Hi, I have to manage many RTSP streams, how can I decode entirely on the GPU, with little load on the CPU?
I would like to do everything with deepstream can you tell me how to configure everything so that it works?
• DeepStream Version
• TensorRT Version
• The pipeline being used
Deepstream usually does not use cpu codec, so CPU load is usually not high.
You can try deepstream-app in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app.
You can add source[index your rtsp source] item in configuration file.
• Hardware Platform: GPU RTX 3060
• DeepStream Version: 6.2
• NVIDIA GPU Driver Version: nvidia-driver-535
• UBUNTU 22.04
we need an updated user guide to install deepstream or to use gstreamer on nvidia GPU.
Do you have an example of an app that handles multiple RTSP streams without doing anything else?
You can refer source30_1080p_dec_infer-resnet_tiled_display_int8.yml in /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app
Replace the uri in sources_30.csv as yours
