Having followed the instructions in “building the samples” in the driveWorks SDK reference document,
I have used the following cross compile:
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks-1.2/samples/cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK:STRING=/home/test/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux
/drive-t186ref-linux /usr/local/driveworks/samples
which generated build files succesfully to /usr/local/driveworks-1.2/samples/release.
Then I used:
make -j
It created following errors:
test@test-Inspiron-3542:/usr/local/driveworks/samples/release$ sudo make -j
[ 2%] Built target lodepng-src
[ 4%] Built target update_cuda_deps
[ 14%] Built target glfw
[ 25%] Built target dw_samples_framework
[ 26%] Linking CXX executable sample_gps_logger
[ 27%] Linking CXX executable sample_vehicleio
[ 28%] Linking CXX executable sample_canbus_logger
[ 28%] Linking CXX executable sample_record
[ 29%] Linking CXX executable sample_hello_world
[ 28%] Linking CXX executable sample_lane_detection
[ 29%] Linking CXX executable sample_canbus_interpreter
[ 30%] Linking CXX executable sample_icp
[ 31%] Linking CXX executable sample_camera_multiple_gmsl
[ 32%] Linking CXX executable sample_freespace_detection
[ 32%] Linking CXX executable sample_ipc_socketclientserver
[ 32%] Linking CXX executable sample_calibration_imu
[ 33%] Linking CXX executable sample_camera_replay
[ 34%] Linking CXX executable sample_imu_logger
[ 35%] Linking CXX executable sample_sensors_info
[ 35%] Linking CXX executable sample_mapaccess
[ 35%] Linking CXX executable sample_egomotion
[ 36%] Linking CXX executable sample_camera_gmsl_raw
[ 41%] Linking CXX executable sample_occupancy_grid
[ 40%] Linking CXX executable sample_camera_seek
[ 47%] Linking CXX executable sample_drivenet
[ 47%] Linking CXX executable sample_calibration_lidar
[ 47%] Linking CXX executable sample_object_tracker
[ 47%] Linking CXX executable sample_camera_scaling_tracker
[ 42%] Linking CXX executable sample_rig_configuration
[ 41%] Linking CXX executable sample_object_detector
[ 41%] Linking CXX executable sample_camera_gmsl
[ 47%] Linking CXX executable sample_radar_replay
[ 41%] Linking CXX executable sample_lidar_accumulator
[ 46%] Linking CXX executable sample_camera_usb
[ 44%] Linking CXX executable sample_color_correction
[ 45%] Built target dw_samples_image_common
[ 45%] Linking CXX executable sample_template
[ 47%] Linking CXX executable sample_render_engine
[ 47%] Linking CXX executable sample_camera_tracker
[ 48%] Linking CXX executable sample_maptracker
[ 47%] Linking CXX executable sample_calibration_camera
[ 47%] Linking CXX executable sample_lidar_replay
[ 49%] Linking CXX executable sample_blindness_detection
[ 49%] Linking CXX executable sample_drivenetNcameras
[ 49%] Linking CXX executable sample_laneplanner
[ 51%] Built target dw_samples_stereo_common
[ 51%] Linking CXX executable sample_video_rectifier
[ 52%] Linking CXX executable sample_renderer
Scanning dependencies of target sample_image_streamer_multi
[ 53%] Linking CXX executable sample_sfm
[ 54%] Linking CXX executable sample_dataspeedBridge
Scanning dependencies of target sample_stereo_rectifier
Scanning dependencies of target sample_image_streamer_cross
Scanning dependencies of target sample_image_capture
Scanning dependencies of target sample_image_streamer_simple
Scanning dependencies of target sample_stereo_disparity
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate' /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaDestroy’
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' collect2: error: ld returned 1 exit status src/sensors/record/CMakeFiles/sample_record.dir/build.make:110: recipe for target 'src/sensors/record/sample_record' failed make[2]: *** [src/sensors/record/sample_record] Error 1 CMakeFiles/Makefile2:757: recipe for target 'src/sensors/record/CMakeFiles/sample_record.dir/all' failed make[1]: *** [src/sensors/record/CMakeFiles/sample_record.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaDestroy' /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory’
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' collect2: error: ld returned 1 exit status collect2: error: ld returned 1 exit status src/sensors/gps/CMakeFiles/sample_gps_logger.dir/build.make:110: recipe for target 'src/sensors/gps/sample_gps_logger' failed src/hello_world/CMakeFiles/sample_hello_world.dir/build.make:110: recipe for target 'src/hello_world/sample_hello_world' failed make[2]: *** [src/hello_world/sample_hello_world] Error 1 CMakeFiles/Makefile2:2071: recipe for target 'src/hello_world/CMakeFiles/sample_hello_world.dir/all' failed make[1]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/all] Error 2 make[2]: *** [src/sensors/gps/sample_gps_logger] Error 1 CMakeFiles/Makefile2:529: recipe for target 'src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all' failed make[1]: *** [src/sensors/gps/CMakeFiles/sample_gps_logger.dir/all] Error 2 /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/build.make:110: recipe for target ‘src/ipc/sample_ipc_socketclientserver’ failed
make[2]: *** [src/ipc/sample_ipc_socketclientserver] Error 1
CMakeFiles/Makefile2:2014: recipe for target ‘src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/all’ failed
make[1]: *** [src/ipc/CMakeFiles/sample_ipc_socketclientserver.dir/all] Error 2
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' collect2: error: ld returned 1 exit status src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/build.make:136: recipe for target 'src/sensors/lidar/lidar_replay/sample_lidar_replay' failed make[2]: *** [src/sensors/lidar/lidar_replay/sample_lidar_replay] Error 1 CMakeFiles/Makefile2:928: recipe for target 'src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all' failed make[1]: *** [src/sensors/lidar/lidar_replay/CMakeFiles/sample_lidar_replay.dir/all] Error 2 /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/renderer/CMakeFiles/sample_renderer.dir/build.make:110: recipe for target ‘src/renderer/sample_renderer’ failed
make[2]: *** [src/renderer/sample_renderer] Error 1
CMakeFiles/Makefile2:1537: recipe for target ‘src/renderer/CMakeFiles/sample_renderer.dir/all’ failed
make[1]: *** [src/renderer/CMakeFiles/sample_renderer.dir/all] Error 2
[ 55%] Building CXX object src/image/image_streamer_multi/CMakeFiles/sample_image_streamer_multi.dir/main.cpp.o
[ 56%] Building CXX object src/stereo/stereoRectifier/CMakeFiles/sample_stereo_rectifier.dir/main.cpp.o
[ 56%] Building CXX object src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/main.cpp.o
[ 56%] Building CXX object src/image/image_capture/CMakeFiles/sample_image_capture.dir/main.cpp.o
[ 57%] Building CXX object src/image/image_streamer_simple/CMakeFiles/sample_image_streamer_simple.dir/main.cpp.o
[ 57%] Building CXX object src/stereo/disparity/CMakeFiles/sample_stereo_disparity.dir/main.cpp.o
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/build.make:136: recipe for target ‘src/sensors/canbus/interpreter/sample_canbus_interpreter’ failed
make[2]: *** [src/sensors/canbus/interpreter/sample_canbus_interpreter] Error 1
CMakeFiles/Makefile2:871: recipe for target ‘src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/all’ failed
make[1]: *** [src/sensors/canbus/interpreter/CMakeFiles/sample_canbus_interpreter.dir/all] Error 2
src/sensors/info/CMakeFiles/sample_sensors_info.dir/build.make:110: recipe for target ‘src/sensors/info/sample_sensors_info’ failed
make[2]: *** [src/sensors/info/sample_sensors_info] Error 1
CMakeFiles/Makefile2:472: recipe for target ‘src/sensors/info/CMakeFiles/sample_sensors_info.dir/all’ failed
make[1]: *** [src/sensors/info/CMakeFiles/sample_sensors_info.dir/all] Error 2
src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/build.make:110: recipe for target ‘src/sensors/canbus/logger/sample_canbus_logger’ failed
make[2]: *** [src/sensors/canbus/logger/sample_canbus_logger] Error 1
CMakeFiles/Makefile2:814: recipe for target ‘src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/all’ failed
make[1]: *** [src/sensors/canbus/logger/CMakeFiles/sample_canbus_logger.dir/all] Error 2
src/dnn/sample_object_detector/CMakeFiles/sample_object_detector.dir/build.make:110: recipe for target ‘src/dnn/sample_object_detector/sample_object_detector’ failed
make[2]: *** [src/dnn/sample_object_detector/sample_object_detector] Error 1
CMakeFiles/Makefile2:1729: recipe for target ‘src/dnn/sample_object_detector/CMakeFiles/sample_object_detector.dir/all’ failed
make[1]: *** [src/dnn/sample_object_detector/CMakeFiles/sample_object_detector.dir/all] Error 2
/usr/collect2: error: ld returned 1 exit status
localcollect2: error: ld returned 1 exit status
src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/build.make:110: recipe for target ‘src/mapping/occupancy_grid/sample_occupancy_grid’ failed
make[2]: *** [src/mapping/occupancy_grid/sample_occupancy_grid] Error 1
CMakeFiles/Makefile2:1423: recipe for target ‘src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/all’ failed
make[1]: *** [src/mapping/occupancy_grid/CMakeFiles/sample_occupancy_grid.dir/all] Error 2
src/sensors/imu/CMakeFiles/sample_imu_logger.dir/build.make:110: recipe for target ‘src/sensors/imu/sample_imu_logger’ failed
make[2]: *** [src/sensors/imu/sample_imu_logger] Error 1
CMakeFiles/Makefile2:586: recipe for target ‘src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all’ failed
make[1]: *** [src/sensors/imu/CMakeFiles/sample_imu_logger.dir/all] Error 2
src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/build.make:110: recipe for target ‘src/features/camera_tracker/sample_camera_tracker’ failed
make[2]: *** [src/features/camera_tracker/sample_camera_tracker] Error 1
CMakeFiles/Makefile2:1291: recipe for target ‘src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/all’ failed
make[1]: *** [src/features/camera_tracker/CMakeFiles/sample_camera_tracker.dir/all] Error 2
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' /driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/build.make:110: recipe for target ‘src/rigconfiguration/sample_rig_configuration’ failed
make[2]: *** [src/rigconfiguration/sample_rig_configuration] Error 1
CMakeFiles/Makefile2:1480: recipe for target ‘src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/all’ failed
make[1]: *** [src/rigconfiguration/CMakeFiles/sample_rig_configuration.dir/all] Error 2
src/freespace/CMakeFiles/sample_freespace_detection.dir/build.make:110: recipe for target ‘src/freespace/sample_freespace_detection’ failed
make[2]: *** [src/freespace/sample_freespace_detection] Error 1
CMakeFiles/Makefile2:2644: recipe for target ‘src/freespace/CMakeFiles/sample_freespace_detection.dir/all’ failed
make[1]: *** [src/freespace/CMakeFiles/sample_freespace_detection.dir/all] Error 2
src/rectifier/CMakeFiles/sample_video_rectifier.dir/build.make:110: recipe for target ‘src/rectifier/sample_video_rectifier’ failed
make[2]: *** [src/rectifier/sample_video_rectifier] Error 1
CMakeFiles/Makefile2:1957: recipe for target ‘src/rectifier/CMakeFiles/sample_video_rectifier.dir/all’ failed
make[1]: *** [src/rectifier/CMakeFiles/sample_video_rectifier.dir/all] Error 2
src/render_engine/CMakeFiles/sample_render_engine.dir/build.make:110: recipe for target ‘src/render_engine/sample_render_engine’ failed
make[2]: *** [src/render_engine/sample_render_engine] Error 1
CMakeFiles/Makefile2:1594: recipe for target ‘src/render_engine/CMakeFiles/sample_render_engine.dir/all’ failed
make[1]: *** [src/render_engine/CMakeFiles/sample_render_engine.dir/all] Error 2
/usr/local/driveworks-1.2/targets/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate' /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaDestroy’
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' /aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaDestroy’
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' collect2: error: ld returned 1 exit status collect2: error: ld returned 1 exit status src/cameraBlindness/CMakeFiles/sample_blindness_detection.dir/build.make:110: recipe for target 'src/cameraBlindness/sample_blindness_detection' failed make[2]: *** [src/cameraBlindness/sample_blindness_detection] Error 1 CMakeFiles/Makefile2:3202: recipe for target 'src/cameraBlindness/CMakeFiles/sample_blindness_detection.dir/all' failed make[1]: *** [src/cameraBlindness/CMakeFiles/sample_blindness_detection.dir/all] Error 2 collect2: error: ld returned 1 exit status src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/build.make:110: recipe for target 'src/calibration/imu/sample_calibration_imu' failed make[2]: *** [src/calibration/imu/sample_calibration_imu] Error 1 CMakeFiles/Makefile2:3340: recipe for target 'src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/all' failed make[1]: *** [src/calibration/imu/CMakeFiles/sample_calibration_imu.dir/all] Error 2 collect2: error: ld returned 1 exit status /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/build.make:214: recipe for target ‘src/maps/laneplanner/sample_laneplanner’ failed
make[2]: *** [src/maps/laneplanner/sample_laneplanner] Error 1
CMakeFiles/Makefile2:2860: recipe for target ‘src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/all’ failed
make[1]: *** [src/maps/laneplanner/CMakeFiles/sample_laneplanner.dir/all] Error 2
src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/build.make:110: recipe for target ‘src/calibration/camera/sample_calibration_camera’ failed
make[2]: *** [src/calibration/camera/sample_calibration_camera] Error 1
CMakeFiles/Makefile2:3283: recipe for target ‘src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/all’ failed
make[1]: *** [src/calibration/camera/CMakeFiles/sample_calibration_camera.dir/all] Error 2
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' /usr/local//usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined driveworksreference- 1.2to/ targets/NvMediaDlaCreateaarch64’-
Linux//libusr//libdriveworks.solocal/:driveworks undefined-1.2 reference/targets to/ aarch64-NvMediaDlaCreateLinux/'lib //libdriveworks.sousr:/local /undefineddriveworks reference- 1.2to/ targets/NvMediaDlaDestroyaarch64’-
Linux//usrlib//locallibdriveworks.so/:driveworks -undefined1.2 /referencetargets /toaarch64 -LinuxNvMediaDlaDestroy/'lib //libdriveworks.sousr:/ localundefined/ driveworksreference- 1.2to/ targets/NvMediaDlaLoadFromMemoryaarch64’-
src/drivenet/drivenet_ncameras/CMakeFiles/sample_drivenetNcameras.dir/build.make:113: recipe for target ‘src/drivenet/drivenet_ncameras/sample_drivenetNcameras’ failed
make[2]: *** [src/drivenet/drivenet_ncameras/sample_drivenetNcameras] Error 1
src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/build.make:110: recipe for target ‘src/sensors/camera_gmsl_raw/sample_camera_gmsl_raw’ failed
src/dnn/sample_object_tracker/CMakeFiles/sample_object_tracker.dir/build.make:110: recipe for target ‘src/dnn/sample_object_tracker/sample_object_tracker’ failed
make[2]: *** [src/dnn/sample_object_tracker/sample_object_tracker] Error 1
make[2]: *** [src/sensors/camera_gmsl_raw/sample_camera_gmsl_raw] Error 1
src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/build.make:110: recipe for target ‘src/sensors/camera_seek/sample_camera_seek’ failed
CMakeFiles/Makefile2:2779: recipe for target ‘src/drivenet/drivenet_ncameras/CMakeFiles/sample_drivenetNcameras.dir/all’ failed
make[1]: *** [src/drivenet/drivenet_ncameras/CMakeFiles/sample_drivenetNcameras.dir/all] Error 2
make[2]: *** [src/sensors/camera_seek/sample_camera_seek] Error 1
CMakeFiles/Makefile2:1156: recipe for target ‘src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/all’ failed
make[1]: *** [src/sensors/camera_gmsl_raw/CMakeFiles/sample_camera_gmsl_raw.dir/all] Error 2
CMakeFiles/Makefile2:1786: recipe for target ‘src/dnn/sample_object_tracker/CMakeFiles/sample_object_tracker.dir/all’ failed
make[1]: *** [src/dnn/sample_object_tracker/CMakeFiles/sample_object_tracker.dir/all] Error 2
CMakeFiles/Makefile2:700: recipe for target ‘src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/all’ failed
make[1]: *** [src/sensors/camera_seek/CMakeFiles/sample_camera_seek.dir/all] Error 2
src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/build.make:110: recipe for target ‘src/sensors/radar/radar_replay/sample_radar_replay’ failed
make[2]: *** [src/sensors/radar/radar_replay/sample_radar_replay] Error 1
CMakeFiles/Makefile2:985: recipe for target ‘src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all’ failed
make[1]: *** [src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all] Error 2
src/features/camera_scaling_tracker/CMakeFiles/sample_camera_scaling_tracker.dir/build.make:110: recipe for target ‘src/features/camera_scaling_tracker/sample_camera_scaling_tracker’ failed
make[2]: *** [src/features/camera_scaling_tracker/sample_camera_scaling_tracker] Error 1
CMakeFiles/Makefile2:1348: recipe for target ‘src/features/camera_scaling_tracker/CMakeFiles/sample_camera_scaling_tracker.dir/all’ failed
make[1]: *** [src/features/camera_scaling_tracker/CMakeFiles/sample_camera_scaling_tracker.dir/all] Error 2
src/laneDetection/CMakeFiles/sample_lane_detection.dir/build.make:110: recipe for target ‘src/laneDetection/sample_lane_detection’ failed
make[2]: *** [src/laneDetection/sample_lane_detection] Error 1
CMakeFiles/Makefile2:1843: recipe for target ‘src/laneDetection/CMakeFiles/sample_lane_detection.dir/all’ failed
make[1]: *** [src/laneDetection/CMakeFiles/sample_lane_detection.dir/all] Error 2
src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/build.make:110: recipe for target ‘src/lidar_accumulator/sample_lidar_accumulator’ failed
make[2]: *** [src/lidar_accumulator/sample_lidar_accumulator] Error 1
CMakeFiles/Makefile2:3145: recipe for target ‘src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/all’ failed
make[1]: *** [src/lidar_accumulator/CMakeFiles/sample_lidar_accumulator.dir/all] Error 2
src/colorcorrection/CMakeFiles/sample_color_correction.dir/build.make:110: recipe for target ‘src/colorcorrection/sample_color_correction’ failed
make[2]: *** [src/colorcorrection/sample_color_correction] Error 1
CMakeFiles/Makefile2:1900: recipe for target ‘src/colorcorrection/CMakeFiles/sample_color_correction.dir/all’ failed
make[1]: *** [src/colorcorrection/CMakeFiles/sample_color_correction.dir/all] Error 2
src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/build.make:110: recipe for target ‘src/sensors/camera_multiple_gmsl/sample_camera_multiple_gmsl’ failed
make[2]: *** [src/sensors/camera_multiple_gmsl/sample_camera_multiple_gmsl] Error 1
CMakeFiles/Makefile2:1099: recipe for target ‘src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/all’ failed
make[1]: *** [src/sensors/camera_multiple_gmsl/CMakeFiles/sample_camera_multiple_gmsl.dir/all] Error 2
src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/build.make:110: recipe for target ‘src/sensors/camera_replay/sample_camera_replay’ failed
src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/build.make:110: recipe for target ‘src/dataspeedBridge/sample_dataspeedBridge’ failed
make[2]: *** [src/sensors/camera_replay/sample_camera_replay] Error 1
make[2]: *** [src/dataspeedBridge/sample_dataspeedBridge] Error 1
CMakeFiles/Makefile2:643: recipe for target ‘src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/all’ failed
make[1]: *** [src/sensors/camera_replay/CMakeFiles/sample_camera_replay.dir/all] Error 2
CMakeFiles/Makefile2:3511: recipe for target ‘src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/all’ failed
make[1]: *** [src/dataspeedBridge/CMakeFiles/sample_dataspeedBridge.dir/all] Error 2
src/template/CMakeFiles/sample_template.dir/build.make:110: recipe for target ‘src/template/sample_template’ failed
make[2]: *** [src/template/sample_template] Error 1
CMakeFiles/Makefile2:3031: recipe for target ‘src/template/CMakeFiles/sample_template.dir/all’ failed
make[1]: *** [src/template/CMakeFiles/sample_template.dir/all] Error 2
src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/build.make:110: recipe for target ‘src/sensors/camera_usb/sample_camera_usb’ failed
make[2]: *** [src/sensors/camera_usb/sample_camera_usb] Error 1
CMakeFiles/Makefile2:1213: recipe for target ‘src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/all’ failed
make[1]: *** [src/sensors/camera_usb/CMakeFiles/sample_camera_usb.dir/all] Error 2
src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/build.make:214: recipe for target ‘src/maps/mapaccess/sample_mapaccess’ failed
make[2]: *** [src/maps/mapaccess/sample_mapaccess] Error 1
CMakeFiles/Makefile2:2917: recipe for target ‘src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/all’ failed
make[1]: *** [src/maps/mapaccess/CMakeFiles/sample_mapaccess.dir/all] Error 2
src/egomotion/CMakeFiles/sample_egomotion.dir/build.make:110: recipe for target ‘src/egomotion/sample_egomotion’ failed
src/icp/CMakeFiles/sample_icp.dir/build.make:110: recipe for target ‘src/icp/sample_icp’ failed
make[2]: *** [src/icp/sample_icp] Error 1
CMakeFiles/Makefile2:3088: recipe for target ‘src/icp/CMakeFiles/sample_icp.dir/all’ failed
make[1]: *** [src/icp/CMakeFiles/sample_icp.dir/all] Error 2
src/sfm/CMakeFiles/sample_sfm.dir/build.make:110: recipe for target ‘src/sfm/sample_sfm’ failed
make[2]: *** [src/sfm/sample_sfm] Error 1
src/maps/maptracker/CMakeFiles/sample_maptracker.dir/build.make:214: recipe for target ‘src/maps/maptracker/sample_maptracker’ failed
src/vehicleio/CMakeFiles/sample_vehicleio.dir/build.make:110: recipe for target ‘src/vehicleio/sample_vehicleio’ failed
make[2]: *** [src/vehicleio/sample_vehicleio] Error 1
CMakeFiles/Makefile2:1651: recipe for target ‘src/sfm/CMakeFiles/sample_sfm.dir/all’ failed
make[2]: *** [src/maps/maptracker/sample_maptracker] Error 1
make[1]: *** [src/sfm/CMakeFiles/sample_sfm.dir/all] Error 2
make[2]: *** [src/egomotion/sample_egomotion] Error 1
CMakeFiles/Makefile2:3454: recipe for target ‘src/vehicleio/CMakeFiles/sample_vehicleio.dir/all’ failed
src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/build.make:110: recipe for target ‘src/calibration/lidar/sample_calibration_lidar’ failed
make[2]: *** [src/calibration/lidar/sample_calibration_lidar] Error 1
src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/build.make:110: recipe for target ‘src/sensors/camera_gmsl/sample_camera_gmsl’ failed
make[2]: *** [src/sensors/camera_gmsl/sample_camera_gmsl] Error 1
make[1]: *** [src/vehicleio/CMakeFiles/sample_vehicleio.dir/all] Error 2
CMakeFiles/Makefile2:358: recipe for target ‘src/egomotion/CMakeFiles/sample_egomotion.dir/all’ failed
make[1]: *** [src/egomotion/CMakeFiles/sample_egomotion.dir/all] Error 2
CMakeFiles/Makefile2:1042: recipe for target ‘src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/all’ failed
make[1]: *** [src/sensors/camera_gmsl/CMakeFiles/sample_camera_gmsl.dir/all] Error 2
CMakeFiles/Makefile2:3397: recipe for target ‘src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/all’ failed
make[1]: *** [src/calibration/lidar/CMakeFiles/sample_calibration_lidar.dir/all] Error 2
CMakeFiles/Makefile2:2974: recipe for target ‘src/maps/maptracker/CMakeFiles/sample_maptracker.dir/all’ failed
make[1]: *** [src/maps/maptracker/CMakeFiles/sample_maptracker.dir/all] Error 2
src/drivenet/drivenet/CMakeFiles/sample_drivenet.dir/build.make:113: recipe for target ‘src/drivenet/drivenet/sample_drivenet’ failed
make[2]: *** [src/drivenet/drivenet/sample_drivenet] Error 1
CMakeFiles/Makefile2:2722: recipe for target ‘src/drivenet/drivenet/CMakeFiles/sample_drivenet.dir/all’ failed
make[1]: *** [src/drivenet/drivenet/CMakeFiles/sample_drivenet.dir/all] Error 2
[ 58%] Linking CXX executable sample_image_streamer_cross
[ 59%] Linking CXX executable sample_image_streamer_simple
[ 60%] Linking CXX executable sample_image_capture
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' collect2: error: ld returned 1 exit status src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/build.make:113: recipe for target 'src/image/image_streamer_cross_process/sample_image_streamer_cross' failed make[2]: *** [src/image/image_streamer_cross_process/sample_image_streamer_cross] Error 1 CMakeFiles/Makefile2:2390: recipe for target 'src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/all' failed make[1]: *** [src/image/image_streamer_cross_process/CMakeFiles/sample_image_streamer_cross.dir/all] Error 2 /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/image/image_streamer_simple/CMakeFiles/sample_image_streamer_simple.dir/build.make:113: recipe for target ‘src/image/image_streamer_simple/sample_image_streamer_simple’ failed
make[2]: *** [src/image/image_streamer_simple/sample_image_streamer_simple] Error 1
CMakeFiles/Makefile2:2217: recipe for target ‘src/image/image_streamer_simple/CMakeFiles/sample_image_streamer_simple.dir/all’ failed
make[1]: *** [src/image/image_streamer_simple/CMakeFiles/sample_image_streamer_simple.dir/all] Error 2
[ 60%] Linking CXX executable sample_image_streamer_multi
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' collect2: error: ld returned 1 exit status src/image/image_capture/CMakeFiles/sample_image_capture.dir/build.make:113: recipe for target 'src/image/image_capture/sample_image_capture' failed make[2]: *** [src/image/image_capture/sample_image_capture] Error 1 CMakeFiles/Makefile2:2275: recipe for target 'src/image/image_capture/CMakeFiles/sample_image_capture.dir/all' failed make[1]: *** [src/image/image_capture/CMakeFiles/sample_image_capture.dir/all] Error 2 /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/image/image_streamer_multi/CMakeFiles/sample_image_streamer_multi.dir/build.make:113: recipe for target ‘src/image/image_streamer_multi/sample_image_streamer_multi’ failed
make[2]: *** [src/image/image_streamer_multi/sample_image_streamer_multi] Error 1
CMakeFiles/Makefile2:2159: recipe for target ‘src/image/image_streamer_multi/CMakeFiles/sample_image_streamer_multi.dir/all’ failed
make[1]: *** [src/image/image_streamer_multi/CMakeFiles/sample_image_streamer_multi.dir/all] Error 2
[ 60%] Linking CXX executable sample_stereo_rectifier
/usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaLoadFromMemory' collect2: error: ld returned 1 exit status src/stereo/stereoRectifier/CMakeFiles/sample_stereo_rectifier.dir/build.make:112: recipe for target 'src/stereo/stereoRectifier/sample_stereo_rectifier' failed make[2]: *** [src/stereo/stereoRectifier/sample_stereo_rectifier] Error 1 CMakeFiles/Makefile2:2530: recipe for target 'src/stereo/stereoRectifier/CMakeFiles/sample_stereo_rectifier.dir/all' failed make[1]: *** [src/stereo/stereoRectifier/CMakeFiles/sample_stereo_rectifier.dir/all] Error 2 [ 61%] Linking CXX executable sample_stereo_disparity /usr/local/driveworks-1.2/targets/aarch64-Linux/lib/libdriveworks.so: undefined reference to NvMediaDlaCreate’
src/stereo/disparity/CMakeFiles/sample_stereo_disparity.dir/build.make:112: recipe for target ‘src/stereo/disparity/sample_stereo_disparity’ failed
make[2]: *** [src/stereo/disparity/sample_stereo_disparity] Error 1
CMakeFiles/Makefile2:2472: recipe for target ‘src/stereo/disparity/CMakeFiles/sample_stereo_disparity.dir/all’ failed
make[1]: *** [src/stereo/disparity/CMakeFiles/sample_stereo_disparity.dir/all] Error 2
Makefile:127: recipe for target ‘all’ failed
make: *** [all] Error 2
Please help me resolve the errors …
