Thanks for the response SivaRamaKrishna
I have double checked it. All prerequisites are installed and working as far as I can tell.
(1) is the output of cmake -DCMAKE_BUILD_TYPE=Release /usr/local/driveworks-0.6/samples/
(2) is the output of make -j (This is extremely long)
(1)
– The C compiler identification is GNU 5.4.0
– The CXX compiler identification is GNU 5.4.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found CUDA: /usr/local/cuda-9.0 (found version “9.0”)
– Looking for pthread.h
– Looking for pthread.h - found
– Looking for pthread_create
– Looking for pthread_create - not found
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Found TensorRT:
– - Includes: /usr/local/nvidia/tensorrt/targets/x86_64-linux-gnu/include
– - Libraries: /usr/local/nvidia/tensorrt/targets/x86_64-linux-gnu/lib/libnvinfer.so;/usr/local/nvidia/tensorrt/targets/x86_64-linux-gnu/lib/libnvcaffe_parser.so
– Found libcudnn:
– - Includes: /usr/local/cuda-9.0/include
– - Libraries: /usr/local/cuda-9.0/targets/x86_64-linux/lib/libcudnn.so
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Looking for IceConnectionNumber in ICE
– Looking for IceConnectionNumber in ICE - found
– Found X11: /usr/lib/x86_64-linux-gnu/libX11.so
– Driveworks Samples install dir: /home/tim/Driveworks/build2/install
– Driveworks found at: /usr/local/driveworks-0.6/targets/x86_64-linux
– Found Driveworks
– Configuring done
– Generating done
– Build files have been written to: /home/tim/Driveworks/build2
(2)
Scanning dependencies of target update_cuda_deps
Scanning dependencies of target dw_samples_framework
[ 2%] Dependencies for /home/tim/Driveworks/build2/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.stamp
[ 2%] Dependencies for /home/tim/Driveworks/build2/src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir//gen_utils.cu.o.depend.stamp
[ 3%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SampleFramework.cpp.o
[ 3%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProgramArguments.cpp.o
[ 4%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Log.cpp.o
[ 5%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/WindowGLFW.cpp.o
[ 6%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/Grid.cpp.o
[ 7%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/ProfilerCUDA.cpp.o
[ 12%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/GenericImage.cpp.o
[ 8%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MathUtils.cpp.o
[ 8%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/MouseView3D.cpp.o
[ 12%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/DriveWorksSample.cpp.o
[ 12%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRenderer.cpp.o
[ 12%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleRecordingPlayer.cpp.o
[ 12%] Building CXX object src/framework/CMakeFiles/dw_samples_framework.dir/SimpleCamera.cpp.o
[ 12%] Built target update_cuda_deps
[ 13%] Linking CXX static library libdw_samples_framework.a
[ 13%] Built target dw_samples_framework
Scanning dependencies of target sample_canbus_logger
Scanning dependencies of target sample_egomotion
Scanning dependencies of target sample_camera_pointgrey
[ 14%] Building NVCC (Device) object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/gen_utils.cu.o
Scanning dependencies of target sample_icp
Scanning dependencies of target sample_template
Scanning dependencies of target sample_hello_world
Scanning dependencies of target sample_imu_logger
Scanning dependencies of target sample_camera_seek
Scanning dependencies of target sample_lidar_replay
Scanning dependencies of target sample_camera_usb
Scanning dependencies of target sample_camera_tracker
Scanning dependencies of target sample_ipc_socketclientserver
Scanning dependencies of target sample_record
Scanning dependencies of target sample_occupancy_grid
Scanning dependencies of target sample_canbus_interpreter
Scanning dependencies of target sample_gps_logger
Scanning dependencies of target dw_samples_laneDetection_common
Scanning dependencies of target sample_isp
Scanning dependencies of target sample_camera_replay
Scanning dependencies of target sample_lidar_accumulator
Scanning dependencies of target sample_maps
[ 15%] Building CXX object src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/main.cpp.o
[ 16%] Building CXX object src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/main.cpp.o
[ 18%] Building CXX object src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/main.cpp.o
[ 19%] Building CXX object src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/sample_ipc_socketclientserver.cpp.o
[ 19%] Building CXX object src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/ResourceManager.cpp.o
[ 21%] Building CXX object src/template/CMakeFiles/sample_template.dir/main.cpp.o
Scanning dependencies of target dw_samples_drivenet_common
Scanning dependencies of target sample_camera_scaling_tracker
Scanning dependencies of target sample_sfm
Scanning dependencies of target sample_renderer
Scanning dependencies of target sample_rig_configuration
Scanning dependencies of target sample_camera_multiple_replay
Scanning dependencies of target sample_sensors_info
Scanning dependencies of target sample_radar_replay
[ 15%] Building NVCC (Device) object src/image/image_common/CMakeFiles/dw_samples_image_common.dir/gen_utils.cu.o
Scanning dependencies of target sample_video_rectifier
[ 22%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/main.cpp.o
[ 22%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/SensorIOCuda.cpp.o
[ 23%] Building CXX object src/icp/CMakeFiles/sample_icp.dir/main.cpp.o
[ 24%] Building CXX object src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/main.cpp.o
[ 26%] Building CXX object src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/main.cpp.o
[ 27%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/interpreter.cpp.o
[ 28%] Building CXX object src/maps/CMakeFiles/sample_maps.dir/main.cpp.o
Scanning dependencies of target dw_samples_dnn_common
Scanning dependencies of target sample_color_correction
Scanning dependencies of target sample_third_party_camera
Scanning dependencies of target sample_vehicleio
[ 17%] Building CXX object src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/ResourceManager.cpp.o
[ 20%] Building CXX object src/egomotion/CMakeFiles/sample_egomotion.dir/main.cpp.o
[ 21%] Building CXX object src/sensors/imu/CMakeFiles/sample_imu_logger.dir/main.cpp.o
[ 26%] Building CXX object src/sensors/gps/CMakeFiles/sample_gps_logger.dir/main.cpp.o
[ 28%] Building CXX object src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/main.cpp.o
[ 29%] Building CXX object src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/userInput.cpp.o
[ 30%] Building CXX object src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/main.cpp.o
[ 31%] Building CXX object src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/main.cpp.o
[ 32%] Building CXX object src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o
[ 33%] Building CXX object src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/main.cpp.o
[ 34%] Building CXX object src/renderer/CMakeFiles/sample_renderer.dir/main.cpp.o
[ 35%] Building CXX object src/laneDetection/laneDetection_common/CMakeFiles/dw_samples_laneDetection_common.dir/LaneDetectionCommon.cpp.o
[ 36%] Building CXX object src/vehicleio/CMakeFiles/sample_vehicleio.dir/main.cpp.o
[ 37%] Building CXX object src/sensors/camera_multiple_replay/CMakeFiles/sample_camera_multiple_replay.dir/main.cpp.o
[ 37%] Building CXX object src/isp/CMakeFiles/sample_isp.dir/main.cpp.o
[ 37%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/userInput.cpp.o
[ 39%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o
[ 40%] Building CXX object src/features/camera_scaling_tracker/CMakeFiles/sample_camera_scaling_tracker.dir/main.cpp.o
[ 38%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/main.cpp.o
[ 39%] Building CXX object src/sensors/record/CMakeFiles/sample_record.dir/main.cpp.o
[ 41%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/SensorIOCuda.cpp.o
[ 41%] Building CXX object src/dnn/dnn_common/CMakeFiles/dw_samples_dnn_common.dir/DNNInference.cpp.o
[ 42%] Building CXX object src/rectifier/CMakeFiles/sample_video_rectifier.dir/main.cpp.o
[ 45%] Building CXX object src/drivenet/common/CMakeFiles/dw_samples_drivenet_common.dir/common.cpp.o
[ 43%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/radarDynamics.cpp.o
[ 44%] Building CXX object src/sensors/info/CMakeFiles/sample_sensors_info.dir/main.cpp.o
[ 45%] Building CXX object src/colorcorrection/CMakeFiles/sample_color_correction.dir/main.cpp.o
[ 46%] Building CXX object src/sensors/third_party_camera/CMakeFiles/sample_third_party_camera.dir/main.cpp.o
[ 47%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/SensorIOCuda.cpp.o
[ 48%] Building CXX object src/sfm/CMakeFiles/sample_sfm.dir/main.cpp.o
[ 49%] Building CXX object src/drivenet/common/CMakeFiles/dw_samples_drivenet_common.dir/DriveNetApp.cpp.o
[ 49%] Linking CXX executable sample_rig_configuration
[ 50%] Linking CXX executable sample_camera_pointgrey
[ 51%] Linking CXX executable sample_renderer
[ 51%] Linking CXX executable sample_hello_world
[ 52%] Linking CXX executable sample_occupancy_grid
[ 53%] Linking CXX executable sample_gps_logger
[ 53%] Linking CXX executable sample_camera_usb
/usr/bin/ld: warning: libnvcuvid.so.1, needed by /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnvidia-fatbinaryloader.so.387.26, needed by //usr/lib/x86_64-linux-gnu/libcuda.so.1, not found (try using -rpath or -rpath-link)
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_shnum' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Get_FatBinary_From_Object’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Add_Cubin' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_section_contents’
/usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidParseVideoData' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_section_header’
/usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidCreateDecoder' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to gpuInfoRunsOn’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_section_header' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf_end’
/usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidCreateVideoSource' /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidCreateVideoParser’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_named_section_header' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_shnum’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Delete' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Finish_Reading_Library’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to fatBinaryCtl' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_symbol_shndx’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_typed_section_header' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to gpucompRestoreLogLine’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_file_header' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Free_Fatbinary’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_string_at_offset' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_symbol_shndx’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to fatBinaryCtl_Compile' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to fatBinaryCtl_PickCandidate’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_file_header' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_string_at_offset’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Load_Host_Object' /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidGetSourceVideoFormat’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Start' /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidDestroyVideoSource’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Start_Reading_Library' /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidMapVideoFrame64’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_typed_section_header' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Next_Library_Member’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to gpucompSetLogLine' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Finish’
/usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidDestroyDecoder' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_section_name’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf_is_64bit' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elfLink_Free_Host_Object’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_named_section_header' /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidDecodePicture’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf_size' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_symbol_name’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf32_section_name' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to fatBinaryCtl_Delete’
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to fatBinaryCtl_Create' //usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to elf64_symbol_name’
/usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidUnmapVideoFrame64' /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so: undefined reference to cuvidDestroyVideoParser’
collect2: error: ld returned 1 exit status
/usr/bin/ld: warning: libnvcuvid.so.1, needed by /usr/local/driveworks-0.6src/hello_world/CMakeFiles/sample_hello_world.dir/build.make:109: recipe for target ‘src/hello_world/sample_hello_world’ failed
make[2]: *** [src/hello_world/sample_hello_world] Error 1
CMakeFiles/Makefile2:2031: recipe for target ‘src/hello_world/CMakeFiles/sample_hello_world.dir/all’ failed
make[1]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/all] Error 2
/targetsmake[1]: *** Waiting for unfinished jobs…
/usr/bin/ld: warning: libnvcuvid.so.1, needed by /usr/local/driveworks-0.6/targets/x86_64-linux/lib/libdriveworks.so, not found (try using -rpath or src/renderer/CMakeFiles/sample_renderer.dir/build.make:109: recipe for target ‘src/renderer/sample_renderer’ failed
make[2]: *** [src/renderer/sample_renderer] Error 1
-rpath-link)
/usr/bin/CMakeFiles/Makefile2:1318: recipe for target ‘src/renderer/CMakeFiles/sample_renderer.dir/all’ failed
ld: warning: libnvidia-fatbinaryloader.so.387.26make[1]: *** [src/renderer/CMakeFiles/sample_renderer.dir/all] Error 2
src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/build.make:109: recipe for target ‘src/rigconfiguration/sample_rig_configuration’ failed
make[2]: *** [src/rigconfiguration/sample_rig_configuration] Error 1
CMakeFiles/Makefile2:1263: recipe for target ‘src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/all’ failed
make[1]: *** [src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/all] Error 2
[ 54%] Linking CXX executable sample_imu_logger
Scanning dependencies of target dw_samples_image_common
[ 54%] Linking CXX static library libdw_samples_image_common.a
[ 55%] Linking CXX executable sample_lidar_replay
[ 56%] Linking CXX executable sample_camera_multiple_replay
[ 56%] Built target dw_samples_image_common
src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/build.make:135: recipe for target ‘src/sensors/camera_pointgrey/sample_camera_pointgrey’ failed
make[2]: *** [src/sensors/camera_pointgrey/sample_camera_pointgrey] Error 1
CMakeFiles/Makefile2:674: recipe for target ‘src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/all’ failed
make[1]: *** [src/sensors/camera_pointgrey/CMakeFiles/sample_camera_pointgrey.dir/all] Error 2
[ 57%] Linking CXX executable sample_camera_tracker
[ 58%] Linking CXX executable sample_third_party_camera
src/sensors/gps/CMakeFiles/sample_gps_logger.dir/build.make:109: recipe for target ‘src/sensors/gps/sample_gps_logger’ failed
make[2]: *** [src/sensors/gps/sample_gps_logger] Error 1
CMakeFiles/Makefile2:344: recipe for target ‘src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all’ failed
make[1]: *** [src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all] Error 2
src/sensors/imu/CMakeFiles/sample_imu_logger.dir/build.make:109: recipe for target ‘src/sensors/imu/sample_imu_logger’ failed
make[2]: *** [src/sensors/imu/sample_imu_logger] Error 1
CMakeFiles/Makefile2:399: recipe for target ‘src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all’ failed
make[1]: *** [src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all] Error 2
Scanning dependencies of target dw_samples_stereo_common
src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/build.make:136: recipe for target ‘src/sensors/camera_usb/sample_camera_usb’ failed
make[2]: *** [src/sensors/camera_usb/sample_camera_usb] Error 1
CMakeFiles/Makefile2:619: recipe for target ‘src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/all’ failed
make[1]: *** [src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/all] Error 2
[ 59%] Linking CXX static library libdw_samples_laneDetection_common.a
src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/build.make:109: recipe for target ‘src/mapping/occupancy_grid/sample_occupancy_grid’ failed
make[2]: *** [src/mapping/occupancy_grid/sample_occupancy_grid] Error 1
CMakeFiles/Makefile2:1208: recipe for target ‘src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/all’ failed
make[1]: *** [src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/all] Error 2
[ 60%] Linking CXX executable sample_color_correction
[ 60%] Building CXX object src/stereo/stereo_common/CMakeFiles/dw_samples_stereo_common.dir/stereoCommon.cpp.o
[ 60%] Built target dw_samples_laneDetection_common
[ 61%] Linking CXX static library libdw_samples_dnn_common.a
[ 61%] Built target dw_samples_dnn_common
//usr/lib/x86_64-linux-[ 62%] Linking CXX executable sample_sensors_info
src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/build.make:135: recipe for target ‘src/sensors/lidar/lidar_replay/sample_lidar_replay’ failed
make[2]: *** [src/sensors/lidar/lidar_replay/sample_lidar_replay] Error 1
CMakeFiles/Makefile2:894: recipe for target ‘src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all’ failed
make[1]: *** [src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all] Error 2
[ 63%] Linking CXX executable sample_egomotion
//usr/lib/x86_64-linux-gnu/libcuda.so.1: undefined reference to `elf64_file_header’
//us
