As I wanted to run my CUDA C/C++ program from a C# application, some people advised me to use ManagedCUDA, so it’s what I did and, with some example, after reading some topics and more failure and test I finally figured out how it works… more or less…
I read that ManagedCUDA doesn’t allow to pass class to kernels so we need to declare it as a structure, that’s what I did. But in theses class I got few function (between 1 and 20) and few class (~8). I’m wondering if it’s possible to just declare the function and define it in the .cu file or if I must declare it in C# and int CUDA. If we can, how to proceed ? I’m not that familiar neither with managedCUDA nor with C#, I’m still learning.
And I also wanted to know how can I allocate variable in a structure with managedCUDA ? 'cause I did something like this :
class program
struct foo
int geo;
void main(string[] args)
CudaDeviceVariable<int>foo.geo = new CudaDeviceVariable<int>(100);
//got error on "foo.geo" -> "expected ;"
//use it some way I donc know..
foo.geo.Dispose()
// CudaDeviceVariable does not contain a definition of geo
So how can I do something like this. I did something very similar in CUDA C/C++ and it works
class foo
int *tabgeo;
int main(void)
foo geo;
cudaMalloc((void **)&geo.tabgeo, sizeof(int) * 100);
// and i can use it in kernel
cudaFree(geo.tabgeo);
