scanning dependencies of target sample_image_streamer_cross
[ 16%] Building CXX object src/sensors/info/CMakeFiles/sample_sensors_info.dir/main.cpp.o
[ 17%] Building CXX object src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/main.cpp.o
[ 17%] Building CXX object src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/main.cpp.o
[ 18%] Building CXX object src/isp/CMakeFiles/sample_isp.dir/main.cpp.o
[ 19%] Building CXX object src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/sample_ipc_socketclientserver.cpp.o
[ 19%] Building CXX object src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/main.cpp.o
[ 19%] Building CXX object src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/ResourceManager.cpp.o
[ 20%] Building CXX object src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/main.cpp.o
[ 21%] Building CXX object src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o
[ 22%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/userInput.cpp.o
[ 22%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/main.cpp.o
[ 23%] Building CXX object src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/main.cpp.o
[ 24%] Building CXX object src/sensors/imu/CMakeFiles/sample_imu_logger.dir/main.cpp.o
[ 25%] Building CXX object src/sensors/third_party_camera/CMakeFiles/sample_third_party_camera.dir/main.cpp.o
[ 26%] Building CXX object src/sensors/record/CMakeFiles/sample_record.dir/main.cpp.o
[ 27%] Building CXX object src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/main.cpp.o
[ 28%] Building CXX object src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/main.cpp.o
[ 28%] Building CXX object src/renderer/CMakeFiles/sample_renderer.dir/main.cpp.o
[ 27%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/SensorIOCuda.cpp.o
[ 29%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o
[ 29%] Building CXX object src/sensors/camera_multiple_replay/CMakeFiles/sample_camera_multiple_replay.dir/main.cpp.o
[ 30%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/SensorIONvmedia.cpp.o
[ 34%] Building CXX object src/icp/CMakeFiles/sample_icp.dir/main.cpp.o
[ 34%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/radarDynamics.cpp.o
[ 31%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/main.cpp.o
[ 34%] Building CXX object src/laneDetection/laneDetection_common/CMakeFiles/dw_samples_laneDetection_common.dir/LaneDetectionCommon.cpp.o
[ 35%] Building CXX object src/colorcorrection/CMakeFiles/sample_color_correction.dir/main.cpp.o
[ 36%] Building CXX object src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/userInput.cpp.o
[ 36%] Building CXX object src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/main.cpp.o
[ 36%] Building CXX object src/maps/CMakeFiles/sample_maps.dir/main.cpp.o
[ 37%] Building CXX object src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/main.cpp.o
[ 38%] Building CXX object src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/main.cpp.o
[ 38%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/main.cpp.o
[ 39%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/SensorIOCuda.cpp.o
[ 40%] Building CXX object src/vehicleio/CMakeFiles/sample_vehicleio.dir/main.cpp.o
[ 41%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/SensorIONvmedia.cpp.o
[ 41%] Building CXX object src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/ResourceManager.cpp.o
[ 42%] Building CXX object src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/main.cpp.o
[ 43%] Building CXX object src/egomotion/CMakeFiles/sample_egomotion.dir/main.cpp.o
[ 43%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/DNNInference.cpp.o
[ 44%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/SensorIOCuda.cpp.o
[ 45%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/SensorIONvmedia.cpp.o
[ 45%] Building CXX object src/sensors/camera_gmsl_custom/CMakeFiles/sample_camera_gmsl_custom.dir/captureConfig.cpp.o
[ 46%] Building CXX object src/drivenet/common/CMakeFiles/dw_samples_drivenet_common.dir/common.cpp.o
[ 47%] Building CXX object src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/main.cpp.o
[ 48%] Building CXX object src/drivenet/common/CMakeFiles/dw_samples_drivenet_common.dir/DriveNetApp.cpp.o
[ 49%] Building CXX object src/features/camera_scaling_tracker/CMakeFiles/sample_camera_scaling_tracker.dir/main.cpp.o
[ 50%] Building CXX object src/sensors/camera_gmsl_custom/CMakeFiles/sample_camera_gmsl_custom.dir/main.cpp.o
[ 50%] Building CXX object src/rectifier/CMakeFiles/sample_video_rectifier.dir/main.cpp.o
[ 50%] Building CXX object src/template/CMakeFiles/sample_template.dir/main.cpp.o
[ 50%] Linking CXX executable sample_rig_configuration
[ 50%] Linking CXX executable sample_hello_world
/home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/../../libexec/aarch64-gnu-linux/gcc/aarch64-gnu-linux/4.9.2/ld: warning: libnvinfer.so.4, needed by /usr/local/driveworks-0.6/targets/aarch64-linux/lib/libdriveworks.so, not found (try using -rpath or -rpath-link)
/home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/../../libexec/aarch64-gnu-linux/gcc/aarch64-gnu-linux/4.9.2/ld: warning: libnvparsers.so.4.0.2, needed by /usr/local/driveworks-0.6/targets/aarch64-linux/lib/libdriveworks.so, not found (try using -rpath or -rpath-link)
/usr/local/driveworks-0.6/targets/aarch64-linux/lib/libdriveworks.so: undefined reference to `createInferRuntime_INTERNAL'
/usr/local/driveworks-0.6/targets/aarch64-linux/lib/libdriveworks.so: undefined reference to `getInferLibVersion'
collect2: error: ld returned 1 exit status
src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/build.make:107: recipe for target 'src/rigconfiguration/sample_rig_configuration' failed
make[2]: *** [src/rigconfiguration/sample_rig_configuration] Error 1
CMakeFiles/Makefile2:1527: recipe for target 'src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/all' failed
make[1]: *** [src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 51%] Linking CXX executable sample_renderer
[ 52%] Linking CXX executable sample_camera_pointgrey
[ 53%] Linking CXX executable sample_gps_logger
src/hello_world/CMakeFiles/sample_hello_world.dir/build.make:107: recipe for target 'src/hello_world/sample_hello_world' failed
make[2]: *** [src/hello_world/sample_hello_world] Error 1
CMakeFiles/Makefile2:2295: recipe for target 'src/hello_world/CMakeFiles/sample_hello_world.dir/all' failed
make[1]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/all] Error 2
[ 54%] Linking CXX executable sample_imu_logger
src/renderer/CMakeFiles/sample_renderer.dir/build.make:107: recipe for target 'src/renderer/sample_renderer' failed
make[2]: *** [src/renderer/sample_renderer] Error 1
CMakeFiles/Makefile2:1582: recipe for target 'src/renderer/CMakeFiles/sample_renderer.dir/all' failed
make[1]: *** [src/renderer/CMakeFiles/sample_renderer.dir/all] Error 2
src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/build.make:133: recipe for target 'src/sensors/camera_pointgrey/sample_camera_pointgrey' failed
make[2]: *** [src/sensors/camera_pointgrey/sample_camera_pointgrey] Error 1
CMakeFiles/Makefile2:718: recipe for target 'src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/all' failed
make[1]: *** [src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/all] Error 2
src/sensors/gps/CMakeFiles/sample_gps_logger.dir/build.make:107: recipe for target 'src/sensors/gps/sample_gps_logger' failed
make[2]: *** [src/sensors/gps/sample_gps_logger] Error 1
CMakeFiles/Makefile2:388: recipe for target 'src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all' failed
make[1]: *** [src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all] Error 2
[ 55%] Linking CXX executable sample_sensors_info
[ 55%] Linking CXX executable sample_third_party_camera
/home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/../../libexec/aarch64-gnu-linux/gcc/aarch64-gnu-linux/4.9.2/ld: warning: libnvinfer.so.4, needed by /usr/local/driveworks-0.6/targets/aarch64-linux/lib/libdriveworks.so, not found ([ 56%] Linking CXX executable sample_canbus_interpreter
src/sensors/imu/CMakeFiles/sample_imu_logger.dir/build.make:107: recipe for target 'src/sensors/imu/sample_imu_logger' failed
make[2]: *** [src/sensors/imu/sample_imu_logger] Error 1
CMakeFiles/Makefile2:443: recipe for target 'src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all' failed
make[1]: *** [src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all] Error 2
[ 57%] Linking CXX executable sample_camera_usb
[ 58%] Linking CXX executable sample_camera_multiple_replay
[ 58%] Linking CXX static library libdw_samples_dnn_common.a
src/sensors/info/CMakeFiles/sample_sensors_info.dir/build.make:107: recipe for target 'src/sensors/info/sample_sensors_info' failed
make[2]: *** [src/sensors/info/sample_sensors_info] Error 1
CMakeFiles/Makefile2:333: recipe for target 'src/sensors/info/CMakeFiles/sample_sensors_info.dir/all' failed
make[1]: *** [src/sensors/info/CMakeFiles/sample_sensors_info.dir/all] Error 2
[ 59%] Linking CXX executable sample_lidar_replay
src/sensors/third_party_camera/CMakeFiles/sample_third_party_camera.dir/build.make:107: recipe for target 'src/sensors/third_party_camera/sample_third_party_camera' failed
make[2]: *** [src/sensors/third_party_camera/sample_third_party_camera] Error 1
CMakeFiles/Makefile2:1048: recipe for target 'src/sensors/third_party_camera/CMakeFiles/sample_third_party_camera.dir/all' failed
make[1]: *** [src/sensors/third_party_camera/CMakeFiles/sample_third_party_camera.dir/all] Error 2
[ 59%] Built target dw_samples_dnn_common
src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/build.make:133: recipe for target 'src/sensors/canbus/interpreter/sample_canbus_interpreter' failed
make[2]: *** [src/sensors/canbus/interpreter/sample_canbus_interpreter] Error 1
CMakeFiles/Makefile2:883: recipe for target 'src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/all' failed
make[1]: *** [src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/all] Error 2
src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/build.make:134: recipe for target 'src/sensors/camera_usb/sample_camera_usb' failed
make[2]: *** [src/sensors/camera_usb/sample_camera_usb] Error 1
CMakeFiles/Makefile2:663: recipe for target 'src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/all' failed
make[1]: *** [src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/all] Error 2
src/sensors/camera_multiple_replay/CMakeFiles/sample_camera_multiple_replay.dir/build.make:107: recipe for target 'src/sensors/camera_multiple_replay/sample_camera_multiple_replay' failed
make[2]: *** [src/sensors/camera_multiple_replay/sample_camera_multiple_replay] Error 1
CMakeFiles/Makefile2:608: recipe for target 'src/sensors/camera_multiple_replay/CMakeFiles/sample_camera_multiple_replay.dir/all' failed
make[1]: *** [src/sensors/camera_multiple_replay/CMakeFiles/sample_camera_multiple_replay.dir/all] Error 2
[ 59%] Linking CXX executable sample_image_streamer_cross
[ 60%] Linking CXX executable sample_color_correction
[ 60%] Linking CXX executable sample_canbus_logger
src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/build.make:133: recipe for target 'src/sensors/lidar/lidar_replay/sample_lidar_replay' failed
make[2]: *** [src/sensors/lidar/lidar_replay/sample_lidar_replay] Error 1
CMakeFiles/Makefile2:938: recipe for target 'src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all' failed
make[1]: *** [src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all] Error 2
Scanning dependencies of target dw_samples_image_common
src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/build.make:110: recipe for target 'src/image/image_streamer_cross_process/sample_image_streamer_cross' failed
make[2]: *** [src/image/image_streamer_cross_process/sample_image_streamer_cross] Error 1
CMakeFiles/Makefile2:2603: recipe for target 'src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/all' failed
make[1]: *** [src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/all] Error 2
[ 61%] Linking CXX static library libdw_samples_image_common.a
src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/build.make:107: recipe for target 'src/sensors/canbus/logger/sample_canbus_logger' failed
make[2]: *** [src/sensors/canbus/logger/sample_canbus_logger] Error 1
CMakeFiles/Makefile2:828: recipe for target 'src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/all' failed
make[1]: *** [src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/all] Error 2
[ 62%] Linking CXX executable sample_camera_gmsl
src/colorcorrection/CMakeFiles/sample_color_correction.dir/build.make:107: recipe for target 'src/colorcorrection/sample_color_correction' failed
make[2]: *** [src/colorcorrection/sample_color_correction] Error 1
CMakeFiles/Makefile2:2075: recipe for target 'src/colorcorrection/CMakeFiles/sample_color_correction.dir/all' failed
make[1]: *** [src/colorcorrection/CMakeFiles/sample_color_correction.dir/all] Error 2
[ 63%] Linking CXX executable sample_camera_tracker
[ 63%] Built target dw_samples_image_common
[ 63%] Linking CXX static library libdw_samples_laneDetection_common.a
[ 63%] Linking CXX executable sample_camera_gmsl_raw
[ 63%] Built target dw_samples_laneDetection_common
src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/build.make:108: recipe for target 'src/sensors/camera_gmsl/sample_camera_gmsl' failed
make[2]: *** [src/sensors/camera_gmsl/sample_camera_gmsl] Error 1
CMakeFiles/Makefile2:1103: recipe for target 'src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/all' failed
make[1]: *** [src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/all] Error 2
[ 64%] Linking CXX executable sample_ipc_socketclientserver
src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/build.make:159: recipe for target 'src/features/camera_tracker/sample_camera_tracker' failed
make[2]: *** [src/features/camera_tracker/sample_camera_tracker] Error 1
CMakeFiles/Makefile2:1344: recipe for target 'src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/all' failed
make[1]: *** [src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/all] Error 2
src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/build.make:108: recipe for target 'src/sensors/camera_gmsl_raw/sample_camera_gmsl_raw' failed
make[2]: *** [src/sensors/camera_gmsl_raw/sample_camera_gmsl_raw] Error 1
CMakeFiles/Makefile2:1268: recipe for target 'src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/all' failed
make[1]: *** [src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/all] Error 2
[ 64%] Linking CXX executable sample_isp
[ 64%] Linking CXX executable sample_egomotion
[ 64%] Linking CXX executable sample_occupancy_grid
[ 65%] Linking CXX executable sample_record
src/isp/CMakeFiles/sample_isp.dir/build.make:110: recipe for target 'src/isp/sample_isp' failed
make[2]: *** [src/isp/sample_isp] Error 1
CMakeFiles/Makefile2:2130: recipe for target 'src/isp/CMakeFiles/sample_isp.dir/all' failed
make[1]: *** [src/isp/CMakeFiles/sample_isp.dir/all] Error 2
[ 66%] Linking CXX executable sample_template
[ 67%] Linking CXX executable sample_vehicleio
src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/build.make:107: recipe for target 'src/ipc/sample_ipc_socketclientserver' failed
make[2]: *** [src/ipc/sample_ipc_socketclientserver] Error 1
CMakeFiles/Makefile2:2240: recipe for target 'src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/all' failed
make[1]: *** [src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/all] Error 2
src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/build.make:107: recipe for target 'src/mapping/occupancy_grid/sample_occupancy_grid' failed
make[2]: *** [src/mapping/occupancy_grid/sample_occupancy_grid] Error 1
CMakeFiles/Makefile2:1472: recipe for target 'src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/all' failed
make[1]: *** [src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/all] Error 2
Scanning dependencies of target dw_samples_stereo_common
[ 68%] Linking CXX executable sample_maps
src/sensors/record/CMakeFiles/sample_record.dir/build.make:107: recipe for target 'src/sensors/record/sample_record' failed
make[2]: *** [src/sensors/record/sample_record] Error 1
CMakeFiles/Makefile2:773: recipe for target 'src/sensors/record/CMakeFiles/sample_record.dir/all' failed
make[1]: *** [src/sensors/record/CMakeFiles/sample_record.dir/all] Error 2
src/egomotion/CMakeFiles/sample_egomotion.dir/build.make:107: recipe for target 'src/egomotion/sample_egomotion' failed
make[2]: *** [src/egomotion/sample_egomotion] Error 1
CMakeFiles/Makefile2:209: recipe for target 'src/egomotion/CMakeFiles/sample_egomotion.dir/all' failed
make[1]: *** [src/egomotion/CMakeFiles/sample_egomotion.dir/all] Error 2
src/vehicleio/CMakeFiles/sample_vehicleio.dir/build.make:107: recipe for target 'src/vehicleio/sample_vehicleio' failed
make[2]: *** [src/vehicleio/sample_vehicleio] Error 1
CMakeFiles/Makefile2:3508: recipe for target 'src/vehicleio/CMakeFiles/sample_vehicleio.dir/all' failed
make[1]: *** [src/vehicleio/CMakeFiles/sample_vehicleio.dir/all] Error 2
[ 69%] Linking CXX executable sample_video_rectifier
[ 70%] Building CXX object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/stereoCommon.cpp.o
[ 70%] Linking CXX executable sample_camera_replay
src/template/CMakeFiles/sample_template.dir/build.make:107: recipe for target 'src/template/sample_template' failed
make[2]: *** [src/template/sample_template] Error 1
CMakeFiles/Makefile2:3269: recipe for target 'src/template/CMakeFiles/sample_template.dir/all' failed
make[1]: *** [src/template/CMakeFiles/sample_template.dir/all] Error 2
src/maps/CMakeFiles/sample_maps.dir/build.make:107: recipe for target 'src/maps/sample_maps' failed
make[2]: *** [src/maps/sample_maps] Error 1
CMakeFiles/Makefile2:3214: recipe for target 'src/maps/CMakeFiles/sample_maps.dir/all' failed
make[1]: *** [src/maps/CMakeFiles/sample_maps.dir/all] Error 2
[ 71%] Linking CXX executable sample_camera_gmsl_custom
/home/gris/append/NVIDIA/Drive/5050bL_SDK/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64[ 72%] Linking CXX executable sample_camera_multiple_gmsl
src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/build.make:107: recipe for target 'src/sensors/camera_replay/sample_camera_replay' failed
make[2]: *** [src/sensors/camera_replay/sample_camera_replay] Error 1
CMakeFiles/Makefile2:498: recipe for target 'src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/all' failed
make[1]: *** [src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/all] Error 2
src/rectifier/CMakeFiles/sample_video_rectifier.dir/build.make:108: recipe for target 'src/rectifier/sample_video_rectifier' failed
make[2]: *** [src/rectifier/sample_video_rectifier] Error 1
CMakeFiles/Makefile2:2185: recipe for target 'src/rectifier/CMakeFiles/sample_video_rectifier.dir/all' failed
make[1]: *** [src/rectifier/CMakeFiles/sample_video_rectifier.dir/all] Error 2
[ 73%] Linking CXX executable sample_camera_seek
src/sensors/camera_gmsl_custom/CMakeFiles/sample_camera_gmsl_custom.dir/build.make:134: recipe for target 'src/sensors/camera_gmsl_custom/sample_camera_gmsl_custom' failed
make[2]: *** [src/sensors/camera_gmsl_custom/sample_camera_gmsl_custom] Error 1
CMakeFiles/Makefile2:1158: recipe for target 'src/sensors/camera_gmsl_custom/CMakeFiles/sample_camera_gmsl_custom.dir/all' failed
make[1]: *** [src/sensors/camera_gmsl_custom/CMakeFiles/sample_camera_gmsl_custom.dir/all] Error 2
src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/build.make:108: recipe for target 'src/sensors/camera_multiple_gmsl/sample_camera_multiple_gmsl' failed
make[2]: *** [src/sensors/camera_multiple_gmsl/sample_camera_multiple_gmsl] Error 1
CMakeFiles/Makefile2:1213: recipe for target 'src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/all' failed
make[1]: *** [src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/all] Error 2
src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/build.make:107: recipe for target 'src/sensors/camera_seek/sample_camera_seek' failed
make[2]: *** [src/sensors/camera_seek/sample_camera_seek] Error 1
CMakeFiles/Makefile2:553: recipe for target 'src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/all' failed
make[1]: *** [src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/all] Error 2
[ 73%] Linking CXX executable sample_radar_replay
src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/build.make:133: recipe for target 'src/sensors/radar/radar_replay/sample_radar_replay' failed
make[2]: *** [src/sensors/radar/radar_replay/sample_radar_replay] Error 1
CMakeFiles/Makefile2:993: recipe for target 'src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all' failed
make[1]: *** [src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all] Error 2
[ 74%] Linking CXX executable sample_icp
src/icp/CMakeFiles/sample_icp.dir/build.make:107: recipe for target 'src/icp/sample_icp' failed
make[2]: *** [src/icp/sample_icp] Error 1
CMakeFiles/Makefile2:3324: recipe for target 'src/icp/CMakeFiles/sample_icp.dir/all' failed
make[1]: *** [src/icp/CMakeFiles/sample_icp.dir/all] Error 2
[ 74%] Linking CXX static library libdw_samples_stereo_common.a
[ 74%] Built target dw_samples_stereo_common
[ 75%] Linking CXX executable sample_lidar_accumulator
src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/build.make:133: recipe for target 'src/lidar_accumulator/sample_lidar_accumulator' failed
make[2]: *** [src/lidar_accumulator/sample_lidar_accumulator] Error 1
CMakeFiles/Makefile2:3379: recipe for target 'src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/all' failed
make[1]: *** [src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/all] Error 2
[ 76%] Linking CXX executable sample_sfm
[ 77%] Linking CXX executable sample_camera_scaling_tracker
src/sfm/CMakeFiles/sample_sfm.dir/build.make:159: recipe for target 'src/sfm/sample_sfm' failed
make[2]: *** [src/sfm/sample_sfm] Error 1
CMakeFiles/Makefile2:1637: recipe for target 'src/sfm/CMakeFiles/sample_sfm.dir/all' failed
make[1]: *** [src/sfm/CMakeFiles/sample_sfm.dir/all] Error 2
please help!
