Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
We are trying to cross compile the driveworks samples in our host system
When running CMake the build files are generated successfully (see log below)
soleng@agx-demo:~/build$ cmake -DCMAKE_BUILD_TYPE=Release \
> -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-4.0/samples/cmake/Toolchain-V5L.cmake \
> -DVIBRANTE_PDK:STRING=/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux -DTRT_VERSION:STRING=6.5.0.7 \
-- VIBRANTE_PDK = /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux
-- VIBRANTE_PDK_DEVICE = t186ref
-- VIBRANTE_PDK_BRANCH = 5.2.6.0
-- Vibrante version 5.2.6.0
-- The C compiler identification is GNU 7.3.1
-- The CXX compiler identification is GNU 7.3.1
-- Check for working C compiler: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/../toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc
-- Check for working C compiler: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/../toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/../toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++
-- Check for working CXX compiler: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/../toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ - works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- The CUDA compiler identification is NVIDIA 10.2.311
-- Check for working CUDA compiler: /usr/local/cuda/bin/nvcc
-- Check for working CUDA compiler: /usr/local/cuda/bin/nvcc - works
-- Detecting CUDA compiler ABI info
-- Detecting CUDA compiler ABI info - done
-- Detecting CUDA compile features
-- Detecting CUDA compile features - done
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Found EGL: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libEGL.so
-- Found /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libEGL.so:
-- - Includes: [/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/include]
-- - Libraries: [/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libEGL.so]
-- Found: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libdrm.so
-- Header at: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/include
-- DW_EXPERIMENTAL_FORCE_EGL set and EGL Support Enabled
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Cross Compiling for Vibrante
-- Building with TRT version 6.5.0.7 and cudnn version 7.6.6.415, pdk version 5.2.6.0
-- Building GLFW for X11 (static)
-- Found X11: /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/include
-- Looking for XOpenDisplay in /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libX11.so;/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libXext.so
-- Looking for XOpenDisplay in /home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libX11.so;/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/lib-target/libXext.so - not found
-- Looking for dnet_ntoa in dnet
-- Looking for dnet_ntoa in dnet - not found
-- Looking for dnet_ntoa in dnet_stub
-- Looking for dnet_ntoa in dnet_stub - not found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Found vibrante lib: /usr/local/driveworks-4.0/samples/3rdparty/linux-aarch64/vibrante/lib/libudev.so
-- Found vibrante lib: /usr/local/driveworks-4.0/samples/3rdparty/linux-aarch64/vibrante/lib/libusb-1.0.so
-- Found vibrante_Xlib: /usr/local/driveworks-4.0/samples/3rdparty/linux-aarch64/vibrante_Xlibs/lib/libXcursor.so
-- Driveworks Samples install dir: /home/soleng/build/install
-- Found 'dw/core/Version.h' in /usr/local/driveworks-4.0/targets/aarch64-Linux/include
-- Found dw_base library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_base.so
-- Found dw_calibration library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_calibration.so
-- Found dw_egomotion library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_egomotion.so
-- Found dw_imageprocessing library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_imageprocessing.so
-- Found dw_pointcloudprocessing library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_pointcloudprocessing.so
-- Found dw_sensors library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_sensors.so
-- Found dw_vehicleio library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_vehicleio.so
-- Found dw_dnn_base library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdw_dnn_base.so
-- Found 'dwvisualization/core/Visualization.h' in /usr/local/driveworks-4.0/targets/aarch64-Linux/include
-- Found driveworks_visualization library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdriveworks_visualization.so
-- optional driveworks_visualization_av library not found at /usr/local/driveworks-4.0/cmake/../targets/aarch64-Linux/lib;/usr/local/driveworks-4.0/cmake/../lib - ok
-- Found 'dw/core/DynamicMemory.h' in /usr/local/driveworks-4.0/targets/aarch64-Linux/include
-- Found dwdynamicmemory library in /usr/local/driveworks-4.0/targets/aarch64-Linux/lib/libdwdynamicmemory.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/soleng/build
But when we run make -j command, we get warnings and errors, please refer to the detailed log below
soleng@agx-demo:~/build$ make -j
Scanning dependencies of target lodepng-src
Scanning dependencies of target samples_allocator
Scanning dependencies of target create-data-symlink
Scanning dependencies of target samples_framework_nocuda
Scanning dependencies of target glfw-x11
[ 0%] Generating '_data' symbolic link
[ 0%] Building CXX object src/framework/CMakeFiles/samples_allocator.dir/Allocator.cpp.o
[ 1%] Building CXX object src/framework/CMakeFiles/samples_framework_nocuda.dir/ProgramArguments.cpp.o
[ 2%] Building CXX object 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/src/lodepng.cpp.o
[ 2%] Built target create-data-symlink
[ 3%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/init.c.o
[ 3%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/context.c.o
[ 4%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/vulkan.c.o
[ 5%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/input.c.o
[ 5%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/monitor.c.o
[ 5%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/x11_init.c.o
[ 6%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/window.c.o
[ 7%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/x11_monitor.c.o
[ 7%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/x11_window.c.o
[ 8%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/xkb_unicode.c.o
[ 9%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/linux_joystick.c.o
[ 9%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/posix_time.c.o
[ 10%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/posix_tls.c.o
[ 10%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/glx_context.c.o
[ 11%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/egl_context.c.o
[ 12%] Linking CXX static library libsamples_allocator.a
[ 12%] Built target samples_allocator
Scanning dependencies of target sample_imu_plugin
Scanning dependencies of target sample_can_plugin
Scanning dependencies of target sample_gps_plugin
[ 12%] Building CXX object src/sensors/plugins/imu/CMakeFiles/sample_imu_plugin.dir/main.cpp.o
[ 12%] Building CXX object src/sensors/plugins/canbus/CMakeFiles/sample_can_plugin.dir/main.cpp.o
[ 12%] Building CXX object src/sensors/plugins/gps/CMakeFiles/sample_gps_plugin.dir/main.cpp.o
[ 12%] Built target glfw-x11
Scanning dependencies of target glfw-src
[ 13%] Linking C shared library libglfw.so
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: total time in link: 0.010871
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: data size 5861376
[ 13%] Built target glfw-src
[ 14%] Linking CXX static library libsamples_framework_nocuda.a
[ 14%] Built target samples_framework_nocuda
[ 15%] Linking CXX shared library libsample_can_plugin.so
[ 16%] Linking CXX shared library libsample_imu_plugin.so
[ 17%] Linking CXX shared library libsample_gps_plugin.so
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: total time in link: 0.046859
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: data size 21762048
[ 17%] Built target sample_imu_plugin
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: total time in link: 0.065160
[ 17%] Built target sample_can_plugin
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: total time in link: 0.054963
[ 17%] Built target sample_gps_plugin
[ 17%] Linking CXX static library liblodepng-src.a
[ 17%] Built target lodepng-src
[ 17%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SampleFramework.cpp.o
[ 18%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/DriveWorksSample.cpp.o
[ 19%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/Window.cpp.o
[ 20%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/ProgramArguments.cpp.o
[ 20%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/DriveWorksSampleSeek.cpp.o
[ 20%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/Grid.cpp.o
[ 21%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/WindowGLFW.cpp.o
[ 22%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/ProfilerCUDA.cpp.o
[ 23%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/MathUtils.cpp.o
[ 23%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/Log.cpp.o
[ 23%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/MouseView3D.cpp.o
[ 24%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SimpleCamera.cpp.o
[ 25%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/CameraFramePipeline.cpp.o
[ 25%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SimpleRenderer.cpp.o
[ 26%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SimpleRecordingPlayer.cpp.o
[ 26%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/ScreenshotHelper.cpp.o
[ 27%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/RenderUtils.cpp.o
[ 28%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/SamplesDataPath.cpp.o
[ 29%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/WindowEGL.cpp.o
[ 29%] Building CXX object src/framework/CMakeFiles/samples_framework.dir/WindowLinuxEGL.cpp.o
[ 29%] Linking CXX static library libsamples_framework.a
[ 29%] Built target samples_framework
Scanning dependencies of target sample_egomotion
Scanning dependencies of target sample_imu_logger
Scanning dependencies of target sample_camera_replay
Scanning dependencies of target sample_sensors_info
Scanning dependencies of target sample_camera_seek
Scanning dependencies of target sample_record
Scanning dependencies of target sample_canbus_interpreter
Scanning dependencies of target sample_gps_logger
Scanning dependencies of target sample_radar_replay
Scanning dependencies of target sample_canbus_logger
Scanning dependencies of target sample_timesensor
Scanning dependencies of target sample_cameraserver_client
Scanning dependencies of target sample_lidar_replay
Scanning dependencies of target sample_camera_usb
Scanning dependencies of target sample_template_tracker
Scanning dependencies of target sample_feature_tracker
Scanning dependencies of target sample_cameraserver_client_raw
Scanning dependencies of target sample_stereo_disparity
Scanning dependencies of target sample_fast9_feature_detector
Scanning dependencies of target sample_hello_world
Scanning dependencies of target sample_image_pyramid_pva
Scanning dependencies of target sample_color_correction
Scanning dependencies of target sample_stereo_disparity_pva
Scanning dependencies of target sample_socket_ipc_clientserver
Scanning dependencies of target sample_calibration_camera
Scanning dependencies of target sample_imagetransformation
Scanning dependencies of target sample_denseopticalflow
Scanning dependencies of target sample_sfm
Scanning dependencies of target sample_renderer
Scanning dependencies of target sample_video_rectifier
Scanning dependencies of target sample_connected_components
Scanning dependencies of target dnn_pool_plugin
Scanning dependencies of target sample_rig
Scanning dependencies of target sample_calibration_radar
Scanning dependencies of target sample_pointcloudprocessing
Scanning dependencies of target sample_sfm_vehicleio_plugin
Scanning dependencies of target sample_object_detector_tracker
Scanning dependencies of target sample_render_engine
Scanning dependencies of target sample_datasensor
[ 30%] Building CXX object src/sensors/info/CMakeFiles/sample_sensors_info.dir/main.cpp.o
Scanning dependencies of target sample_dataspeedBridge
Scanning dependencies of target dw_samples_image_common
Scanning dependencies of target sample_vehicleio_plugin
Scanning dependencies of target sample_calibration_imu
Scanning dependencies of target sample_calibration_lidar
Scanning dependencies of target sample_dnn_tensor
Scanning dependencies of target sample_calibration_stereo
[ 31%] Building CXX object src/sensors/gps/CMakeFiles/sample_gps_logger.dir/main.cpp.o
[ 31%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/main.cpp.o
[ 31%] Building CXX object src/sensors/camera/camera_seek/CMakeFiles/sample_camera_seek.dir/main.cpp.o
[ 31%] Building CXX object src/sensors/time/CMakeFiles/sample_timesensor.dir/main.cpp.o
[ 32%] Building CXX object src/sensors/camera/camera_usb/CMakeFiles/sample_camera_usb.dir/main.cpp.o
[ 33%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o
[ 33%] Building CXX object src/egomotion/CMakeFiles/sample_egomotion.dir/main.cpp.o
[ 30%] Building CXX object src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/main.cpp.o
Scanning dependencies of target sample_icp
[ 30%] Building CXX object src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o
[ 34%] Building CXX object src/sensors/imu/CMakeFiles/sample_imu_logger.dir/main.cpp.o
Scanning dependencies of target sample_calibration_steering
[ 35%] Building CXX object src/sensors/camera/cameraserver_client/CMakeFiles/sample_cameraserver_client.dir/main.cpp.o
[ 35%] Building CXX object src/comms/sample_socket_ipc/CMakeFiles/sample_socket_ipc_clientserver.dir/sample_ipc_socketclientserver.cpp.o
[ 35%] Building CXX object src/sensors/camera/camera_replay/CMakeFiles/sample_camera_replay.dir/main.cpp.o
[ 35%] Building CXX object src/imageprocessing/template_tracker/CMakeFiles/sample_template_tracker.dir/main.cpp.o
[ 35%] Building CXX object src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/main.cpp.o
[ 36%] Building CXX object src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/interpreter.cpp.o
[ 37%] Building CXX object src/sensors/camera/camera/CMakeFiles/sample_camera.dir/main.cpp.o
[ 38%] Building CXX object src/sensors/camera/cameraserver_client_raw/CMakeFiles/sample_cameraserver_client_raw.dir/main.cpp.o
[ 39%] Building CXX object src/imageprocessing/colorcorrection/CMakeFiles/sample_color_correction.dir/main.cpp.o
[ 39%] Building CXX object src/imageprocessing/sfm/CMakeFiles/sample_sfm_vehicleio_plugin.dir/vehicleio_plugin.cpp.o
[ 41%] Building CXX object src/visualization/render_engine/CMakeFiles/sample_render_engine.dir/main.cpp.o
[ 41%] Building CXX object src/imageprocessing/feature_tracker/CMakeFiles/sample_feature_tracker.dir/main.cpp.o
[ 42%] Building CXX object src/sensors/record/CMakeFiles/sample_record.dir/main.cpp.o
[ 43%] Building CXX object src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/main.cpp.o
[ 44%] Building CXX object src/imageprocessing/fast9_feature_detector/CMakeFiles/sample_fast9_feature_detector.dir/main.cpp.o
[ 45%] Building CXX object src/vehicleio_plugin/CMakeFiles/sample_vehicleio_plugin.dir/driver.cpp.o
[ 46%] Building CXX object src/imageprocessing/geometry/rectifier/CMakeFiles/sample_video_rectifier.dir/main.cpp.o
[ 47%] Building CUDA object src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir/utils.cu.o
[ 47%] Building CXX object src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir/main.cpp.o
[ 48%] Building CXX object src/dnn/sample_dnn_plugin/CMakeFiles/dnn_pool_plugin.dir/PoolPlugin.cpp.o
[ 49%] Building CXX object src/imageprocessing/connected_components/CMakeFiles/sample_connected_components.dir/main.cpp.o
[ 49%] Building CXX object src/rig/CMakeFiles/sample_rig.dir/main.cpp.o
[ 50%] Building CUDA object src/image/image_common/CMakeFiles/dw_samples_image_common.dir/utils.cu.o
[ 51%] Building CXX object src/sensors/data/CMakeFiles/sample_datasensor.dir/main.cpp.o
[ 52%] Building CXX object src/template/CMakeFiles/sample_template.dir/main.cpp.o
[ 53%] Building CXX object src/imageprocessing/geometry/imagetransformation/CMakeFiles/sample_imagetransformation.dir/main.cpp.o
[ 54%] Building CXX object src/dnn/sample_object_detector_tracker/CMakeFiles/sample_object_detector_tracker.dir/main.cpp.o
[ 54%] Building CXX object src/dnn/sample_dnn_tensor/CMakeFiles/sample_dnn_tensor.dir/main.cpp.o
[ 55%] Building CXX object src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/main.cpp.o
[ 55%] Building CXX object src/pointcloudprocessing/CMakeFiles/sample_pointcloudprocessing.dir/main.cpp.o
[ 55%] Building CXX object src/visualization/renderer/CMakeFiles/sample_renderer.dir/main.cpp.o
[ 56%] Building CXX object src/vehicleio/CMakeFiles/sample_vehicleio.dir/main.cpp.o
[ 57%] Building CXX object src/calibration/stereo/CMakeFiles/sample_calibration_stereo.dir/main.cpp.o
[ 58%] Building CXX object src/imageprocessing/filtering/pyramid/CMakeFiles/sample_image_pyramid_pva.dir/main.cpp.o
[ 59%] Building CXX object src/imageprocessing/sfm/CMakeFiles/sample_sfm.dir/main.cpp.o
[ 60%] Building CXX object src/pointcloudprocessing/CMakeFiles/sample_pointcloudprocessing.dir/PointCloudProcessingSample.cpp.o
[ 60%] Building CXX object src/calibration/radar/CMakeFiles/sample_calibration_radar.dir/main.cpp.o
[ 60%] Building CXX object src/imageprocessing/stereo/stereoPVA/CMakeFiles/sample_stereo_disparity_pva.dir/main.cpp.o
[ 61%] Building CUDA object src/imageprocessing/stereo/stereoPVA/CMakeFiles/sample_stereo_disparity_pva.dir/utils.cu.o
[ 62%] Building CXX object src/icp/CMakeFiles/sample_icp.dir/main.cpp.o
[ 62%] Building CXX object src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/main.cpp.o
[ 63%] Building CXX object src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/main.cpp.o
[ 64%] Building CXX object src/calibration/vehicle/CMakeFiles/sample_calibration_steering.dir/main.cpp.o
[ 64%] Building CXX object src/imageprocessing/motion/denseopticalflow/CMakeFiles/sample_denseopticalflow.dir/main.cpp.o
[ 65%] Building CUDA object src/imageprocessing/motion/denseopticalflow/CMakeFiles/sample_denseopticalflow.dir/utils.cu.o
[ 66%] Linking CXX executable sample_hello_world
[ 67%] Linking CXX shared library libsample_sfm_vehicleio_plugin.so
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: warning: libbsd.so.0, needed by /usr/lib/aarch64-linux-gnu/libXdmcp.so.6, not found (try using -rpath or -rpath-link)
/usr/lib/aarch64-linux-gnu/libXdmcp.so.6: Warnung: undefinierter Verweis auf »arc4random_buf@LIBBSD_0.2«
collect2: Fehler: ld gab 1 als Ende-Status zurück
src/hello_world/CMakeFiles/sample_hello_world.dir/build.make:135: recipe for target 'src/hello_world/sample_hello_world' failed
make[2]: *** [src/hello_world/sample_hello_world] Error 1
CMakeFiles/Makefile2:3029: recipe for target 'src/hello_world/CMakeFiles/sample_hello_world.dir/all' failed
make[1]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/all] Error 2
make[1]: *** Auf noch nicht beendete Prozesse wird gewartet …
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: total time in link: 0.110397
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: data size 23257088
[ 67%] Linking CXX executable sample_sensors_info
[ 67%] Built target sample_sfm_vehicleio_plugin
[ 68%] Linking CXX executable sample_rig
[ 68%] Linking CXX shared library libsample_vehicleio_plugin.so
src/sensors/info/CMakeFiles/sample_sensors_info.dir/build.make:135: recipe for target 'src/sensors/info/sample_sensors_info' failed
make[2]: *** [src/sensors/info/sample_sensors_info] Error 1
CMakeFiles/Makefile2:1837: recipe for target 'src/sensors/info/CMakeFiles/sample_sensors_info.dir/all' failed
make[1]: *** [src/sensors/info/CMakeFiles/sample_sensors_info.dir/all] Error 2
src/rig/CMakeFiles/sample_rig.dir/build.make:135: recipe for target 'src/rig/sample_rig' failed
make[2]: *** [src/rig/sample_rig] Error 1
CMakeFiles/Makefile2:2788: recipe for target 'src/rig/CMakeFiles/sample_rig.dir/all' failed
make[1]: *** [src/rig/CMakeFiles/sample_rig.dir/all] Error 2
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: total time in link: 0.116309
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: data size 23322624
[ 68%] Built target sample_vehicleio_plugin
[ 69%] Linking CXX executable sample_dataspeedBridge
[ 69%] Linking CXX static library libdw_samples_image_common.a
[ 70%] Linking CXX executable sample_canbus_interpreter
[ 70%] Built target dw_samples_image_common
src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/build.make:135: recipe for target 'src/dataspeedBridge/sample_dataspeedBridge' failed
make[2]: *** [src/dataspeedBridge/sample_dataspeedBridge] Error 1
CMakeFiles/Makefile2:3513: recipe for target 'src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/all' failed
make[1]: *** [src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/all] Error 2
[ 71%] Linking CXX executable sample_imu_logger
[ 71%] Linking CXX shared library libdnn_pool_plugin.so
[ 71%] Linking CXX executable sample_datasensor
[ 72%] Linking CXX executable sample_canbus_logger
[ 73%] Linking CXX executable sample_gps_logger
[ 74%] Linking CXX executable sample_socket_ipc_clientserver
src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/build.make:150: recipe for target 'src/sensors/canbus/interpreter/sample_canbus_interpreter' failed
make[2]: *** [src/sensors/canbus/interpreter/sample_canbus_interpreter] Error 1
CMakeFiles/Makefile2:2047: recipe for target 'src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/all' failed
make[1]: *** [src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/all] Error 2
[ 75%] Linking CXX executable sample_lidar_replay
[ 76%] Linking CXX executable sample_renderer
src/sensors/imu/CMakeFiles/sample_imu_logger.dir/build.make:135: recipe for target 'src/sensors/imu/sample_imu_logger' failed
make[2]: *** [src/sensors/imu/sample_imu_logger] Error 1
CMakeFiles/Makefile2:1897: recipe for target 'src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all' failed
make[1]: *** [src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all] Error 2
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: total time in link: 0.137226
/home/soleng/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: data size 23740416
[ 77%] Linking CXX executable sample_template
[ 77%] Built target dnn_pool_plugin
[ 78%] Linking CXX executable sample_camera_seek
src/sensors/gps/CMakeFiles/sample_gps_logger.dir/build.make:135: recipe for target 'src/sensors/gps/sample_gps_logger' failed
make[2]: *** [src/sensors/gps/sample_gps_logger] Error 1
CMakeFiles/Makefile2:1867: recipe for target 'src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all' failed
make[1]: *** [src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all] Error 2
src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/build.make:135: recipe for target 'src/sensors/canbus/logger/sample_canbus_logger' failed
make[2]: *** [src/sensors/canbus/logger/sample_canbus_logger] Error 1
CMakeFiles/Makefile2:2017: recipe for target 'src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/all' failed
make[1]: *** [src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/all] Error 2
src/sensors/data/CMakeFiles/sample_datasensor.dir/build.make:135: recipe for target 'src/sensors/data/sample_datasensor' failed
make[2]: *** [src/sensors/data/sample_datasensor] Error 1
CMakeFiles/Makefile2:2278: recipe for target 'src/sensors/data/CMakeFiles/sample_datasensor.dir/all' failed
make[1]: *** [src/sensors/data/CMakeFiles/sample_datasensor.dir/all] Error 2
src/comms/sample_socket_ipc/CMakeFiles/sample_socket_ipc_clientserver.dir/build.make:135: recipe for target 'src/comms/sample_socket_ipc/sample_socket_ipc_clientserver' failed
make[2]: *** [src/comms/sample_socket_ipc/sample_socket_ipc_clientserver] Error 1
CMakeFiles/Makefile2:2999: recipe for target 'src/comms/sample_socket_ipc/CMakeFiles/sample_socket_ipc_clientserver.dir/all' failed
make[1]: *** [src/comms/sample_socket_ipc/CMakeFiles/sample_socket_ipc_clientserver.dir/all] Error 2
src/visualization/renderer/CMakeFiles/sample_renderer.dir/build.make:135: recipe for target 'src/visualization/renderer/sample_renderer' failed
make[2]: *** [src/visualization/renderer/sample_renderer] Error 1
CMakeFiles/Makefile2:2818: recipe for target 'src/visualization/renderer/CMakeFiles/sample_renderer.dir/all' failed
make[1]: *** [src/visualization/renderer/CMakeFiles/sample_renderer.dir/all] Error 2
src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/build.make:135: recipe for target 'src/sensors/lidar/lidar_replay/sample_lidar_replay' failed
make[2]: *** [src/sensors/lidar/lidar_replay/sample_lidar_replay] Error 1
CMakeFiles/Makefile2:2077: recipe for target 'src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all' failed
make[1]: *** [src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all] Error 2
[ 79%] Linking CXX executable sample_timesensor
src/template/CMakeFiles/sample_template.dir/build.make:135: recipe for target 'src/template/sample_template' failed
make[2]: *** [src/template/sample_template] Error 1
CMakeFiles/Makefile2:3213: recipe for target 'src/template/CMakeFiles/sample_template.dir/all' failed
make[1]: *** [src/template/CMakeFiles/sample_template.dir/all] Error 2
src/sensors/camera/camera_seek/CMakeFiles/sample_camera_seek.dir/build.make:137: recipe for target 'src/sensors/camera/camera_seek/sample_camera_seek' failed
make[2]: *** [src/sensors/camera/camera_seek/sample_camera_seek] Error 1
CMakeFiles/Makefile2:1957: recipe for target 'src/sensors/camera/camera_seek/CMakeFiles/sample_camera_seek.dir/all' failed
make[1]: *** [src/sensors/camera/camera_seek/CMakeFiles/sample_camera_seek.dir/all] Error 2
[ 80%] Linking CXX executable sample_render_engine
src/sensors/time/CMakeFiles/sample_timesensor.dir/build.make:135: recipe for target 'src/sensors/time/sample_timesensor' failed
make[2]: *** [src/sensors/time/sample_timesensor] Error 1
CMakeFiles/Makefile2:2218: recipe for target 'src/sensors/time/CMakeFiles/sample_timesensor.dir/all' failed
make[1]: *** [src/sensors/time/CMakeFiles/sample_timesensor.dir/all] Error 2
[ 81%] Linking CXX executable sample_camera_replay
[ 81%] Linking CXX executable sample_radar_replay
src/visualization/render_engine/CMakeFiles/sample_render_engine.dir/build.make:135: recipe for target 'src/visualization/render_engine/sample_render_engine' failed
make[2]: *** [src/visualization/render_engine/sample_render_engine] Error 1
CMakeFiles/Makefile2:2848: recipe for target 'src/visualization/render_engine/CMakeFiles/sample_render_engine.dir/all' failed
make[1]: *** [src/visualization/render_engine/CMakeFiles/sample_render_engine.dir/all] Error 2
[ 81%] Linking CXX executable sample_camera_usb
src/sensors/camera/camera_replay/CMakeFiles/sample_camera_replay.dir/build.make:135: recipe for target 'src/sensors/camera/camera_replay/sample_camera_replay' failed
make[2]: *** [src/sensors/camera/camera_replay/sample_camera_replay] Error 1
CMakeFiles/Makefile2:1927: recipe for target 'src/sensors/camera/camera_replay/CMakeFiles/sample_camera_replay.dir/all' failed
make[1]: *** [src/sensors/camera/camera_replay/CMakeFiles/sample_camera_replay.dir/all] Error 2
src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/build.make:135: recipe for target 'src/sensors/radar/radar_replay/sample_radar_replay' failed
make[2]: *** [src/sensors/radar/radar_replay/sample_radar_replay] Error 1
CMakeFiles/Makefile2:2107: recipe for target 'src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all' failed
make[1]: *** [src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all] Error 2
src/sensors/camera/camera_usb/CMakeFiles/sample_camera_usb.dir/build.make:135: recipe for target 'src/sensors/camera/camera_usb/sample_camera_usb' failed
make[2]: *** [src/sensors/camera/camera_usb/sample_camera_usb] Error 1
CMakeFiles/Makefile2:2368: recipe for target 'src/sensors/camera/camera_usb/CMakeFiles/sample_camera_usb.dir/all' failed
make[1]: *** [src/sensors/camera/camera_usb/CMakeFiles/sample_camera_usb.dir/all] Error 2
[ 82%] Linking CXX executable sample_cameraserver_client_raw
[ 82%] Linking CXX executable sample_connected_components
[ 82%] Linking CXX executable sample_record
[ 82%] Linking CXX executable sample_vehicleio
[ 83%] Linking CXX executable sample_color_correction
src/sensors/camera/cameraserver_client_raw/CMakeFiles/sample_cameraserver_client_raw.dir/build.make:135: recipe for target 'src/sensors/camera/cameraserver_client_raw/sample_cameraserver_client_raw' failed
make[2]: *** [src/sensors/camera/cameraserver_client_raw/sample_cameraserver_client_raw] Error 1
CMakeFiles/Makefile2:2338: recipe for target 'src/sensors/camera/cameraserver_client_raw/CMakeFiles/sample_cameraserver_client_raw.dir/all' failed
make[1]: *** [src/sensors/camera/cameraserver_client_raw/CMakeFiles/sample_cameraserver_client_raw.dir/all] Error 2
src/imageprocessing/connected_components/CMakeFiles/sample_connected_components.dir/build.make:135: recipe for target 'src/imageprocessing/connected_components/sample_connected_components' failed
make[2]: *** [src/imageprocessing/connected_components/sample_connected_components] Error 1
CMakeFiles/Makefile2:2458: recipe for target 'src/imageprocessing/connected_components/CMakeFiles/sample_connected_components.dir/all' failed
make[1]: *** [src/imageprocessing/connected_components/CMakeFiles/sample_connected_components.dir/all] Error 2
src/sensors/record/CMakeFiles/sample_record.dir/build.make:135: recipe for target 'src/sensors/record/sample_record' failed
make[2]: *** [src/sensors/record/sample_record] Error 1
CMakeFiles/Makefile2:1987: recipe for target 'src/sensors/record/CMakeFiles/sample_record.dir/all' failed
make[1]: *** [src/sensors/record/CMakeFiles/sample_record.dir/all] Error 2
src/vehicleio/CMakeFiles/sample_vehicleio.dir/build.make:137: recipe for target 'src/vehicleio/sample_vehicleio' failed
make[2]: *** [src/vehicleio/sample_vehicleio] Error 1
CMakeFiles/Makefile2:3453: recipe for target 'src/vehicleio/CMakeFiles/sample_vehicleio.dir/all' failed
make[1]: *** [src/vehicleio/CMakeFiles/sample_vehicleio.dir/all] Error 2
src/sensors/camera/cameraserver_client/CMakeFiles/sample_cameraserver_client.dir/build.make:135: recipe for target 'src/sensors/camera/cameraserver_client/sample_cameraserver_client' failed
make[2]: *** [src/sensors/camera/cameraserver_client/sample_cameraserver_client] Error 1
CMakeFiles/Makefile2:2308: recipe for target 'src/sensors/camera/cameraserver_client/CMakeFiles/sample_cameraserver_client.dir/all' failed
make[1]: *** [src/sensors/camera/cameraserver_client/CMakeFiles/sample_cameraserver_client.dir/all] Error 2
src/imageprocessing/colorcorrection/CMakeFiles/sample_color_correction.dir/build.make:135: recipe for target 'src/imageprocessing/colorcorrection/sample_color_correction' failed
make[2]: *** [src/imageprocessing/colorcorrection/sample_color_correction] Error 1
CMakeFiles/Makefile2:2548: recipe for target 'src/imageprocessing/colorcorrection/CMakeFiles/sample_color_correction.dir/all' failed
make[1]: *** [src/imageprocessing/colorcorrection/CMakeFiles/sample_color_correction.dir/all] Error 2
[ 84%] Linking CXX executable sample_video_rectifier
[ 85%] Linking CXX executable sample_image_pyramid_pva
[ 85%] Linking CXX executable sample_icp
src/imageprocessing/geometry/rectifier/CMakeFiles/sample_video_rectifier.dir/build.make:135: recipe for target 'src/imageprocessing/geometry/rectifier/sample_video_rectifier' failed
make[2]: *** [src/imageprocessing/geometry/rectifier/sample_video_rectifier] Error 1
CMakeFiles/Makefile2:2578: recipe for target 'src/imageprocessing/geometry/rectifier/CMakeFiles/sample_video_rectifier.dir/all' failed
make[1]: *** [src/imageprocessing/geometry/rectifier/CMakeFiles/sample_video_rectifier.dir/all] Error 2
src/imageprocessing/filtering/pyramid/CMakeFiles/sample_image_pyramid_pva.dir/build.make:135: recipe for target 'src/imageprocessing/filtering/pyramid/sample_image_pyramid_pva' failed
make[2]: *** [src/imageprocessing/filtering/pyramid/sample_image_pyramid_pva] Error 1
CMakeFiles/Makefile2:2758: recipe for target 'src/imageprocessing/filtering/pyramid/CMakeFiles/sample_image_pyramid_pva.dir/all' failed
make[1]: *** [src/imageprocessing/filtering/pyramid/CMakeFiles/sample_image_pyramid_pva.dir/all] Error 2
src/icp/CMakeFiles/sample_icp.dir/build.make:137: recipe for target 'src/icp/sample_icp' failed
make[2]: *** [src/icp/sample_icp] Error 1
CMakeFiles/Makefile2:3243: recipe for target 'src/icp/CMakeFiles/sample_icp.dir/all' failed
make[1]: *** [src/icp/CMakeFiles/sample_icp.dir/all] Error 2
[ 85%] Linking CXX executable sample_imagetransformation
[ 86%] Linking CXX executable sample_template_tracker
[ 86%] Linking CXX executable sample_fast9_feature_detector
src/imageprocessing/geometry/imagetransformation/CMakeFiles/sample_imagetransformation.dir/build.make:135: recipe for target 'src/imageprocessing/geometry/imagetransformation/sample_imagetransformation' failed
make[2]: *** [src/imageprocessing/geometry/imagetransformation/sample_imagetransformation] Error 1
CMakeFiles/Makefile2:2608: recipe for target 'src/imageprocessing/geometry/imagetransformation/CMakeFiles/sample_imagetransformation.dir/all' failed
make[1]: *** [src/imageprocessing/geometry/imagetransformation/CMakeFiles/sample_imagetransformation.dir/all] Error 2
src/imageprocessing/template_tracker/CMakeFiles/sample_template_tracker.dir/build.make:135: recipe for target 'src/imageprocessing/template_tracker/sample_template_tracker' failed
make[2]: *** [src/imageprocessing/template_tracker/sample_template_tracker] Error 1
CMakeFiles/Makefile2:2428: recipe for target 'src/imageprocessing/template_tracker/CMakeFiles/sample_template_tracker.dir/all' failed
make[1]: *** [src/imageprocessing/template_tracker/CMakeFiles/sample_template_tracker.dir/all] Error 2
[ 87%] Linking CXX executable sample_egomotion
src/imageprocessing/fast9_feature_detector/CMakeFiles/sample_fast9_feature_detector.dir/build.make:135: recipe for target 'src/imageprocessing/fast9_feature_detector/sample_fast9_feature_detector' failed
make[2]: *** [src/imageprocessing/fast9_feature_detector/sample_fast9_feature_detector] Error 1
CMakeFiles/Makefile2:2698: recipe for target 'src/imageprocessing/fast9_feature_detector/CMakeFiles/sample_fast9_feature_detector.dir/all' failed
make[1]: *** [src/imageprocessing/fast9_feature_detector/CMakeFiles/sample_fast9_feature_detector.dir/all] Error 2
src/egomotion/CMakeFiles/sample_egomotion.dir/build.make:137: recipe for target 'src/egomotion/sample_egomotion' failed
make[2]: *** [src/egomotion/sample_egomotion] Error 1
CMakeFiles/Makefile2:1807: recipe for target 'src/egomotion/CMakeFiles/sample_egomotion.dir/all' failed
make[1]: *** [src/egomotion/CMakeFiles/sample_egomotion.dir/all] Error 2
[ 88%] Linking CXX executable sample_camera
src/sensors/camera/camera/CMakeFiles/sample_camera.dir/build.make:137: recipe for target 'src/sensors/camera/camera/sample_camera' failed
make[2]: *** [src/sensors/camera/camera/sample_camera] Error 1
CMakeFiles/Makefile2:2248: recipe for target 'src/sensors/camera/camera/CMakeFiles/sample_camera.dir/all' failed
make[1]: *** [src/sensors/camera/camera/CMakeFiles/sample_camera.dir/all] Error 2
[ 88%] Linking CXX executable sample_denseopticalflow
[ 88%] Linking CXX executable sample_calibration_steering
src/imageprocessing/motion/denseopticalflow/CMakeFiles/sample_denseopticalflow.dir/build.make:152: recipe for target 'src/imageprocessing/motion/denseopticalflow/sample_denseopticalflow' failed
make[2]: *** [src/imageprocessing/motion/denseopticalflow/sample_denseopticalflow] Error 1
CMakeFiles/Makefile2:2728: recipe for target 'src/imageprocessing/motion/denseopticalflow/CMakeFiles/sample_denseopticalflow.dir/all' failed
make[1]: *** [src/imageprocessing/motion/denseopticalflow/CMakeFiles/sample_denseopticalflow.dir/all] Error 2
src/calibration/vehicle/CMakeFiles/sample_calibration_steering.dir/build.make:135: recipe for target 'src/calibration/vehicle/sample_calibration_steering' failed
make[2]: *** [src/calibration/vehicle/sample_calibration_steering] Error 1
CMakeFiles/Makefile2:3423: recipe for target 'src/calibration/vehicle/CMakeFiles/sample_calibration_steering.dir/all' failed
make[1]: *** [src/calibration/vehicle/CMakeFiles/sample_calibration_steering.dir/all] Error 2
[ 89%] Linking CXX executable sample_calibration_imu
src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/build.make:135: recipe for target 'src/calibration/imu/sample_calibration_imu' failed
make[2]: *** [src/calibration/imu/sample_calibration_imu] Error 1
CMakeFiles/Makefile2:3303: recipe for target 'src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/all' failed
make[1]: *** [src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/all] Error 2
[ 90%] Linking CXX executable sample_dnn_tensor
[ 90%] Linking CXX executable sample_sfm
src/dnn/sample_dnn_tensor/CMakeFiles/sample_dnn_tensor.dir/build.make:135: recipe for target 'src/dnn/sample_dnn_tensor/sample_dnn_tensor' failed
make[2]: *** [src/dnn/sample_dnn_tensor/sample_dnn_tensor] Error 1
CMakeFiles/Makefile2:2969: recipe for target 'src/dnn/sample_dnn_tensor/CMakeFiles/sample_dnn_tensor.dir/all' failed
make[1]: *** [src/dnn/sample_dnn_tensor/CMakeFiles/sample_dnn_tensor.dir/all] Error 2
src/imageprocessing/sfm/CMakeFiles/sample_sfm.dir/build.make:135: recipe for target 'src/imageprocessing/sfm/sample_sfm' failed
make[2]: *** [src/imageprocessing/sfm/sample_sfm] Error 1
CMakeFiles/Makefile2:2638: recipe for target 'src/imageprocessing/sfm/CMakeFiles/sample_sfm.dir/all' failed
make[1]: *** [src/imageprocessing/sfm/CMakeFiles/sample_sfm.dir/all] Error 2
[ 90%] Linking CXX executable sample_stereo_disparity_pva
[ 91%] Linking CXX executable sample_pointcloudprocessing
src/imageprocessing/stereo/stereoPVA/CMakeFiles/sample_stereo_disparity_pva.dir/build.make:150: recipe for target 'src/imageprocessing/stereo/stereoPVA/sample_stereo_disparity_pva' failed
make[2]: *** [src/imageprocessing/stereo/stereoPVA/sample_stereo_disparity_pva] Error 1
CMakeFiles/Makefile2:2518: recipe for target 'src/imageprocessing/stereo/stereoPVA/CMakeFiles/sample_stereo_disparity_pva.dir/all' failed
make[1]: *** [src/imageprocessing/stereo/stereoPVA/CMakeFiles/sample_stereo_disparity_pva.dir/all] Error 2
[ 91%] Linking CXX executable sample_object_detector_tracker
src/pointcloudprocessing/CMakeFiles/sample_pointcloudprocessing.dir/build.make:152: recipe for target 'src/pointcloudprocessing/sample_pointcloudprocessing' failed
make[2]: *** [src/pointcloudprocessing/sample_pointcloudprocessing] Error 1
CMakeFiles/Makefile2:3543: recipe for target 'src/pointcloudprocessing/CMakeFiles/sample_pointcloudprocessing.dir/all' failed
make[1]: *** [src/pointcloudprocessing/CMakeFiles/sample_pointcloudprocessing.dir/all] Error 2
src/dnn/sample_object_detector_tracker/CMakeFiles/sample_object_detector_tracker.dir/build.make:135: recipe for target 'src/dnn/sample_object_detector_tracker/sample_object_detector_tracker' failed
make[2]: *** [src/dnn/sample_object_detector_tracker/sample_object_detector_tracker] Error 1
CMakeFiles/Makefile2:2878: recipe for target 'src/dnn/sample_object_detector_tracker/CMakeFiles/sample_object_detector_tracker.dir/all' failed
make[1]: *** [src/dnn/sample_object_detector_tracker/CMakeFiles/sample_object_detector_tracker.dir/all] Error 2
[ 92%] Linking CXX executable sample_calibration_lidar
[ 93%] Linking CXX executable sample_calibration_radar
src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/build.make:137: recipe for target 'src/calibration/lidar/sample_calibration_lidar' failed
make[2]: *** [src/calibration/lidar/sample_calibration_lidar] Error 1
CMakeFiles/Makefile2:3333: recipe for target 'src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/all' failed
make[1]: *** [src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/all] Error 2
src/calibration/radar/CMakeFiles/sample_calibration_radar.dir/build.make:135: recipe for target 'src/calibration/radar/sample_calibration_radar' failed
make[2]: *** [src/calibration/radar/sample_calibration_radar] Error 1
CMakeFiles/Makefile2:3363: recipe for target 'src/calibration/radar/CMakeFiles/sample_calibration_radar.dir/all' failed
make[1]: *** [src/calibration/radar/CMakeFiles/sample_calibration_radar.dir/all] Error 2
[ 93%] Linking CXX executable sample_feature_tracker
[ 93%] Linking CXX executable sample_calibration_stereo
[ 93%] Linking CXX executable sample_calibration_camera
src/imageprocessing/feature_tracker/CMakeFiles/sample_feature_tracker.dir/build.make:135: recipe for target 'src/imageprocessing/feature_tracker/sample_feature_tracker' failed
make[2]: *** [src/imageprocessing/feature_tracker/sample_feature_tracker] Error 1
CMakeFiles/Makefile2:2398: recipe for target 'src/imageprocessing/feature_tracker/CMakeFiles/sample_feature_tracker.dir/all' failed
make[1]: *** [src/imageprocessing/feature_tracker/CMakeFiles/sample_feature_tracker.dir/all] Error 2
src/calibration/stereo/CMakeFiles/sample_calibration_stereo.dir/build.make:135: recipe for target 'src/calibration/stereo/sample_calibration_stereo' failed
make[2]: *** [src/calibration/stereo/sample_calibration_stereo] Error 1
CMakeFiles/Makefile2:3393: recipe for target 'src/calibration/stereo/CMakeFiles/sample_calibration_stereo.dir/all' failed
make[1]: *** [src/calibration/stereo/CMakeFiles/sample_calibration_stereo.dir/all] Error 2
src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/build.make:135: recipe for target 'src/calibration/camera/sample_calibration_camera' failed
make[2]: *** [src/calibration/camera/sample_calibration_camera] Error 1
CMakeFiles/Makefile2:3273: recipe for target 'src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/all' failed
make[1]: *** [src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/all] Error 2
[ 94%] Linking CXX executable sample_stereo_disparity
src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir/build.make:150: recipe for target 'src/imageprocessing/stereo/stereo/sample_stereo_disparity' failed
make[2]: *** [src/imageprocessing/stereo/stereo/sample_stereo_disparity] Error 1
CMakeFiles/Makefile2:2488: recipe for target 'src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir/all' failed
make[1]: *** [src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
Please could you provide us the reason for this issue and support us in resolving it?
Best regards,
Roshan
