I see that the kernel name in the raw file is demangled. Is there a way to parse the ncu-rep file with --page raw and mangled kernel names?
Let me make sure that I understand your question. Are you looking for a CLI output from the report using “–page raw” but you want the kernel names mangled instead of demangled? If so, you should be able to use “ncu -i <REPORT_FILE> --page raw --print-kernel-base=mangled”. Using the -i flag lets you import an existing report.
Correct. Thank you.
